![]() Join Date: Oct 2011 Location: Secaucus/New Brunswick NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 769
(Thread Starter) | Not Ranked : 0 score Hey guys... If you guys are running a long DP do you have any issues with the downpipe/catback portion of the exhaust sitting lower than the rest? It seems as if mine is sagging and I'm kind of tired dragging my exhaust over every little thing. I am on coilovers and I'm at a 1.5" gap in the front already so I am not ridiculously low. I'll try to grab some pictures of what I am talking about whenever I can tomorrow. I have COBB Poly Exhaust hangers that I'll be putting on in hopes of fixing it but if it doesn't then IDK. Also if you had an ATP DP did you have any issues with the fitment of another catback? The ATP DP that I have didn't want to mate to the CS Catback properly so the flange had to be heated and bent in order for the two to meet up. I'm just hoping to resolve this soon because I plan on adjusting the coils a bit lower during the spring but not if the exhaust is going to drag everywhere, I dont want to rip a hole in either the DP or CBE.
__________________ BMW 335xi 6MT AR Catless Downpipes///HPF Fmic///BMS DCI///CP-e Chargepipe///Cobb AP V2///Volk TE37sl 18x9.5+22F 18x10.5+20R 2007 BM Mazdaspeed 6 GT #10477 SOLD 8/29/14 ![]() |
![]() Join Date: Nov 2011 Location: Alexandria, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 239
| Not Ranked : 0 score i have a m2 dp to stock catback with no sagging issue. Might have to get a exhaust hanger welded on to help it sit a little higher. the dp didnt mate with the catback properly, guessing its becuase of the angle of the flange. I have 4 gaskets on there now to try and prevent the exhaust leak, wouldnt be surprised if it is still there though.
__________________ 07 Speed6 ETS TMIC | HTP 3" Intake | Turboxs Hybrid BOV | JBR RMM | Ralco RZ STS | CP-E Triple Dash Pod | Prosport Gauges | Bilstein HD Shocks | H&R Springs | SPC Adjustable Ball Joints | Corksport Strut Bar | CP-E Diff Mount | Whiteline RSB | Autotech HPFP | Cobb AP V3 | M2 DP | PU Rims | Unicorn Jizz | Rotella T6 Blood Next to come : ??????????? |
| The Following User Says Thank You to almcbs For This Useful Post: | Status Update (03-06-2014) |
| Not Ranked : 0 score It's probably the CS catback. For some reason it dips down right before where it meets the downpipe. I have poly hangers too, they help a little but it's kind of unfixable.
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | Status Update (03-09-2014) |
__________________ BMW 335xi 6MT AR Catless Downpipes///HPF Fmic///BMS DCI///CP-e Chargepipe///Cobb AP V2///Volk TE37sl 18x9.5+22F 18x10.5+20R 2007 BM Mazdaspeed 6 GT #10477 SOLD 8/29/14 ![]() | |
![]() Join Date: Nov 2009 Location: Sterling Heights, Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 6 Times in 2 Posts
| Not Ranked : 0 score I have a full ATP DP & Corksport catback with zero clearance issues.
__________________ 2012 BMW 135i M-Sport |
| The Following User Says Thank You to Dark Lightning For This Useful Post: | Status Update (04-11-2014) |
![]() Join Date: Apr 2012 Location: Austin, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 137
Sent while speeding and swerving.....
__________________ Chad Erwin -ATX 06 MazdaSpeed6 Gt AWD/Turbo/#5994 MODS: COBB AP // MSD Dashhawk // Street Unit TMIC // Street Unit Test Pipe // CorkSport Power Series Catless DP // COBB SRI intake // Speedies TIP // Turbosmart BOV // RPM Street Spring // Bilstein Struts/Shocks // TWM Stage 2 Short Shifter // CPE Dogbone rear mount // CPE JuggerNaught Diff mount // COBB Shifter weight // HPFP Internals // Magnaflow FULL 3IN Back// Denso ITV 22s // Full TIGS // EGR Delete // Shorty Antenna // PA Engineering OCC // LED swap | |
| The Following User Says Thank You to Cheeto For This Useful Post: | Status Update (04-11-2014) |
![]() Join Date: Mar 2012 Location: Bend, Oregon
Rep Power: 670 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,489
Groans: 122
| Not Ranked : 0 score @Status Update; I'm running the ATP catted and a scrape very little only over big speed bumps but the fitment fucking sucks. I have to run like 2-3 gaskets to not leak.
__________________ 2006 BCM Mazdaspeed 6 GT w/navi SOLD Freektune: 400whp/387awtq Mods: Cobb AP, MSD Dashhawk, GT3076r, HTP 3" SRI, FMIC w/ tr8, Wiseco Pistons (9.5:1), Manely Rods, HPFP AutoTech Intenals, NJSPEED3 Ported Intake Manifold w/ VCTS Delete, Turbosmart BPV, Grimspeed 3-Port EBCS, NGK Iridium One Step Colder Plugs, 3.0" ATP Turbo Dowpipe w/ high flow cat, Devil's Own Stage 1 Methanol/Water Injection Kit, 50/50 Methanol, ACT 6 puck sprung w/ streetlite flywheel, Block8head vent pod, Prosport Performance Boost Gauge Amber/White, Cipher Auto Harness Bar, Cipher Auto 4-point Racing Harness, BC Racing Coilovers, CP-E rear diff mount, JBR RMM 80A, SPC Front Adjustable Ball Joints, Enkei Raijin Hypersilver 18x8 +45, 225/45/18 -Autocross Setup- 17x8 +38, BF Goodrich R1 225/45/17 Other Rides: 2006 Mazdaspeed6 GT BCM: 114k miles, never modded (Totaled March 2013) 1969 Ford Ranchero: 351 Windsor, Edelbrock 600cfm, fully re-done interior (w/ Grant steering wheel, '91 T-Bird SC racing bucket seats), C-6 Automatic Trans w/ shifter kit, First, body work, then drag racing and dumping money into it. 1969 Pontiac Firebird: 4:11 gears, 28x10 ET Streets (Middle of restoration with father) 1998 Toyota Tacoma 4x4: 174k miles, 5 speed, Fiberglass Baja Front clip, 2in body lift, 4in suspension lift, 33x10 BFG All-Terrains, Custom Smittybuilt Bumpers, Custom Intake (SOLD) |
| The Following User Says Thank You to rymanmazda For This Useful Post: | Status Update (04-11-2014) |
Sent from my Nexus 5 using Tapatalk 2
Groans: 122
| Not Ranked : 0 score I know I was pissed when I was installing it. But it hasn't cracked and I got it when edge had a sale last year. Plus vband FTW!
![]() Join Date: Mar 2011 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18
| Not Ranked : 0 score ATP DP has Vband?
__________________ '06 Mazdaspeed 6|| Cobb SF & AP Stage 1 | RPM Street Springs | SPC Ball Joints | SU Rear MM | SURE Dread | Whiteline RSB |18x8 Enkei EKM3 w/ 225/40 | JBR SSP & SURE Anchors | Rotora Blanks w/ EBC Red Stuff | 6K HID lights/fogs | V2 Pre-amp | |
| The Following User Says Thank You to Mi06Speed6 For This Useful Post: | rymanmazda (04-11-2014) |
Yep! Sent from my Nexus 5 using Tapatalk 2
| Not Ranked : 0 score I love my Cp-e downpipe. I'm so happy to have ditched my ebay one, it leaked everywhere.
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | Status Update (04-11-2014) |
| MS6 Catback CLEARANCE | www.cp-e.com | Custom Performance Engineering (cp-e.com) | 8 | 01-15-2010 02:22 PM |
| anyone have a downpipe with hks catback? | blackspeedo | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 08-15-2008 10:31 AM |
