 Old 05-20-2008, 11:14 PM   #1
det_ms3's Avatar
Posts: 479   (View Stats)
det_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the world
Default mbc install question
anyone completely bypassing the stock solenoid? if so do you have a how to?
2008 Sunlight Silver MS3 the toy
2012 Chrysler 200 Limited 3.6l the daily driver
det_ms3 is offline   Reply With Quote
 Old 05-21-2008, 12:19 AM   #2
shucky's Avatar
Posts: 198   (View Stats)
shucky is a name known to allshucky is a name known to allshucky is a name known to allshucky is a name known to allshucky is a name known to allshucky is a name known to all
Groaned at 9 Times in 7 Posts
Take hose from top of wastegate and pull off. Follow that to stock solenoid and pull off from there. Use vacuum caps and cap both of those. Fatter hose on bottom of wastegate, pull off, follow it to the turbo (only a few inches) and remove. You'll need 2 pieces of new hose. Attach one to the bottom of the wastegate, and the other to the nipple on the turbo where you removed the fatter bottom wastegate line from. Connect these to proper ports on your MBC.
There is a write up from Laloosh on 247 regarding above.
I am running mine inline with the factory solenoid (with help from loosh) and it works great and is much easier. Remove hose on top of wastegate (from wastegate and solenoid). Run new line from MBC to top of wastegate and another new line from MBC to solenoid. Done.
Its really tight in there, my hands are still f'd up. Really can only get 1 hand in there unless your a midget or mutant. Good luck. And thanks to loosh as always for his help!
shucky is offline   Reply With Quote
 Old 05-21-2008, 12:34 AM   #3
det_ms3's Avatar
m
 Old 05-21-2008, 12:46 AM   #4
shucky's Avatar
ah, you broke the nipple on the stock solenoid? sucks ...
 Old 05-21-2008, 05:23 PM   #5
det_ms3's Avatar
m
 Old 05-21-2008, 05:36 PM   #6
How the hell did you break the nipple off?
 Old 05-21-2008, 05:49 PM   #7
det_ms3's Avatar
m
 Old 05-22-2008, 11:59 AM   #8
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
hmm cool
 Old 05-22-2008, 07:08 AM   #9
det_ms3's Avatar
anyone got ideas?
 Old 05-22-2008, 07:22 AM   #10
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
whoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the world
Groaned at 39 Times in 23 Posts
Originally Posted by det_ms3 View Post
anyone got ideas?
what ideas do you need?
disconnect the OEM solenoid and throw it away
follow the simple MBC instructions
add a map clamp or BCD and your car will run better than it ever has
that is as long as you know how to adjust the MBC and your MBC is not cheap junk
the other option is to talk to Jason at onlinemazdaparts.com and get a new solenoid shipped to you for about 60 bucks
2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008)
2008 Caliber SRT4 / 11.8 @ 120
whoosh@Realtune is offline   Reply With Quote
The Following User Says Thank You to whoosh@Realtune For This Useful Post:
det_ms3 (05-22-2008)
 Old 05-22-2008, 11:17 AM   #11
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
I thought people ran into problems running a MBC in line with the factory solenoid.
13.2@111
CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
Originally Posted by rodrigo View Post
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline   Reply With Quote
 Old 05-22-2008, 12:24 PM   #12
LBV
LBV's Avatar
Posts: 700   (View Stats)
LBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond repute
Those nipples are damn fragile! I broke the outside 1 but just cut the thing off and connected the hose to the end. So instead of having the 2 hoses sticking up, you've got 1 up and 1 sideways.
Try that.
LBV is offline   Reply With Quote
The Following User Says Thank You to LBV For This Useful Post:
 Old 05-22-2008, 12:27 PM   #13
LBV
LBV's Avatar
Shucky - With your MBC inline with the thinner solenoid hose, how does the boost behave? Is basically like the stock curve except 1 or 2 psi higher?
 Old 05-23-2008, 09:40 AM   #14
shucky's Avatar
I guess it behaves like well, ... a MBC should. I haven't tried bypassing the stock solenoid so I cant compare. W/out a map clamp the ECU would resort to reducing whatever boost
you dialed up to keep within stock parameters. With a map clamp (which I have) there is no issue whatsoever. With the Turbosmart MBC there really isn't a "boost spike." Floor it and boost goes to whatever you set (depending on load), and gradually drops as rpm's increase. Does not have the "on/off" feeling others have reported with other mbc's. Set at 18psi, if I floor it in second gear around 3000 rpm I get about 16psi which charges hard. Haven't tested 1st gear. 3rd gear 18psi, 4th 18psi, falling as rpms increase to about 15. Haven't tried 5th or 6th. Set at 21psi, it holds about 16-17 psi up to 6000 or so rpm. The upgraded cdfp helps keep throttle open which is why this setup holds a bit more boost through the run. Laloosh has run it both ways (bypassed and inline) and he told me there was no difference that he noticed and runs it currently inline.
 Old 05-23-2008, 10:04 AM   #15
LBV
LBV's Avatar
Thx - I think that's what I wanna try. I really don't think it's a good idea holding peak boost 'til redline and the more I hear about blown motors the more I wanna just take the stock boost & AFR curves and just move them up a bit.
2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual.
 Old 05-23-2008, 03:03 PM   #16
ms3jake's Avatar
Posts: 695   (View Stats)
ms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the world
If you know what your doing, how long should it take to install a mbc?
ms3jake is offline   Reply With Quote
 Old 05-23-2008, 03:25 PM   #17
SgtP's Avatar
Groans: 106
20-30 min depending on your hand size.
13.2@111
Sponsored By: CP-E
 Old 05-28-2008, 08:04 PM   #18
det_ms3's Avatar
m
 Old 05-28-2008, 08:05 PM   #19
det_ms3's Avatar
m
 Old 05-28-2008, 10:53 PM   #20
det_ms3's Avatar
m
 Old 05-29-2008, 07:54 AM   #21
shucky's Avatar
what mbc do you have? And there is no point of installing a mbc w/out a map clamp. Especially in line with the factory solenoid. The stock ECU will do everything it can to reduce any boost increase you added with the mbc. You need a map clamp.
 Old 05-29-2008, 11:26 AM   #22
det_ms3's Avatar
m
 Old 05-29-2008, 12:08 PM   #23
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
does the TXS mbc work fine with our cars??? I would get the turbosmart (if i go this route), as it seems to work good for everyone, but I have a local buddy who has a turboxs one laying around. I think its like this one
StreetUnit.com - MAZDASPEED SPECIALISTS
 Old 05-29-2008, 12:18 PM   #24
94jedi's Avatar
Posts: 2,200   (View Stats)
94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world
Groaned at 7 Times in 5 Posts
Hey aaron, try it out and pm me your results. So you'll be Stg2+ and MBC/MAP Clamp at 18psi? Your car is going to be a gorilla on pcp!
94jedi is offline   Reply With Quote
 Old 05-29-2008, 12:27 PM   #25
mrlilguy157's Avatar
Posts: 606   (View Stats)
mrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the world
ive got a boost solenoid if you want it.
$50 shipped
Black Mica '07 Mazdaspeed3
Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing
Reppin' ProtegeGarage for life!
mrlilguy157 is offline   Reply With Quote
 Old 05-29-2008, 12:30 PM   #26
aaronc7's Avatar
Groans: 370
I was considering sending the AP back if things dont work out and just go mbc/map clamp route at 18psi. Is there a real advantage of running the stage 2 maps with mbc over just upping the boost really? With the AP i run a bit richer which might be good to keep things safe, but i dont know what i'll be at with just mbc...it may be just fine, i'd just have to see for myself when i get there. It's already not running right with just stage 2 I have a feeling upping the boost wont solve it .
Not to get it off topic but right now I'm just waiting on step colder plugs and gonna see what happens from there. Getting FMIC next week and sways tomorrow! woot. My friend just got a bunch of mods for his car that I helped install and I couldnt help it anymore I just had to splurge.
 Old 05-30-2008, 10:05 AM   #27
shucky's Avatar
I've read the unos mbc spikes high and doesn't work well on these cars. I have the turbosmart myself and it works great. Right now, I think the AP is causing more issues than its worth. Until the bugs are ironed out I would return it and run a map clamp and mbc. I think you'll be surprised <no issues, no stuttering, no knock, afr's in check + a big grin on your face>
 Old 05-30-2008, 10:11 AM   #28
aaronc7's Avatar
Groans: 370
18 psi? what do you have the map clamped to? 15ish?
 Old 06-03-2008, 12:51 PM   #29
shucky's Avatar
Aaron you asking me? My clamp is set at 3.2 volts (10.5psi). I haven't experimented with raising the clamping voltage yet.
 Old 06-03-2008, 07:59 PM   #30
LBV
LBV's Avatar
Where do you get a boost clamp anyway?
 Old 06-04-2008, 07:56 AM   #31
shucky's Avatar
splitsec.com (vc2.5)
AEM CAI install HELP djchris721 MazdaSpeed 3 - How-To's 31 05-14-2010 01:23 PM
Really, REALLY Stupid CAI Install Question div2 MazdaSpeed 3 - Engine, Transmission & Driveline 17 03-04-2010 05:37 PM
Question about TXS FMIC Derek88 MazdaSpeed 3/6 - Turbo Induction 12 04-10-2008 08:24 PM
question for driver311? bombdotcom MazdaSpeed 3/6 - Turbo Induction 8 03-31-2008 06:13 PM
Page generated in 0.47320 seconds with 30 queries
