![]() | | #81 | ![]() |
| Not Ranked : 0 score
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
![]() | | #82 | ![]() |
already attempted to convey that. It it didn't stick Lol 3071 is argueable for a larger TB Tappin
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
![]() | | #83 | ![]() |
![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
| Not Ranked : 0 score I do not disagree with the above, but k04 is temporary
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
| The Following 2 Users Say Thank You to mrmonk7663 For This Useful Post: | bcmurphy87 (06-23-2012), Dano (06-23-2012) |
![]() | | #84 | ![]() |
| Not Ranked : 0 score I am pretty sure that alot of people have a ported oem tb and I think those are only ported 2-3mm and I think its costs like $200 so I think alot of people would jump on a real upgrade even with a ko4. I think what holds alot of people back is that we dont really have any real sponsored cars that showcase real parts and mod paths. If you look at every other car out there they have shop owned cars running fast times, we have... gt40... just saying Go fast cars sell go fast parts.
| The Following 4 Users Say Thank You to 06Speed6 For This Useful Post: |
![]() | | #85 | ![]() |
| Banned ![]() Join Date: Dec 2010 Location: Middlesex County, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 170
Groaned at 188 Times in 55 Posts
| Not Ranked : 0 score |
![]() | | #86 | ![]() |
![]() | | #87 | ![]() |
| Not Ranked : 0 score Thats the 80mm hemi tb, it can be ported to those sizes
| The Following User Says Thank You to 06Speed6 For This Useful Post: | WWPearlMS6 (06-23-2012) |
![]() | | #88 | ![]() |
(Thread Starter) | Not Ranked : 0 score we dont need a ported TB, we need a stock one thats bigger so we can keep the price down. anything bigger then 60mm will be better so no use getting a 70mm TB ported to 80mm when you can just buy an 80mm OEM one from a different platform.
| The Following 4 Users Say Thank You to superskaterxes For This Useful Post: |
![]() | | #89 | ![]() |
![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 2506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,527
| Not Ranked : 0 score So this discussion is centered around finding a part we can all agree on then getting the eletronics to work?
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
![]() | | #90 | ![]() |
(Thread Starter) | Not Ranked : 0 score roughly. the latter part of your statement is alot harder then most think so it may just be a matter of trying 6 different throttle bodies of which 2 work electronically and having the choice between those 2 compared to vise versa.
![]() | | #91 | ![]() |
![]() Join Date: Feb 2009 Location: Atlanta Ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,123
| Not Ranked : 0 score Is this the TB we have decide might work best? Chevrolet GMC Hummer Isuzu Pontiac Saab Throttle Body 3.5L 3.7L 4.2L 5.3L V6 V8 | eBay |
![]() | | #92 | ![]() |
no the one you need is in the OP, which we still dont know if it works or not.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
![]() | | #93 | ![]() |
| Not Ranked : 0 score I know, frankly, I'm surprised anyone is even attempting it.
![]() | | #94 | ![]() |
![]() Join Date: May 2010 Location: Copperas Cove, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 153
| Not Ranked : 0 score Ok! here is the for the part number that Erich stated before. THROTTLE BODY. for DODGE WD75 (2011, 2012) (05184349AC) It cost $194+ s&h. There is already a solution our platform. We do not need to re-invent the wheel. We just need to figure out the wiring. I guess it would help to take a closer look to Erichs wiring. Its not that hard. It will obviously not work with the factory IM. Therefore each individual will have tofigure out their own IM solution. There are some people like me that built a IM but are using a factory IM ported ect ect. Its not that hard to redo the IM mounting base to fit this TB. I like the skun2 idea since their stuff is proven to work, but the dodge TB is already proven to put out.
__________________ Death is destroyed forever in Victory We built this world on fashion we built this world on fashion I’ve become one to save one that I may by all means save some. Savior...Redeemer... Friend... We both know that we're running this race to win. My reward is that I can offer you a relationship with Him. Freely so you do not run aimlessly. I’m here to help you. Guidance is not far but it is near. All you have to do is ask. Please just ask. I am free I make myself a slave to all people so that I can save some I become one to win one I become one to save one. Everyone who asks may receive the one. Blessed is the man who does not walk in the counsel of the wicked or stand in the way of sinners or sit in the seat of mockers. ![]() |
![]() | | #95 | ![]() |
| Not Ranked : 0 score I do not think we are reinventing the wheel. I think the purpose of this thread is to find a better and more straight forward approach to this. I for one think there is an easier way to handle this than his current set up. |
![]() | | #96 | ![]() |
| Not Ranked : 0 score The wiring for the dodge tb can be made pnp with a adapter, everything is the same, its just the plug that is different.
| The Following 3 Users Say Thank You to 06Speed6 For This Useful Post: |
![]() | | #97 | ![]() |
| Not Ranked : 0 score Do you have links for the plugs that need to be soldered up?
![]() | | #98 | ![]() |
(Thread Starter) | Not Ranked : 0 score not quite. Pablo started testing and there was a problem with the motor voltages on the stock ECU. still some playing around to do but we will get there.
![]() | | #99 | ![]() |
(Thread Starter) | Not Ranked : 0 score so pablo gave me the throttle bodies to test at home. i should be able to dig into this project today and get the ball rolling some more. any chance @Erich would share his wiring with us or if he had to do anything special to make it work other then modifying the ATR tables?
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | Alpha (07-03-2012), TiGraySpeed6 (07-03-2012) |
![]() | | #100 | ![]() |
![]() Join Date: Jul 2009 Location: Sardinia, Ohio
Rep Power: 4725 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,721
Skates, do you have any information on "someone" making this power on a smaller TB? I would be intrigued to have some info on it.
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. | |
| The Following 3 Users Say Thank You to SilverDemon For This Useful Post: |
![]() | | #101 | ![]() |
| Not Ranked : 0 score Just swap out pedal assembly and TB for cable driven one. Kinda like an MBC for boost control
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() | | #102 | ![]() |
| Not Ranked : 0 score If the motor voltages are different by a little bit I am almost certain that there has to be a table or scaler in the ecu that can be tweaked by a volt or two as long as everything else is the same. Of course I dont know but maybe the tps can also be recalibrated. @Ugnius@VersaTune @Steve@VersaTune
| The Following User Says Thank You to 06Speed6 For This Useful Post: | superskaterxes (07-03-2012) |
![]() | | #103 | ![]() |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45885 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
__________________ 2 years after hitting 700hp and still running strong. Happy to see others joining the club. | |
| The Following User Says Thank You to Erich For This Useful Post: | Alpha (07-03-2012) |
![]() | | #104 | ![]() |
(Thread Starter) | Not Ranked : 0 score i suppose that makes sense lol ill try and ring him after work today
![]() | | #105 | ![]() |
(Thread Starter) | Not Ranked : 0 score so @SPEED6 KILLAH and i have been working feverishly on this lately and have made tons of head way. so far we (and by we i mean mostly pablo haha) have figured out that the CX9 TB is too much of a PITA to get working, and the TB that @Erich is using will prob be our best bet. We have also recently discovered the acura TL TB which is ~68mm and almost identically the same bolt pattern as ours. ive ordered the same TB as erich has and will be doing some serious testing when it comes in. for now im going to try and quantify the restriction of the TB by putting my boost gauge pre-TB and using my MAP sensor as a post-TB reference. If i see a huge pressure drop then i will know that the TB is most certainly a restriction. anyone have any comments or suggestions for testing?
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | Boosted Beluga (07-10-2012), dan7225 (07-10-2012) |
![]() | | #106 | ![]() |
| Not Ranked : 0 score That is how I would test it
| The Following 2 Users Say Thank You to 06Speed6 For This Useful Post: | Boosted Beluga (07-10-2012), superskaterxes (07-10-2012) |
![]() | | #107 | ![]() |
They'd have to be pretty damn close to measure a small pressure drop and if you want to be anal...get to identical boost gauges, verify the calibration and test that way.
| The Following User Says Thank You to Dano For This Useful Post: | PapaSmurf (07-10-2012) |
![]() | | #108 | ![]() |
(Thread Starter) | Not Ranked : 0 score so i know my boost gauge and MAP are dead on with eachother @25psi i was only seeing about 1psi more before the TB @30psi it was more like 1.5-2psi but still super minimal. does this sound right? i was hoping for much more conclusive results =(
| The Following User Says Thank You to superskaterxes For This Useful Post: | Lex (07-11-2012) |
![]() | | #109 | ![]() |
| Not Ranked : 0 score Not entirely sure you're gonna get much more accurate without putting it on a bench to flow test. You just need more control over the testing environment, more consistency, or you'll have a hard time repeating results & verifying anything.
![]() | | #110 | ![]() |
![]() Join Date: Apr 2011
| Not Ranked : 0 score anyone happen to have a diagram with the bolt pattern for this hemi TB? or atleast know the spacing between the bolt holes? |
![]() | | #111 | ![]() |
![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,044
Groans: 125
| Not Ranked : 0 score Last edited by TWOptSL0W; 07-11-2012 at 05:56 PM. |
| The Following 7 Users Say Thank You to TWOptSL0W For This Useful Post: | Boosted Beluga (07-12-2012), charlesfist (07-23-2012), djuosnteisn (07-13-2012), NJSPEED3 (07-12-2012), phate (07-11-2012), SPEED6 KILLAH (07-11-2012), superskaterxes (07-12-2012) |
![]() | | #112 | ![]() |
| Not Ranked : 0 score I don't see the TB being a restriction even for the BT guys. Anthony was having more pressure loss across his monstrous intercooler than his throttle body. Remember that it's not just the overall diameter but also the length of pipe involved. The throttle body is relatively short so not much energy will be used going through it.
| The Following 7 Users Say Thank You to Lex For This Useful Post: | charlesfist (07-23-2012), NJSPEED3 (07-12-2012), phate (07-11-2012), SPEED6 KILLAH (07-11-2012), superskaterxes (07-12-2012), TWOptSL0W (07-11-2012), wolly6973 (07-11-2012) |
![]() | | #113 | ![]() |
very true but you have to consider all of the BS between the hotpipe and the TB like tubing bends, the IC itself, ect. my IC is rated to 1000CFM @2psi pressure drop so i doubt you can call it a restriction. the TB is 60mm which is ~2.36" NOT including the TP itself. after u subtract another 15% for that your down to ~2" even. starting at the turbo my pipes are 2.5" to 3" IC in/out to 3" cold pipe to 2" TB. regardless of the length of the TB itself its still a restriction in the grand scheme of things. im going to stay scientific here and do some before after logs along with some SOTP gains reviews and see what i can come up with. as long as i dont loose any drivability theres to reason NOT to upgrade the TB when your shooting for the power i am. we're not talking 450-500 here, my end goal is 600whp on moores dyno and ill be dammed if i dont get it lol. i dont care if i need to do it in the dead of winter and with epic boost, ill get it. P.S. i got my Jeep TB in the mail yesterday and im going to be testing it today if i can rig something up for a spacer and find a coupler that fits.
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | Boosted Beluga (07-12-2012), NJSPEED3 (07-12-2012) |
![]() | | #114 | ![]() |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| Not Ranked : 0 score Just read this entire thing finally. No wonder Pablo's been talking to me about tb's for the past month lol. I think this thread is awesome, one thing we sometimes don't realize is how far behind the ball we are in terms of bolt on upgrades. Most other platforms have various tb upgrades, must be for a reason no? So my hat goes off to you Anthony and Pablo for getting vendors excited about the idea of a new part. 2 things I would like to see. 1. a definitive answer to the limitations of our stock throttle body. 2. what changes must be made to preserve driveability post larger tb? I'll pitch in a few dollars for dyno time when the time comes, so we can compare your stock tb to the one you guys are working with. This should help shed some light on how good or bad the stock tb flows at Anthony's current numbers which are close to 500awhp. |
| The Following 3 Users Say Thank You to NJSPEED3 For This Useful Post: |
![]() | | #115 | ![]() |
| Not Ranked : 0 score I'm still at work, so I cannot search it out. But we had a 2009 ford f150 come in with a 4.6 triton v8 for service. The throttle body has what looks to be the exact same connector something that could be looked into. My guess is it is a 75mm or so. And the bolt patten looks to be the same. |
| The Following 2 Users Say Thank You to pinkcheese For This Useful Post: | Easter Bunny (07-16-2012), Tomas (07-12-2012) |
![]() | | #116 | ![]() |
![]() Join Date: Apr 2010 Location: Elizabeth /NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,623
| The Following User Says Thank You to SPEED6 KILLAH For This Useful Post: | Easter Bunny (07-16-2012) |
![]() | | #117 | ![]() |
| Not Ranked : 0 score is there anything this guy doesn't know.
| The Following 2 Users Say Thank You to Dano For This Useful Post: | jreiden1 (06-14-2013), superskaterxes (07-12-2012) |
![]() | | #118 | ![]() |
| Not Ranked : 0 score Anthony as we discussed this is not about your IC being inefficient, this is about the IC and piping being MORE of a restriction than that TB. So why not go with a super short piping liquid to air IC instead of messing with the TB? No one will tell you when the TB will become a restriction. It is ALWAYS a restriction. Just like the entire intake tract. People rating it based on HP levels is silly and rather random. Look at your entire intake and exhaust tract and start removing the pieces that have the highest pressure drop across them first while keeping in mind the feasibility of doing so. That way you're removing restrictions from largest to smallest.
| The Following 6 Users Say Thank You to Lex For This Useful Post: | charlesfist (07-23-2012), Easter Bunny (07-16-2012), phate (07-12-2012), SPEED6 KILLAH (07-12-2012), superskaterxes (07-12-2012), Tomas (07-12-2012) |
![]() | | #119 | ![]() |
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
| The Following User Says Thank You to cld12pk2go For This Useful Post: | superskaterxes (07-12-2012) |
![]() | | #120 | ![]() |
| Not Ranked : 0 score Damn it... you guys are missing the point... it is bigger, so, it must be better... <-----spoken like a true redneck..hahahahaha
| The Following 5 Users Say Thank You to SilverDemon For This Useful Post: | breakfstincluded (07-12-2012), Dano (07-13-2012), Easter Bunny (07-16-2012), El_Diablo (09-26-2013), ms3blackmica (07-22-2013) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/lets-talk-about-bigger-throttle-bodies-116929/ | ||||
| Throttle body | This thread | Refback | 08-06-2013 09:04 AM | |
| Lets talk fuel pump internals | Javi | Mazdaspeed3/6 General Discussion | 63 | 04-10-2014 04:44 PM |
| Lets talk Compressor AR | superskaterxes | MazdaSpeed 3/6 - Turbo Induction | 16 | 03-30-2012 10:54 AM |
| Lets talk turbo sizing | bf360 | MazdaSpeed 3/6 - Turbo Induction | 23 | 12-17-2009 03:49 PM |
| Lets talk clutches | Death-From-A-Mile | MazdaSpeed 3 - Engine, Transmission & Driveline | 4 | 11-03-2008 08:37 PM |
