![]() | | #41 | ![]() |
![]() Join Date: Jul 2009 Location: Sardinia, Ohio
Rep Power: 4725 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,721
| Not Ranked : 0 score
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. | ||
| The Following User Says Thank You to SilverDemon For This Useful Post: | Boosted Beluga (06-21-2012) |
![]() | | #42 | ![]() |
why not just let the consumer swap it like the skunk2 unit? u just sell us the completed TP/housing and we swap over our stock guts/cover.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
| The Following 6 Users Say Thank You to superskaterxes For This Useful Post: | 06Speed6 (06-21-2012), bcmurphy87 (06-21-2012), darkcherry (06-26-2012), djuosnteisn (06-21-2012), NJSPEED3 (07-12-2012), wolly6973 (06-23-2012) |
![]() | | #43 | ![]() |
![]() Join Date: Nov 2011 Location: Caldwell, ID
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,042
| Not Ranked : 0 score hillbilly: "Hey duz dat thing got uh hemi in it?" MS owner: "Fuck yeah bitch!!!!!!!!"
__________________ Old stuff: Stock k04 12.301 @ 113.20 New Stuff: PTE 5858 and Built, not bought, by ME ![]() |
| The Following 4 Users Say Thank You to h.h.sk1nny For This Useful Post: |
![]() | | #44 | ![]() |
![]() Join Date: Feb 2009 Location: Atlanta Ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,123
| Not Ranked : 0 score in b4 aftermarket TB options are availible before IM hits the mass market. |
| The Following 11 Users Say Thank You to bcmurphy87 For This Useful Post: | 06Speed6 (06-21-2012), Boosted Beluga (06-21-2012), djuosnteisn (06-21-2012), doubleflusher (06-21-2012), Easter Bunny (06-21-2012), Erich (06-21-2012), JacksonMS30 (07-03-2012), nighthawk358 (06-22-2012), SPEED6 KILLAH (06-21-2012), TWOptSL0W (07-04-2012), uncorked11 (06-22-2012) |
![]() | | #45 | ![]() |
![]() Join Date: Apr 2010 Location: Elizabeth /NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,623
basically you would have to reverse engineer the Tb. Its really not worth it because of the cost. You can the a new TB for $200.00 with the wire... | |
| The Following User Says Thank You to SPEED6 KILLAH For This Useful Post: | wolly6973 (06-23-2012) |
![]() | | #46 | ![]() |
| Not Ranked : 0 score I did a little research, I think @Erich's TB is the 74mm 2011-2012 Dodge 3.6L TB. The Dodge 3.5l V6 TB is 64mm and the hemi 5.7l v8 TB looks like 80mm EDIT: Erich's TB is likely ported, the ported TB that is available has a 80mm radiused opening with the oem 74mm oem blade. IIRC the blade is not replaceable. EDIT #2: 74mm is 2.9", which is a 6.6sq" area, subtract out 20% for the blade and shaft... 5.28sq" area... thats about a 2.6" dia useable area TB EDIT #3: I am starting to like that TB alot
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG Last edited by 06Speed6; 06-21-2012 at 04:38 PM. |
| The Following 2 Users Say Thank You to 06Speed6 For This Useful Post: | doubleflusher (06-21-2012), wolly6973 (06-23-2012) |
![]() | | #47 | ![]() |
![]() Join Date: Jun 2009 Location: Riverside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,560
Groans: 50
| Not Ranked : 0 score Any more edits^^^
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit |
| The Following User Says Thank You to Boosted Beluga For This Useful Post: | 06Speed6 (06-21-2012) |
![]() | | #48 | ![]() |
![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
| Not Ranked : 0 score Do you have more info on this throttle body. This size would be ideal for an upgrade in my opinion for everything 3076 and under. In my experience, even if the stock throttle body can support up to XX HP, on a boosted application a slightly larger TB tends to lend to gains, even if they aren't "huge" gains. Many of us have ported stock intake manis, which include porting of the throttle body opening area of the manifold. A 66mm would be perfect.
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
| The Following User Says Thank You to mrmonk7663 For This Useful Post: | Boosted Beluga (06-21-2012) |
![]() | | #49 | ![]() |
| Not Ranked : 0 score That is the 3.5L dodge v6 TB. Factory OEM CHRYSLER 300 DODGE Charger NEW Throttle Body 2.7L 3.5L 4.0L | eBay The problem with making an adapter is that the holes in the TB are almost on top of the holes in the IM so you would have to make a really thick adapter which is $$$$. If you have to spend $300 on a limited market 4" spacer that is not a bolt on because the intake system would have to be rebuilt, which is more $$, why not just drop $600 on a new IM that keeps the stock TB location? Or you can cut the oem IM's TB flange off and machine a new one and weld it on and blend it in, but that isnt going to be much cheaper because welding and port matching arent cheap.
![]() | | #50 | ![]() |
(Thread Starter) | Not Ranked : 0 score pablo is sending me a sketch of the hemi TB bolt pattern and im gona see if i can get one made locally. it depends on how much overlap there is between the bolts before we can decide how to tackle it
![]() | | #51 | ![]() |
![]() Join Date: Jul 2008
Rep Power: 1790 ![]() Thanks: 2,239
Groans: 62
Groaned at 156 Times in 148 Posts
| Not Ranked : 0 score If someone wants to send me that TB, I'll make an adapter plate and price out a part in about a week. |
| The Following User Says Thank You to MarkyMark For This Useful Post: | mrmonk7663 (06-21-2012) |
![]() | | #52 | ![]() |
![]() Join Date: Mar 2012 Location: Burlington, WI
| Not Ranked : 0 score I don't as I don't work for chrysler, but a dealers parts department should be able to get them, they will want a vin of a vehicle though. This is because parts guys in this day and age suck and can't do a damn thing without a computer. The easy way is find a truck that they have on their lot and use that vin.
__________________ Cobb AP // Cobb SRI // Cobb TIP // Autotech Internals // Synapse BPV // JBR 88a // H&R Springs |
![]() | | #53 | ![]() |
| The Following 7 Users Say Thank You to SPEED6 KILLAH For This Useful Post: | 06Speed6 (06-22-2012), Boosted Beluga (06-21-2012), doubleflusher (06-22-2012), JacksonMS30 (07-03-2012), MarkyMark (06-22-2012), mrmonk7663 (06-21-2012), NJSPEED3 (07-12-2012) |
![]() | | #54 | ![]() |
| Not Ranked : 0 score Do you have a link for the spacers you just posted, and can you verify if the 66mm TB electronics work the same as our stock, or is it different and requires mods/recalibrations within the TB itself? You have me VERY interested.
![]() | | #55 | ![]() |
| Not Ranked : 0 score Is there enough room to countersink a bolt? I didnt think there was.
![]() | | #56 | ![]() |
would you be able to do rifling on the inner bore to help swirl the air for people who have AUX injection?
we shall see!!! if not do u see a problem rotating the TB 20ish degrees to allow the bolts to no longer line up? ive never seen a TB at any angle other then 0 and 90 so it begs the question if this really matters or not. also does it matter if the top of the throttle plate opens towards or away from the manifold?
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | ||
| The Following 4 Users Say Thank You to superskaterxes For This Useful Post: | dot584 (06-25-2012), doubleflusher (06-22-2012), mrmonk7663 (06-22-2012), SPEED6 KILLAH (06-22-2012) |
![]() | | #57 | ![]() |
| Not Ranked : 0 score Ok Anthony, so you will be testing the 64mm chrysler 300/charger TB correct? This throttle body can be opened up to 71 or 72mm successfully...it is common for the V6 crowd to do that to the TB...so if this throttle body works it will theoretically provide us with a very wide range of power configurations!!!
![]() | | #58 | ![]() |
| Not Ranked : 0 score noob answer...yes. the blade would probably direct flow more so in one direction than another if not at a 90 or parallel to the runners.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 |
![]() | | #59 | ![]() |
![]() | | #60 | ![]() |
Groans: 62
| Not Ranked : 0 score Should be. I'll just get different hardware to bolt the assembly together. Even a 1/2 spacer will throw TMIC fitment off. I'd prefer to make the spacer comforatbly, which would be a little thicker, and those with FMIC piping would be much easier to accommodate. I would prefer to build a whole unit. I'll try to get this TB i have here taken apart all the way to analyze it. |
| The Following 4 Users Say Thank You to MarkyMark For This Useful Post: |
![]() | | #61 | ![]() |
Rep Power: 151849 ![]() Thanks: 55,993
Groans: 1,443
| Not Ranked : 0 score Those with a TMIC need not try this mod. They're already way behind the 8 ball for making power.
__________________ Evo VIII - 9.93 @ 150.05 - CAI and LEDs Beanfab / Tuned by Nishan |
| The Following 6 Users Say Thank You to doubleflusher For This Useful Post: | 06Speed6 (06-22-2012), Don06speed6 (06-22-2012), MarkyMark (06-22-2012), PapaSmurf (06-22-2012), SilverDemon (06-22-2012), TWOptSL0W (07-04-2012) |
![]() | | #62 | ![]() |
| Not Ranked : 0 score Alright, there have been too many throttle bodies thrown into this thread. Lets Catalog. HEMI 05-12 Challenger, Charger, 300, Magnum 5.7L, 6.1L, 392/6.4L $120 or so...spacer most likely needed 05-10 300/Challenger/Charger/Magnum 2.7L or 3.5L- 64mm (able to be ported to at least 71mm) $70-$100 NEW Spacer needed most likely Stock Optimized Throttle Body-60mm with partly opened up to 64mm $285 NEW CX9 Throttle Body-72mm optimized (electronics are different and a bitch to work with) $300+ Did I miss anything? I for one and interested in the 64mm Charger throttle body. These can be opened up safely to 71MM...so you would have a throttle body that could grow with your application. 80MM is huge and would be better reserved for the "big dogs"...for everyone else I would believe the 64-71mm range would be sufficent for normal BT applications (GTX series, BNR, etc) So with this recap, do any of yall have information on the 64mm Dodge Charger/Chrysler 300 V6 Throttle body other than the pictures that were posted in this thread?
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN Last edited by mrmonk7663; 06-22-2012 at 02:13 PM. |
![]() | | #63 | ![]() |
| Not Ranked : 0 score Anthony do you want the 74mm 3.6l and cx-9 tb?
![]() | | #64 | ![]() |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45885 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
__________________ 2 years after hitting 700hp and still running strong. Happy to see others joining the club. | |
| The Following User Says Thank You to Erich For This Useful Post: | superskaterxes (06-22-2012) |
![]() | | #65 | ![]() |
| Not Ranked : 0 score Bro I think you are the only person in this thread that is willing to drop hundreds of dollars into custum fab work for a tb that is less than a quarter inch bigger than stock.
![]() | | #66 | ![]() |
(Thread Starter) | Not Ranked : 0 score ill take the 74mm TB, i dont think its worth it to have to tear apart the CX-9 TB to get it to work. its going to be hard enough getting the other ones dialed in with ATR let alone having to gut them a re-position the TPS and whatnot. my goal at this point is to get an adapter made for 1-2 TB's and get it working well enough to say its not destroying the drive-ability of my car. going fast is cool, but if i want to kill someone driving in traffic/PT because of my TB then i wont be running one of these lol
![]() | | #67 | ![]() |
lol
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
![]() | | #68 | ![]() |
| Not Ranked : 0 score Guess I didn't really consider what somebody else would have to drop into it. That being said, I certainly didn't drop hundreds of dollars of custom fab work for it to work (unless you include my IM and Intercooler set up, which was happening no matter which throttle body I went with.)
![]() | | #69 | ![]() |
![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 2506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,527
| Not Ranked : 0 score I'll read this later when I'm not swamped at work. And god damn you mother fuckers for giving me another thing to freak out about because I have to figure out where the money is coming from because god forbit I not have a any additional power adders on this car that I didn't before...
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
![]() | | #70 | ![]() |
| Not Ranked : 0 score Updated HEMI 05-12 Challenger, Charger, 300, Magnum 5.7L, 6.1L, 392/6.4L-80MM $120 or so...spacer most likely needed 05-10 300/Challenger/Charger/Magnum 2.7L or 3.5L- 64mm and able to be ported to 72mm. Need Spacer 3.6L Chrysler/Dodge Throttle Body -74mm and can be ported up to 80mm. Need Spacer About $180 New Stock Optimized Throttle Body-60mm with partly opened up throat to 64mm $285 NEW CX9 Throttle Body-72mm optimized (electronics are different and a bitch to work with) $300+
| The Following 2 Users Say Thank You to mrmonk7663 For This Useful Post: | djuosnteisn (06-25-2012), Domino81 (06-22-2012) |
![]() | | #71 | ![]() |
| Not Ranked : 0 score @Dano @Erich I was talking about mrmonk7663 wanting the 64mm tb. The 74mm tb is a good fit for any of us I think.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | Dano (06-22-2012) |
![]() | | #72 | ![]() |
| Not Ranked : 0 score Anthony one thing to consider is that if erich/john had that much trouble dialing in a 74mm, the 80mmthe is going to be harder and even more on/off. Supras have a 71mm tb and they dont have trouble hitting the numbers we want.
| The Following 3 Users Say Thank You to 06Speed6 For This Useful Post: |
![]() | | #73 | ![]() |
| Not Ranked : 0 score I think it would have been much easier with the proper tables instead of using what is available for a workaround.
![]() | | #74 | ![]() |
| Not Ranked : 0 score O I C...I was afraid that might be the case...that you were talking to mrmonk
![]() | | #75 | ![]() |
| Not Ranked : 0 score I'm not willing to spend hundreds and hundreds of dollars getting a throttle body marginally larger to fit. With the picture of the 64mm TB that was posted I was under the impression that it had already been adapted successfully to our platform by someone, hence I was focusing on that TB. Also, the fact that it can be ported to 72mm made it even more attractive. If it's a bitch and a half to adapt then no I wouldn't want to do it. We have tossed around so many different TBs in here in a short period of time, the thread was getting jumbled, so I made the list a few posts above. Maybe you guys were not getting lost but I was haha. So for now, it looks like the upcoming testing will be the 74mm 3.6L throttle body correct, and it will be done by Anthony? I have access to a machine shop 5 days a week, and if I had drawings and or a TB I could get the guys to make a spacer with the countersunk holes etc...so it would be no money invested on my part for the spacer aspect. At the same time I have no desire to have to take apart and rewire a throttle body unit.
![]() | | #76 | ![]() |
| Not Ranked : 0 score Sure send it to mark once your done with it. Hopefully mark won't take long making the spacer.. |
| The Following User Says Thank You to SPEED6 KILLAH For This Useful Post: | MarkyMark (06-23-2012) |
![]() | | #77 | ![]() |
Groans: 62
| Not Ranked : 0 score Seeing the limited number of peeps, I'm sure I could get 50 working into machining schedule and the price wouldn't be too bad. Although it would take a year from now to sell them all LOL. |
| The Following User Says Thank You to MarkyMark For This Useful Post: | 06Speed6 (06-23-2012) |
![]() | | #78 | ![]() |
Groans: 50
| Not Ranked : 0 score With the amount of ppl going big turbo there might be more interest then you think. Plus ppl might do this before going BT as a supporting mod. Hell even if a bolt on k04 car put the TB on and it showed some gains I'm willing to bet ppl would jump all over these.
![]() | | #79 | ![]() |
| Not Ranked : 0 score I'm k04 and itching for one of these. I'll be the k04 guinea pig
| The Following User Says Thank You to mrmonk7663 For This Useful Post: | Boosted Beluga (06-22-2012) |
![]() | | #80 | ![]() |
![]() Join Date: Sep 2011 Location: Lexington Park, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,852
Groans: 165
| Not Ranked : 0 score I think it would take less time to sell like other have said for the reasons posted above. if it works well and tuned easy with average pricing I will upgrade as well.
__________________ New....Camaro SS/RS Stocked out selling parts.2011 Black MS3 -GTX3071R , 38mm Tial Wastegate, CPE Exhaust Manifold, Cobb AP, HKS SSQV 4, Autotech Internals, JBR SSP & Bushings, JBR Fully mounted 88 duro, JBR OCC, JBR EGR delete, TWM M1Knob, H&R springs, Ultimate Racing Turbo back, NKG plugs, CP-E FMIC, big MAF, big TIP, Grimmspeed MBC, SPC Rear Camber Arms, JBR Sway bar. 2006 Jeep Wrangler -20 grand of Shit |
| The Following 2 Users Say Thank You to uncorked11 For This Useful Post: | Boosted Beluga (06-22-2012), mrmonk7663 (06-22-2012) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/lets-talk-about-bigger-throttle-bodies-116929/ | ||||
| Throttle body | This thread | Refback | 08-06-2013 09:04 AM | |
| Lets talk fuel pump internals | Javi | Mazdaspeed3/6 General Discussion | 63 | 04-10-2014 04:44 PM |
| Lets talk Compressor AR | superskaterxes | MazdaSpeed 3/6 - Turbo Induction | 16 | 03-30-2012 10:54 AM |
| Lets talk turbo sizing | bf360 | MazdaSpeed 3/6 - Turbo Induction | 23 | 12-17-2009 03:49 PM |
| Lets talk clutches | Death-From-A-Mile | MazdaSpeed 3 - Engine, Transmission & Driveline | 4 | 11-03-2008 08:37 PM |
