 Old 06-11-2014, 07:37 PM   #1
Stealthvr4's Avatar
Posts: 84   (View Stats)
Stealthvr4 is a name known to allStealthvr4 is a name known to allStealthvr4 is a name known to allStealthvr4 is a name known to allStealthvr4 is a name known to allStealthvr4 is a name known to all
Default ms6 boost problem...2 psi
My car suddenly cant build boost past 2 psi....ii checked the ic boost elbows and clamps..I checked the vacuum lines at the ebcs and intake... I reflashed my ots 1 map.. still no boost... wastegate duty is 50 % at wot...
Stealthvr4 is offline   Reply With Quote
 Old 06-11-2014, 08:05 PM   #2
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Wastegate might be stuck open. Does the wg actuator and arm look ok? Still hooked up? when did it work last and what did you do since?
MINI H1 6.0 - CAR LED TAILS
 Old 06-11-2014, 08:06 PM   #3
dizzin9's Avatar
Posts: 1,807   (View Stats)
dizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the world
Groans: 77
re-check all connections: BOV, intercooler pipes, TIP, etc.
2008.5 MAZDASPEED3 GT TRUE RED ***GONE***
2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg
Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB
J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19
dizzin9 is offline   Reply With Quote
 Old 06-11-2014, 08:07 PM   #4
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
get a log...
The Following User Says Thank You to mr.speedy3 For This Useful Post:
mxlplx71 (06-14-2014)
 Old 06-11-2014, 09:00 PM   #5
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
Did you do a visual inspection or did you do an actual boost leak test. Always best to start there and rule the obvious out.
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
 Old 06-11-2014, 09:17 PM   #6
Stealthvr4's Avatar
I looked at everything 3 times... 2 weeks ago I installed corksport sri and tip, still needed maf cal but all was well not like this... ill get a log tomorrow afternoon
 Old 06-11-2014, 09:30 PM   #7
GrumpyMPS's Avatar
Posts: 51   (View Stats)
GrumpyMPS has much to be proud ofGrumpyMPS has much to be proud ofGrumpyMPS has much to be proud ofGrumpyMPS has much to be proud ofGrumpyMPS has much to be proud ofGrumpyMPS has much to be proud ofGrumpyMPS has much to be proud ofGrumpyMPS has much to be proud of
Did you hear anything when it "all of a sudden" stop boosting? Sounds like a massive boost leak or the wastegate is not hooked up anymore.
Sent from my GT-I9505 using Tapatalk
Oh and your cat could also have shat itself blocking the exhaust and in turn not allowing the turbo to spool.
2012 VR MPS
BNR S3 and E30 fully bolted. Next up CP-E stage 2 pistons, Manley rods, few other bits and bops, extra fuel, GTX3076R to get it to 500whp............
Last edited by GrumpyMPS; 06-11-2014 at 09:30 PM. Reason: MSF Database - Automerged Doublepost
GrumpyMPS is offline   Reply With Quote
 Old 06-11-2014, 09:37 PM   #8
Stealthvr4's Avatar
How viable is the clogged cat option....
 Old 06-11-2014, 09:38 PM   #9
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
most important thing do you hear it trying to spool or like the turbo is working hard because your turbo could have simply shit the bed
something could have fallen into turbo inlet while you installed blocking flow or touching turbo blades
take the TIP off and reach back there and touch the turbo blades and see if is spins freely or feels rough and grindish feeling and shaft play
 Old 06-11-2014, 09:45 PM   #10
GrumpyMPS's Avatar
Very, can also occur slow where you gradually lose boost. If it is you should hear it when you rev it up.
Texting while driving.........
2012 VR MPS
 Old 06-12-2014, 12:36 AM   #11
Stealthvr4's Avatar
Ill check everything out in the am....
 Old 06-12-2014, 04:56 AM   #12
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
did you suck a paper towel in the intake? That will cause you to get 0 boost and ruin your turbo. Ask me how I know.
The Following 5 Users Say Thank You to maisonvi For This Useful Post:
btstarcher (06-12-2014), dale_gribble (06-14-2014), jm211 (06-12-2014), mxlplx71 (06-14-2014), Stealthvr4 (06-12-2014)
 Old 06-12-2014, 05:17 AM   #13
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Had it happen on my sonoma a few years back. Created enough of a block to stop the truck dead at 80 on the highway....twice. So yeah it's a viable option, and it can be a mess.
Blue Pu.
 Old 06-12-2014, 05:52 AM   #14
Stealthvr4's Avatar
Im thinking it might be a clogged cat.... at 4,500 rpm and up. Sounds like a pressurized poping noise like the exhaust has no where to go
 Old 06-12-2014, 05:57 AM   #15
btstarcher's Avatar
Posts: 4,852   (View Stats)
I'd inspect the turbo before driving it, just in case.
SnailTune in progress
The Following 2 Users Say Thank You to btstarcher For This Useful Post:
maisonvi (06-12-2014), mxlplx71 (06-14-2014)
 Old 06-13-2014, 07:37 PM   #16
Stealthvr4's Avatar
Pulled the top o2 sensor and was able to build 6 psi. So I take it as a clogged cat
 Old 06-14-2014, 01:10 AM   #17
What if the 02 sensor is your problem and not the cat? keep the 02 sensor in but disconnect it to go to a static table instead of live 02 readings and see what happens. By pulling the 02 sensor you exposed it to fresh air and it may have reported something different to the ecm that let it build boost.
I've chased what I thought were clogged cats in other cars and it was never clogged cats. Not common in this platform based on my experience.
 Old 06-14-2014, 01:36 AM   #18
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
no turbo shaft play?
bpv not sticking?
post a log as @mr.speedy3; says
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following User Says Thank You to mxlplx71 For This Useful Post:
mr.speedy3 (06-14-2014)
speed 3 boost problem? jacarper MazdaSpeed 3/6 - Turbo Induction 2 03-28-2014 04:56 AM
Had a boost problem :/ Evolution99 MazdaSpeed 3/6 - Turbo Induction 2 03-29-2013 05:43 PM
Need some ideas for low boost problem zdrpewter01 MazdaSpeed 3/6 - Turbo Induction 3 09-03-2011 03:33 PM
same problem... boost spike LiEast MazdaSpeed 3/6 - ECU Computer Tuning 4 10-11-2009 10:31 AM
sb boost control problem speed_3 MazdaSpeed 3/6 - ECU Computer Tuning 20 07-01-2009 04:53 PM
Page generated in 0.37263 seconds with 30 queries
