Like Tree3Likes
  • 1 Post By bnoon
  • 1 Post By Lex
  • 1 Post By paveltol
 Old 07-13-2011, 11:11 PM   #1
volodya84's Avatar
Posts: 1,552   (View Stats)
volodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the world
Groans: 42
Default k16 compressor wheels into k04s
So I met this random dude with a crazy built 2001 s4 putting down 400 awhp *mustang dyno 400awhp*. He mentioned something to me that just blew my mind.
Putting a k16 turbo compressor wheel (I believe porsche uses k16 turbos for the 911 or some shit) into the stock k04s. I know there is some porting involved, but is this possible for us mazdaspeed folk?
Corksport TMIC // Denso ITV22s .028" // COBB SRI // Corksport TIP // Forge V1 BPV // COBB AP // JBR SSP // TWM Bushings // Prosport Boost Gauge // CS Interior LED kit
"ban post whoring brownies"
Forge v1
volodya84 is offline   Reply With Quote
The Following User Says Thank You to volodya84 For This Useful Post:
Docnox (07-16-2011)
 Old 07-13-2011, 11:58 PM   #2
chuckms6's Avatar
Posts: 1,618   (View Stats)
chuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the world
just googled it... looks very interesting. im looking for more power up top for not too much money with silmilar spool and this looks promising. just trying to find more info on a mazda k04 application since the housings are different
chuckms6 is offline   Reply With Quote
 Old 07-14-2011, 12:12 AM   #3
chuckms6's Avatar
Turbo Compressor Wheel KKK K16 5324-123-2006 by BAE | eBay
$60 for a compressor wheel? i say its worth a try!
The Following User Says Thank You to chuckms6 For This Useful Post:
Docnox (07-16-2011)
 Old 07-14-2011, 12:17 AM   #4
volodya84's Avatar
Groans: 42
yea, but how much is porting the turbo?
Sent from my SPH-D700 using Tapatalk
Forge v1
 Old 07-14-2011, 12:41 AM   #5
Karmat's Avatar
Posts: 1,179   (View Stats)
400awhp S4 doesnt need to be "crazy built" just needs a pair of k04s and some supporting mods.
Subbed for some k16 info.
2002 Corvette Z06 (Black)
 Old 07-14-2011, 12:53 AM   #6
friedricebob's Avatar
Posts: 102   (View Stats)
friedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond repute
Looked at it a bit myself. All of the Audi guys who are doing it are having the compressor wheel swap done by a turbo shop. So basically the cost of reworking a K04, and then the cost of the wheel and anything else that needs to be swapped out or machined/modified. Maybe even a new K16 cold side housing?
From this site:
Compressor Wheels - 3K Racing Applications - TurboMaster
K04 Wheel diameter: 51mm
K16 Wheel diameter: 55mm
The S4's are claiming 20-30 whp for swapping to a PAIR of hybrids.
RIP
friedricebob is offline   Reply With Quote
 Old 07-14-2011, 02:31 AM   #7
paveltol's Avatar
Posts: 520   (View Stats)
My advice to you is just to go BNR turbo. I have a Stg3 and it pulls hard up to 7200rpm. With extremely conservative tune at 15.5psi it goes fast and is veeeeery smooth. Going to tune for 18ish psi soon. Without meth and with local pos gas..
paveltol is offline   Reply With Quote
The Following 6 Users Say Thank You to paveltol For This Useful Post:
AJ713 (07-15-2011), Alpha (07-14-2011), Dash08 (07-15-2011), Docnox (07-16-2011), laxplayermjd (07-14-2011), Tokay444 (07-14-2011)
 Old 07-14-2011, 08:21 AM   #8
Alpha's Avatar
Posts: 3,711   (View Stats)
Originally Posted by paveltol View Post
My advice to you is just to go BNR turbo. I have a Stg3 and it pulls hard up to 7200rpm. With extremely conservative tune at 15.5psi it goes fast and veeeeery smoothly. Going to tune for 18ish psi soon. Without meth and with local pos gas..
Agreed. You could push that BNR much harder/more safely than the stock K04 and make one hell of a snappy DD as long as you drive and tune the car properly.
I remember Bryan talking about 25psi and me saying "No way..." but he was very calm and cool about doing so with a good tune on a stock motor.
rfinkle2 (07-15-2011)
 Old 07-14-2011, 08:58 AM   #9
volodya84's Avatar
Groans: 42
So the bnr turbos are basically upgraded k04s anyway, right?
Forge v1
 Old 07-14-2011, 09:07 AM   #10
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
I don't think the compressors are the issue on our turbos, it's the turbine side. Too damn restrictive.
07 MS3
The original Genpoo Hater
 Old 07-14-2011, 09:28 AM   #11
JMEngineer's Avatar
Posts: 2,122   (View Stats)
JMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the world
Groans: 32
Groaned at 19 Times in 15 Posts
Unless you find a shop that is familiar with doing this I think just going to a 2871 would be easier.
Personally I like the feel of larger turbos that need rpm to spool and make BIG power up top. I don't even have my 3076 installed yet and I already wish I had gone with a GT35R.
2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list...
2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch
-GTX2867R Coming Soon
JMEngineer is offline   Reply With Quote
The Following User Says Thank You to JMEngineer For This Useful Post:
Alpha (07-14-2011)
 Old 07-14-2011, 10:30 AM   #12
chuckms6's Avatar
They have different turbine wheels on the site I linked. And for someone who can do porting themselves this is a very good option for someone who just wants to hold boost to redline without having to drop the big bucks to to bt
tapatalkin to you
DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's
SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's)
 Old 07-14-2011, 10:37 AM   #13
volodya84's Avatar
Groans: 42
hmm more reseatch needs to be done here. unfortunately I am neither smart nor knowledgeable enough to pioneer this turbo mod approach.
Forge v1
 Old 07-14-2011, 10:41 AM   #14
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Someone who claims they can uniformly port housings by hand is surely going to lead to either surge issues or outright failure. I'd only trust a machine shop to machine the housings to fit larger wheels, THEN I'd send the housings to extrude hone for full housing enlarging and not just porting where a tool can reach.
But for all that effort and money, fuckin go big turbo.
07 MS3
Fobio (07-15-2011), Tokay444 (07-14-2011)
 Old 07-14-2011, 11:52 AM   #15
bnoon's Avatar
Posts: 1,770   (View Stats)
No matter what wheel you install the compressor housing is going to need to be machined because different wheels use different heights and blade angles... the housings have to match those blade angles. It's not just a pull and replace type of thing. Then, the whole thing needs to be rebalanced too. By that time you're pretty much looking at a $600-$800 job with a rebuild, which is right where the modded K04 costs are at. Any 7mm wheel will fit, doesn't have to be a "stock" K16 wheel. Just look at the compressor maps of all of the K04 wheels and there are several that are upgrades for our stock K04 configurations.
MZR165 likes this.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
The Following User Says Thank You to bnoon For This Useful Post:
Docnox (07-16-2011)
 Old 07-14-2011, 12:02 PM   #16
This will be made much easier if you can get the K16 backing plate and compressor housing as well as the wheel. Then hope it fits on the CHRA of the K04.
blackstar likes this.
AZSPEED3 (07-14-2011)
 Old 07-15-2011, 12:26 AM   #17
paveltol's Avatar
Nice turbo! My tuner said that under load it performs perfectly and is capable of pushing some significant amounts of air. Considerably more than the stock k04 can. Plus to that he noticed that the EGT with BNR Stg3 is lower. Definitely good news.
What makes me excited is that the way the car pulls with this turbo. With stock manifold it spools just a tiny bit later(maybe 100-200 RPM), but then goes on pulling. Feels like you're in a fast subway train))) I like it!
 Old 07-15-2011, 01:09 PM   #18
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Yep, but step one of the BNR upgrade is to toss the entire K04...LOL
Only the exhaust housing is reused from the stock turbo on the BNR S3.
Basically, the BNR S3 is a GT2871 that bolts right up for cheap.
Docnox (07-16-2011), rfinkle2 (07-15-2011)
 Old 07-15-2011, 01:26 PM   #19
volodya84's Avatar
Groans: 42
So what you're saying is the with the S3 you just take the k04 off and put the bnr on, no other modification required??????
Forge v1
 Old 07-15-2011, 01:33 PM   #20
Eth/Meth Junkie
cld12pk2go's Avatar
Here is the link:
BNR Supercars - Bryan Nickell's Rotary Supercars - Mazdaspeed3/Mazdaspeed6/CX7
You can call Brian up to discuss the details or read through the multiple install threads.
You need to bend one of the stock coolant lines, and have provisions for the 2.5'' intake coupler, but other than that it is drop in. No custom oil lines, downpipe, or exhaust manifold required as the stock turbine housing bolts right up.
 Old 07-15-2011, 01:41 PM   #21
Another cool, but more expensive option is this housing ATP makes:
At the very end of the page, it notes that everything remains stock.
I believe Driver311 is using this option.
http://www.atpturbo.com/mm5/merchant...egory_Code=MS3
 Old 07-16-2011, 03:02 AM   #22
paveltol's Avatar
Correct! Except for the stuff that cld12pk2go mentioned above. But all that is as easy as breathing. No drilling/cutting/fitting/wrecking anything. At all.
The Following User Says Thank You to paveltol For This Useful Post:
rfinkle2 (07-16-2011)
 Old 07-16-2011, 05:38 AM   #23
volodya84's Avatar
Groans: 42
pavel, it was your car that ran 11 seconds, right?
Forge v1
 Old 07-17-2011, 02:17 AM   #24
paveltol's Avatar
Nope) That was the car of our Ukranian clubmate. It has 500+hp now and is heavily tuned.
rfinkle2 (07-17-2011)
 Old 08-18-2011, 11:09 AM   #25
Domino81's Avatar
Posts: 5,081   (View Stats)
Subscribed. I've been looking into a rebuild.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
 Old 10-28-2013, 01:54 PM   #26
wallenberg's Avatar
Posts: 13   (View Stats)
wallenberg has a spectacular aura aboutwallenberg has a spectacular aura about
Sorry for posting in this really old thread, but i have got hold on at slightly used K16 turbo from a Focus RS.
Is there any possibility that i can remove it from the old turbine housing and put it in the K04s ?
Thanks
wallenberg is offline   Reply With Quote
Compressor Mapping mkriebs MazdaSpeed 3/6 - Turbo Induction 12 02-03-2010 06:35 AM
Compressor surge v2 Dash08 MazdaSpeed 3/6 - Turbo Induction 6 05-31-2009 08:21 AM
compressor surge? k0m MazdaSpeed 3 - Engine, Transmission & Driveline 3 04-30-2009 10:21 AM
Page generated in 0.46503 seconds with 33 queries
