![]() Join Date: Feb 2011 Location: Somerset, PA
Rep Power: 145 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 70
Groaned at 3 Times in 1 Post
__________________ 2006 Mazdaspeed 6 - Velocity Red Mica - #5129 - Totaled 2006 Mazdaspeed 6 GT - Titanium Gray Metallic - #3820 |
| Not Ranked : 0 score I don't think there is a full blown wiring schematic in the Mazda shop manual, so you will need to check the wire colors at the map sensor and do some poking around. |
(Thread Starter) | Not Ranked : 0 score I'm pretty sure that's for the MS3. How about for the MS6?
| Not Ranked : 0 score send a PM to sixualpanda, i think he just did this.
| The Following User Says Thank You to superskaterxes For This Useful Post: | nattun (03-14-2011) |
| Not Ranked : 0 score You are correct, it is for the MS3. Since the engines are identical, hardware wise, it will correspond directly to the MS6 sensor location and functionality. I would venture to say even the wire colors are the same between the 3 & 6... |
(Thread Starter) | Not Ranked : 0 score While the engines are the same I dont know if you could say the hardware is. Im pretty sure the MS6 MAP sensor has some orange and brown while Ive red other posts on MS3 MAP clamp installation that talks about green, red, etc.. Can anyone confirm this? By no means am I saying youre wrong... Just trying to figure it out. Thanks for the input as well
![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 189
Groaned at 53 Times in 27 Posts
| Not Ranked : 0 score I had to remove my battery box last night and I couldn't get the connections undone for the ecu. Is there an easy way to do this without breaking anything? There are 2 white brackets that seem to pull up, and I tried doing this but gave up before I broke something else in my car. I ended up unbolting the ecu off the box and moving it out of the way - pain in the ass. Thanks.
__________________ Current Mods: K&N SRI, UR downpipe, UR testpipe, Magnaflow CBE, 3.5" ETS TMIC, Cobb AP(Stage 2 91), cp-e 75 RMM, JBR HSK/SSP/bushings, RA mudflaps, EGR delete, Autotech HPFP Internals, DO stage 2 meth/water kit 50/50 mix,Ford Motorcraft Tranny Fluid |
![]() Join Date: May 2012 Location: Yukon OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 618
| Not Ranked : 0 score @jasper; |
![]() Join Date: Aug 2014
Rep Power: 0 ![]() Thanks: 27
| Not Ranked : 0 score Resurrecting the thread, @nattun did you found it? Or maybe someone can tell me which of all the wire that have the connector is of MAP sensor Thanks |
| location of map sensor | phillyb | MazdaSpeed 3/6 - Turbo Induction | 7 | 04-25-2010 09:30 AM |
| Does Homelink Mirror rain sensor replace OEM rain sensor? | Chinsel | MazdaSpeed 3/6 - Car Audio & Electronics | 5 | 02-25-2010 11:36 AM |
| Knock sensor location and logging | GQ_WhiteMS3 | MazdaSpeed 3/6 - ECU Computer Tuning | 0 | 08-23-2009 08:12 PM |
| Coolant in Oil, Wiring Problem in Chevy Cobalt, Cruise Control Complaint with Toyota Prius, Changing An O2 Sensor, Heate | Haltech | Automotive News | 0 | 03-10-2009 03:10 PM |
| Horn location help | Tomas | MazdaSpeed 3 - How-To's | 5 | 02-22-2009 09:10 PM |
