 Old 09-25-2016, 02:05 PM   #1
Lex2007's Avatar
Posts: 574   (View Stats)
Default Leaking, dripping turbo
I smelled something burning when driving the car last couple of days and got under it to find oil dripping down onto the turbo heat shield among other places. Hence the smell.
Any guess as to the source? I see some coming down from the turbo inlet but mostly it looks like the turbo oil return hardline to the engine block. Thats very wet as you can see.
Is this likely the gasket on the oil return line? I assume its a hard gasket from Mazda only?
My car's engine is stock accept for CAI. Stock turbo, never touched. $113k miles.
These pic were taken from underneath the car, obviously. I appreciate you help.
Bottom of turbo:
Engine block at end of oil return line:
Oil return line:
Oil leaking from turbo Djohns 2010 MS3 - Troubleshoot/Diagnostics 42 03-22-2019 07:39 AM
"Smoking Turbo" / Leaking Catalytic Converter mars0282 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 04-05-2016 09:22 AM
Strange Dripping Sound r0cknry MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 12-24-2011 11:12 PM
KO4 TURBO ON MS6 LEAKING OIL RETURN LINE GAMISTAD Mazdaspeed3/6 General Discussion 9 01-27-2011 01:06 AM
Leaking turbo seal after catted DP install (surprise, surprise) -cj- MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 02-16-2010 11:03 PM
Page generated in 0.22314 seconds with 20 queries
