 Old 04-13-2016, 05:35 AM   #1
Deri's Avatar
Posts: 2   (View Stats)
Deri is an unknown quantity at this point
Default MS6 Boost stops under 11PSI
Hello,
My car is 2006Mazda6 MPS
Corksport intake and COBB turbo inlet pipe, stock turbo and stock downpipe
Running Cobb stage1+ map Which have boost peak target around 16,5PSI
As i logged some test runs i found that max boost peaks only at 10-11PSI
I live in standard altitude around 300-500 meters above sea level
Also I've checked wastegate actuator which works correctly (no move at 60kPa full open at 110kPa)
and wastegate control solenoid also works (free flow while energized)
Can anyone please help me where can be problem that boost stay that low?
My current map and datalog from accessport are here:
Deri is offline   Reply With Quote
 Old 04-13-2016, 06:48 PM   #2
sheston's Avatar
Posts: 1,847   (View Stats)
I would check for boost leaks. Have you done anything to the car recently?
Your STFT look weird (high) when you are full throttle
We could see more if you post a proper WOT log
 Old 04-14-2016, 03:22 AM   #3
Deri's Avatar
I think that Actual AFR signal looks wierd too it stay stuck on same level and only few times spiked to another level.
Can faulty Front O2 senzor cause that high fuel trim on WOT and then higher WasteGate DutyCycle which can causes lower boost targets?
At 4000rpm WGDC sould be 44,4% and log says that its around 55%
 Old 04-14-2016, 09:19 PM   #4
sheston's Avatar
Sounds like the WGDC is trying to get your boost up by increasing. I'd still say check all your plumbing for loose connections. Intercooler tubes, BPV connections, MAF gasket, etc
Not hitting boost target (~10-11psi) yangx405 2010 MS3 - Turbo Induction 8 08-08-2014 08:05 PM
Bump stops=gone at 44,000 bigmike MazdaSpeed 3/6 - Suspension & Brakes 18 11-19-2013 09:14 PM
Only boosting 10 to 11psi???? MS6Blaze MazdaSpeed 3/6 - Turbo Induction 12 07-18-2012 02:34 PM
Under boost feeling good then stops pulling and I got 3 dtcs. oldognewtriks Mazdaspeed3/6 General Discussion 32 03-21-2012 01:48 PM
Only boosting 11psi Sniper2606 MazdaSpeed 3 - Engine, Transmission & Driveline 12 06-26-2011 11:58 AM
Page generated in 0.24601 seconds with 22 queries
