  • 1 Post By ms6mil
  • 1 Post By Lex
 Old 02-01-2014, 07:03 PM   #1
DO NOT BUY FROM ME!
bigwavedave33's Avatar
Posts: 288   (View Stats)
bigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the world
Default Max boost question
Sorry for the newbie question.
My previous setup: Sure Aeros SRI/Stock TIP/Turbo Smart Dual BOV/ProSport boost gauge/AP V2 with 93 stage one installed. Car ran fine, but I got a good deal on Cobb TIP and SRI. With this setup would boost would raise to 18psi and then drop down to ~15psi.
Swapped for the Cobb TIP/SRI. Car runs great, but boost showing steady 13psi where before it would go a little higher. Would that be normal? Adjust BOV maybe?
bigwavedave33 is offline   Reply With Quote
 Old 02-01-2014, 07:12 PM   #2
tagsung's Avatar
Posts: 139   (View Stats)
tagsung has a reputation beyond reputetagsung has a reputation beyond reputetagsung has a reputation beyond reputetagsung has a reputation beyond reputetagsung has a reputation beyond reputetagsung has a reputation beyond reputetagsung has a reputation beyond reputetagsung has a reputation beyond reputetagsung has a reputation beyond reputetagsung has a reputation beyond reputetagsung has a reputation beyond repute
Groaned at 39 Times in 30 Posts
Do you have internals?
tagsung is offline   Reply With Quote
 Old 02-01-2014, 07:16 PM   #3
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
Post some logs. Are you on the same map after switching intakes?
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
The Following User Says Thank You to ms6mil For This Useful Post:
cshunter (02-01-2014)
 Old 02-01-2014, 07:21 PM   #4
DO NOT BUY FROM ME!
No on the internals
same map after swap. I don't have the AP logging, but I'll figure out how.
Go back to stock map to be safe?
 Old 02-01-2014, 07:29 PM   #5
ms6mil's Avatar
Groans: 307
Typically you want to make sure you are running the map that coincides with the hardware you have in your car. Just locate the map that best fits your setup. visit the how to's for logging, maf cal and WOT calibration. Post up a few logs then we can see where you're at.
The best way to get assistance with ECU/Tuning issues, is to post up logs, logs, logs...
Cezar1113 likes this.
PTE5862 - TBD
The Following 2 Users Say Thank You to ms6mil For This Useful Post:
Agent_Orange (02-02-2014), cshunter (02-01-2014)
 Old 02-01-2014, 07:32 PM   #6
DO NOT BUY FROM ME!
Thanks I'll do a MAF/WOT cal tomorrow and take a look at the how to logging The map I'm using with a change in TIP should not have changed the map. I'll look again tomorrow when I get a chance and then post logs.
 Old 02-01-2014, 07:41 PM   #7
ms6mil's Avatar
Groans: 307
You went from a Sure Aeros which I believe has a 3" maf housing and stock TIH, to a COBB SRI and COBB TIH. (unsure of the maf housing with the COBB)
Different hardware will have different maf scale. Just make sure you are using the map that goes with the COBB SRI/TIH, do the maf cal and wot cal, you should be good as long as there are no other hardware issues.
PTE5862 - TBD
 Old 02-01-2014, 09:28 PM   #8
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
The aeros SRI is OEM diameter.
ms6mil (02-01-2014)
 Old 02-01-2014, 09:34 PM   #9
ms6mil's Avatar
Groans: 307
ah.. thought i read somewhere it was 3"
is it the same size as the COBB? just outta curiosity
PTE5862 - TBD
 Old 02-02-2014, 12:34 AM   #10
sidekick's Avatar
Groans: 47
I believe so. Their 3" intakes have a different name.
 Old 02-02-2014, 01:27 AM   #11
The Cobb intakes are quite large in diameter. So the car should run more boost and not less. This sounds like a different problem such as a boost leak. A maf cal log and wot log will give us a lot more info.
3 Port Boost Control Solenoid / Boost Question Badinfluence MazdaSpeed 3/6 - ECU Computer Tuning 24 06-24-2013 02:59 PM
Snow maf/boost controller boost Line question speed3gen1 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 10-29-2012 07:29 PM
Boost question needforspeed6 MazdaSpeed 3/6 - Turbo Induction 13 08-26-2011 04:37 PM
Boost Question? irishking03 Mazdaspeed3/6 General Discussion 11 01-19-2011 09:45 AM
Boost Question burntRice MazdaSpeed 3/6 - Turbo Induction 8 05-24-2010 08:31 AM
Page generated in 0.31393 seconds with 24 queries
