 Old 04-22-2008, 10:35 AM   #1
BlackMS3's Avatar
Posts: 1,078   (View Stats)
BlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the world
Default Mazda just replaced my Turbo under warranty...
So I just got a call from my dealer, they said Mazda approved the replacement of my turbo under warranty.
I had been experiencing the smoking issue for some time now and when I took it in to the dealer on Saturday, I let it idle for 5-10 mins and it looked like their lot was on fire there was so much smoke....
The tech said there was quite a bit of oil residue in the downpipe and the intake.
YAY for me!
Best to date - 13.802@104.16 (I/MP/MM/W)
BlackMS3 is offline   Reply With Quote
 Old 04-22-2008, 11:13 AM   #2
ikillforfunok's Avatar
Posts: 58   (View Stats)
ikillforfunok has a spectacular aura aboutikillforfunok has a spectacular aura about
Congrats. I have been following your story on DFW. Good to know the evil beeyotch didn't screw you. Feels kinda weird to congratulate someone for needing a new turbo, but hopefully this will help you fall in love with the car again.
ikillforfunok is offline   Reply With Quote
 Old 04-22-2008, 11:24 AM   #3
BlackMS3's Avatar
Yeah, it's ridiculous to be replacing the turbo at all on a car with less than 20K miles... but thankfully it is... it didn't effect the driving from what I could tell, but would have definitely ruined my cat in the long run, if not more.
For the most part it was just embarrassing to smoke like that and it usually always happened in the drive through, or any place where it would be idling for an extended period.. The people in the drive through would always gag and cough and that crap would definitely burn your eyes....
Either way, I'm very glad it's getting fixed and kudos to my dealer for having the turbo shipped overnight so I can pick up the car tomorrow!!
BTW, they are going to do the cdfp flash and check it out as well!!!
I can't wait to get rid of this pathetic Tribute rental and finally get back into something that doesn't take the ENTIRE on-ramp to get up to highway speeds.....(ie 60mph)...
 Old 04-22-2008, 12:49 PM   #4
What are your mods? DP or RP?
 Old 04-22-2008, 01:19 PM   #5
BlackMS3's Avatar
RP....
The Following User Says Thank You to BlackMS3 For This Useful Post:
Haltech (04-22-2008)
 Old 04-22-2008, 05:10 PM   #6
Ain't that the truth about the rentals? I got a regular mazda 6 when I got the fuel pump and flash. Not having torque = teh suck
 Old 04-24-2008, 09:19 AM   #7
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
Lol, you should have went to Town North. I got a CX7 for my rental. Better yet, you wouldn't have had to worry about your mods.
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
 Old 04-24-2008, 09:58 AM   #8
BlackMS3's Avatar
Yeah well.... hindsight is 20/20.....
 Old 04-24-2008, 12:49 PM   #9
SLS MS3's Avatar
End result is all that matters. When do you get back from OK? I think I might actually go out to Denton Raceway with you.
 Old 04-24-2008, 01:05 PM   #10
BlackMS3's Avatar
I pick up the car in an hour... I'm driving straight home and hopping in the expedition for the trip to OK. I'll be back Sunday evening.
So Friday, the 2nd??
 Old 04-24-2008, 03:03 PM   #11
SLS MS3's Avatar
Ok.
 Old 04-24-2008, 05:06 PM   #12
BlackMS3's Avatar
Just got the car back btw....
It's pretty weird... I'm been without it 6 days now and I don't know what it is, but it feel "different" than I remember.....
here's the writeup from the tech:
19024 INTERNAL FAILURE OF THE TURBO CAUSING SMOKE F0008XDX 1.20, F0702BRX 1.50, F0111XRX 3.30, 85, 9W 6.00 TEST DROVE THE VEHICLE AND VERIFY THE CONCERN. PER TECH LINE CK ENGINE COMPRESSION AND INSPECT THE TURBO IMPELLER FOR OIL RESIDUE. THE ENGINE COMPRESSION IS AT 182-184. REPLACE THE TURBO ASSY. REPAIR THE THREADS AT THE O2 SENSOR AND THE DOWN PIPE TO CAT MOUNTING FLANGE. FILL THE ENGINE WITH COOLANT AND TEST DRIVE TO VERIFY THE REPAIRS. CK THE VEHICLE TO VERIFY THERE ARE NO LEAKS.
 Old 04-24-2008, 09:19 PM   #13
You sound concerned. Is it "different" in a bad way? Did they tell you anything about a break-in time?
 Old 04-27-2008, 07:58 PM   #14
BlackMS3's Avatar
I've been gone all weekend with the truck, so I haven't driven it except for the drive home from the dealer.... I'll take it to work tomorrow and see if it still seems a bit weird....
Dealer said nothing about break-in.
 Old 04-29-2008, 07:03 PM   #15
BlackMS3's Avatar
Okay, so I've been driving for a few days now and I can DEFINITELY tell there's something different and I still can't quite put my finger on it....
I'll try and explain what I'm seeing....
So first off, I don't get the grumble backfire at startup I once had... and I no longer get a loud drone when letting off at cruising speed.... now it seems like my whole exhaust is just... well quieter.. this may be due to the flash leaning out the mixture and the richness is now gone.... who knows...
The turbo spool is noticeably different. Not sure how or how to even explain it other than it feels like a "tighter" spool and maybe a bit quicker... maybe the turbo needs to be broke in, I dunno.
The first day and a half, it seemed really sluggish... the weather was cooler, but maybe the ECU needed time to adjust.
Now today with it being about 85 degrees out... I managed to spin through second with traction control crap on... I don't recall doing that before, but my tires are pretty worn out.... so that could be it.
Power still seems to be very temperamental and it seems to change daily... maybe a couple more days driving will give me a different impression, but yeah.
 Old 05-11-2008, 09:38 AM   #16
CMESCOOT's Avatar
Posts: 429   (View Stats)
CMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the world
everybody should take note of this. It's good ammunition if you ever need to take your car in for the turbo seal shit. Don't let the DEALER make decisions that should be made by MazdaUSA
http://active.com/donate/1soldier
Making the world a safer place one Taliban at a time.
Arias 8.8:1 Pistons - Pauter rods - Balance Shaft Delete - ARP Head Studs - Street Unit Rear Motor Mount - TurboXS Hybrid BOV - TurboXS Downpipe - - TurboXS FMIC - CP-E CAI - Custom Built/ported and polished Turbo and Wastegate - CP-E Engine Management - Upgraded high pressure fuel pump - PG Turbo Exhaust manifold - PG Dash mount gauge pod - Cooling Mist Progressive Methanol Injection - Apexi TT - VEI gauges (oil pressure, boost ) - Dashhawk -LaminX Fog lights - H&R Sport Springs - Cobb Rear Sway Bar - Tenzo DC-s wrapped in Nitto InVo's - TWM short throw shifter and bushings
CMESCOOT is offline   Reply With Quote
 Old 08-19-2013, 12:50 PM   #17
mroclimbr's Avatar
Posts: 245   (View Stats)
mroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond repute
Groaned at 30 Times in 14 Posts
I'm getting a new turbo as we speak. I dropped it off last week with all mods in place and the guys never blinked. Hope all will be good.
mroclimbr AEM CAI, OCC, Turbosmart BPV, CP-e turbo downpipe, JBR rsb, JBR 80 duro rmm, 3" CNT CBE, upgraded hpfp, Guardian Angel, JBR heavy knob, Cobb ap, currently stage two on 93 octane, blose speakers and amps all replaced and upgraded, dash daq, full replacement shifter, new ko4 compliments of Mazda at 48k miles.
mroclimbr is offline   Reply With Quote
The Following 2 Users Say NO Thank You to mroclimbr For This Un-useful Post:
2.0t03speed (08-19-2013), El_Diablo (08-19-2013)
 Old 08-19-2013, 12:55 PM   #18
3Gee Tee's Avatar
Posts: 1,533   (View Stats)
Meanwhile, 5 years later...
The Following 3 Users Say Thank You to 3Gee Tee For This Useful Post:
Benis (08-19-2013), PhillyCheese (08-19-2013), Vader (08-19-2013)
 Old 08-19-2013, 01:28 PM   #19
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Holy Necropost Batman!!!
Pickles Tune in progress
 Old 08-19-2013, 06:14 PM   #20
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Well,at least they searched...
Mazda OBD-II Trouble Codes Haltech MazdaSpeed 3/6 - ECU Computer Tuning 9 06-18-2019 05:12 PM
Columbus, OH Mazda Meet EMPIRE Street Racing Stories ( Bench Racing ) 0 04-11-2008 09:13 PM
Is Mazda 3 ECU same as Speed3 ECU Rcimp MazdaSpeed 3/6 - ECU Computer Tuning 8 03-26-2008 06:49 AM
Page generated in 0.37950 seconds with 28 queries
