 Old 03-24-2011, 09:45 AM   #1
starscream's Avatar
Posts: 630   (View Stats)
starscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the world
Groans: 44
Default MS3 Boost Controlling
Was wondering how are people controlling the stock boost system, in the sense that they are controlling spikes?
I been searching last night and this morning and the things that I have seem to come up upon are:
-Stock system is fine, and if its spiking something wrong with the car itself
-Grimspeed EBCS in 2 port mode (does not require tuning) and will stop spiking
-Grimspeed EBCS in 2 port mode BUT will still cause spiking
-Perrin EBCS in 2 port mode but still still cause spiking
-Change wastegates to something that just goes by spring pressure to get your target boost
So I have seen answers all over the map, what works?
FYI I am running a Piasini Tune for 18psi. However sometimes I spike to 20/21psi. I am trying to see what I can do to stop the spiking, if not atleast minimize it.
Can anyone shed some light on this?
starscream is offline   Reply With Quote
The Following User Says Thank You to starscream For This Useful Post:
ak_spray (03-24-2011)
 Old 03-24-2011, 01:21 PM   #2
starscream's Avatar
Groans: 44
Reading more...seems like the Grimspeed may actually work with a stock setup to control spikes.
Anyone confirm this?
 Old 03-24-2011, 06:02 PM   #3
Posts: 2,826   (View Stats)
Don't know about Grimspeed's ability to control the spikes. But I would be reluctant to use an aftermarket solenoid product like that in conjunction with a tune as the two may not work together very well and may be at cross purposes.
I do know one thing which did work for me to control spikes. I was spiking to 21 psi on stock ECU with my catless dp/rp. This was not boost creep. This was momentary, transient spikes when coming up on boost at WOT.
When I went with the Hypertech tune the spikes disappeared while giving me a 19 psi load target and no load cut. I can't say this would work for you. And I know that you would be reluctant to get a different tuning device after having spent money on a tune.
But what this proves is that boost spikes can be tuned out. Maybe whoever did your Piasini tune can customize it to reach the same result? Just a thought . . .
rfinkle2 (03-24-2011)
 Old 03-24-2011, 06:35 PM   #4
I would consult Piasani tuning, or whomever tuned your car for the answer to "tuning" out your spike.
Let them know that you might be interested in utilizing a 3 port solenoid.
wette460 (03-24-2011)
 Old 03-24-2011, 07:52 PM   #5
wette460's Avatar
Posts: 385   (View Stats)
wette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the world
^^2 very wise suggestions...
T3 GTX 3076R .82 a/r, ATP wide-mouth turbo inlet, CPE FMIC, 3.25" MAF custom intake, HKS BPV, Steedspeed T3 Exh. mani, CPE High Output Fuel Pump, Streetunit MM, CP-E side mounts, Mazdaspeed CBE, v-band custom DP, TiAL 38mm EWG, DO stg 2 meth 75/25 w/ do7, 3.5 bar MAP, Cobb AP, TWM solid shifter base bushings, BC racing 32 way adj. coilovers, Mazdaspeed camber links, 18" Bronze Enkei wheels
wette460 is offline   Reply With Quote
 Old 03-24-2011, 08:13 PM   #6
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
since you're already considering buying stuff to fix this:
AP + ATR...tune using boost instead of load. (check the ATR section for how) <done>
The Following User Says Thank You to Sacrilicious For This Useful Post:
Fobio (03-27-2011)
 Old 03-27-2011, 06:37 PM   #7
nosaccordh22's Avatar
Posts: 30   (View Stats)
nosaccordh22 is a jewel in the roughnosaccordh22 is a jewel in the roughnosaccordh22 is a jewel in the roughnosaccordh22 is a jewel in the rough
Groaned at 7 Times in 4 Posts
1)the best way to control boost is via a tune hands down.
2) most research shows boost controllers on these cars don't work too well due to the way the ECU sees boost and interprets the signal, and thus controls fuel/timing/etc.
3) if you're looking on this particular forum for solid info good luck. This is one of the worst sites for legit info
nosaccordh22 is offline   Reply With Quote
The Following 3 Users Say NO Thank You to nosaccordh22 For This Un-useful Post:
ak_spray (03-28-2011), Fobio (03-27-2011), rfinkle2 (03-28-2011)
 Old 03-27-2011, 10:17 PM   #8
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
SS...peep my sig...your answers are all there.
@ next meet, we'll talk cars.
-- Mario Andretti --
The Following User Says Thank You to Fobio For This Useful Post:
MajesticBlueNTO (03-27-2011)
 Old 03-27-2011, 10:22 PM   #9
MajesticBlueNTO's Avatar
Posts: 77   (View Stats)
MajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the worldMajesticBlueNTO is the leader of the world
SS, let me help you out:
DONE . Cobb AP Boost Tuned . Cobb SRI w/ AEM dry-flow . RPMC inlet . Denso ITV-22/24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer . EGR delete . GrimmSpeed EBCS 3-port . PTP WGA . PG v3 CC'd Headers . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM + PTP trans. & kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 Toyo RA1/R888 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 300whp/350wtrq .
SOON . GlowShift 60mm Boost Gauge . 3.25" MAF/Intake/Inlet . GT3071R . NEED . Driver mods . Seat/track time . Brass nuts .
MajesticBlueNTO is offline   Reply With Quote
 Old 03-27-2011, 11:45 PM   #10
pearl_ms3's Avatar
Posts: 545   (View Stats)
pearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the world
Groans: 32
Groaned at 27 Times in 12 Posts
Are u fucking kidding? All my info i have gotten is from this forum. Gtfo 247 is that way. ---------->
You should be able to find ur "legit info" there.
Sent from my SGH-T959V using Tapatalk
CP-E INTAKE W/ AMSOIL FILTER, CP-E INLET, TURBOSMART BOV, DENSO ITV22, AWR RMM, STREET-UNIT TMM & PMM, STEEDSPEED MANI CERAMIC COATED, T3 GT3076, TIAL EWG, CUSTOM V-BAND DOWNPIPE, UR CATTED TESTPIPE, TURBO XS CATBACK EXHAUST, COBB FMIC, CP-E FUEL PUMP, DASHHAWK+CP-E MOUNT, JBARONE SSP, COBB ACCESSPORT STAGE 2 SF 91 FMIC. SELF TUNED WITH 400HP/375TQ @ 21 PSI ON 100 OCTANE.
pearl_ms3 is offline   Reply With Quote
 Old 03-28-2011, 07:21 AM   #11
I disagree with #3. Although every forum has its mistakes, this site is the best place for reliable technical info.
What sites would you suggest that provide better technincal information?
MSMS3 (03-28-2011)
 Old 03-28-2011, 01:58 PM   #12
We may be a rough, tough and roudy crowd. Downright offensive at times. Well, most of the time. We may be intolerant to stupidity. Hell, we are extremely intolerant of stupidity.
But you're not going to find a more knowedgable and experienced group of hard-core enthusiasts for the MS3 and MS6 anywhere on the web. Period. There is more technical know-how here than anywhere else. I might modestly suggest more useful info is here than all the other forums combined.
And if you disagree with me -- go fuck yourself and your homo dick sucking man-bitch! (No offense meant - LOL)
wette460 (03-29-2011)
Porsche's controlling familes meet to chart future Haltech Automotive News 0 07-13-2009 10:30 AM
Porsche's controlling familes meet to chart sports car maker's future Haltech Automotive News 0 07-12-2009 09:20 PM
Controlling boost spike? booya620 MazdaSpeed 3/6 - Turbo Induction 0 10-19-2008 06:32 PM
Ford Considering Selling Controlling Stake in Mazda gamblore Automotive News 5 10-11-2008 05:09 PM
Page generated in 0.32525 seconds with 28 queries
