![]() Join Date: May 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score Any guess as to the source? I see some coming down from the turbo inlet but mostly it looks like the turbo oil return hardline to the engine block. Thats very wet as you can see. Is this likely the gasket on the oil return line? I assume its a hard gasket from Mazda only? My car's engine is stock accept for CAI. Stock turbo, never touched. $113k miles. These pic were taken from underneath the car, obviously. I appreciate you help. Bottom of turbo: Engine block at end of oil return line: Oil return line: Last edited by Lex2007; 09-28-2016 at 10:04 AM. |
| Oil leaking from turbo | Djohns | 2010 MS3 - Troubleshoot/Diagnostics | 42 | 03-22-2019 07:39 AM |
| "Smoking Turbo" / Leaking Catalytic Converter | mars0282 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 04-05-2016 09:22 AM |
| Strange Dripping Sound | r0cknry | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 8 | 12-24-2011 11:12 PM |
| KO4 TURBO ON MS6 LEAKING OIL RETURN LINE | GAMISTAD | Mazdaspeed3/6 General Discussion | 9 | 01-27-2011 01:06 AM |
| Leaking turbo seal after catted DP install (surprise, surprise) | -cj- | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 9 | 02-16-2010 11:03 PM |
