Mazdaspeed Forums
-   -   Ms6 tr8 mounting (http://www.mazdaspeedforum.org/forum/forum/f11/mazdaspeed-6-tr8-mounting-220076/)
slowspeed6 02-03-2019 06:48 PM
Ms6 tr8 mounting
I've done alot of searching on Google and am only finding ms3 fmic mounting options. If there's a post on it I missed can someone point me in that direction? If not what are you guys using to mount the tr8 on your mazdaspeed 6?
nindoja 02-04-2019 09:18 AM
The reason you don't see it for the 6 is because you have to either cut the crash bar or buy a custom one (not sure if anyone still makes crash bars for the 6). Steps below for the oem bar.
1) Cut OEM crash bar because otherwise you can't clear it
2) Buy flat stock at Home Depot (or similar)
3) Bend flat stock
4) Use self taping screws to mount flat stock to OEM bar
5) Drill hole in the right spot for the bolt hole on the TR8 core.
Thor Hammer 02-04-2019 10:41 AM
Quote:
Treadstone makes an FMIC kit with mount that does not require cutting the crash bar. What piping are you running? The CX kit works, but doesn't fit all that well.
Page generated in 0.16995 seconds with 11 queries
