 Old 02-21-2017, 04:09 PM   #1
tom10122's Avatar
Posts: 116   (View Stats)
tom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to all
Default Looking at a car that had overboost issues
I'm in the market for a speed6 and I have been talking to a dealer about one they had for a bit. They just got it and noticed an issue with it on the first test drive they had on it (not by me). Originally they said it was misfiring, now they are saying it was overboosting due to a boost control solenoid wire. Exactly how bad is this? The listing says 100% stock and in the pictures it looks stock as well. I'm assuming a compression test is a must. Pretty surprised they told me it wasn't a misfire as overboosting seems worse to me.
tom10122 is offline   Reply With Quote
 Old 02-21-2017, 05:51 PM   #2
sheston's Avatar
Posts: 1,847   (View Stats)
Not sure why a dealer would sell a car with a boost or misfire issue. I assume no warranty and they must have cut the price in half.....
Misfires most of the time aren't bad, but makes you wonder why they didn't fix it if all it took was plugs, coil stretch, etc.
Overboosting could be critical. I would assume in stock form that would lead to bent rods or vented block or ringland failure. All depends on how long, what ambient temperatures, etc. Why didn't they just fix the wire?
 Old 02-21-2017, 06:02 PM   #3
tom10122's Avatar
I should have cleared that up, they did fix it.
 Old 02-21-2017, 06:12 PM   #4
Omega's Avatar
Posts: 441   (View Stats)
As long as compression comes out ok it should be fine, but sounds like it may have other hidden issues.
2006 Super Clean BCM MS6
 Old 02-24-2017, 08:46 PM   #5
tom10122's Avatar
Thanks for the replies! I test drove it and everything seemed fine but they wouldn't come down on price hardly so I'm still looking. Probably for the best as they got it at an auction. First time behind the wheel of one though, definitely have the bug now!
Overboost help? pantlegz 2010 MS3 - Engine, Transmission & Driveline 6 02-11-2016 08:01 AM
Ford issues six recalls covering 101,000 vehicles for multiple issues Haltech Automotive News 0 07-08-2014 01:50 PM
Overboost issues in MS6. AP logs included. Caligula MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 05-23-2012 12:31 PM
Help Overboost!!! bioevolve MazdaSpeed 3/6 - Turbo Induction 17 05-28-2009 09:41 PM
Overboost with log Praelior MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 03-05-2009 08:16 PM
Page generated in 0.26085 seconds with 22 queries
