 Old 04-22-2008, 07:02 PM   #1
Ghetto Mods's Avatar
Posts: 52   (View Stats)
Ghetto Mods is an unknown quantity at this point
Default MBC Installation How To
Was reading Laloosh's MBC install guide over on the 24/7 forums and have a question:
I understand why the LOWER wastegate hose needs to be removed (this is where the MBC is installed) since that's what bleeds the pressure off to the WG allowing higher boost.
But, I can't understand why it's necessary to remove the UPPER wastegate hose that runs to the solenoid and cap those items.
Can somebody explain to me what that other hose is for?
Thanks!!
Mr. GMAC (Ghetto Mods Always Clueless)
All your boost are belong to us.
Ghetto Mods is offline   Reply With Quote
 Old 04-23-2008, 01:30 PM   #2
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
if you dont cap them off the boost will still get up to the factory boost solenoid. that will still give the car some control of boost. it can also cuase HUGE boost spike if both boost controlers attempt to bleed boost at the same time. REMOVE ans cap it..... trust me !
TRU-BOOST is offline   Reply With Quote
 Old 04-23-2008, 05:51 PM   #3
Thanks for the education.
Hmm, wonder if that's the problem some folks are having with big boost spikes over on the douchebag forum.
O.K. one more:
MAP clamp vs. MAP bleeder valve - big advantage to the MAP?
I ask b/c I have the MAP bleeder (fuel cut defender or whatever it's called) already installed and I need a damn good reason before I go snaking my hand back in there again to unbolt that little PITA.
 Old 04-24-2008, 11:16 AM   #4
TRU-BOOST's Avatar
on the protege garage MS6 they showed a huge advantage on top end power using an electronic method to stop fuel cut. the FCD bleeds out hard earned boost on an already over worked turbo. the result of bleeding boost is a drastic loss of HP over 5k rpm.
 Old 04-24-2008, 02:57 PM   #5
Thanks! I wouldn't think that tiny little pinhole would cost much boost, but results don't lie.
Where on eBay did you get your MAP clamp?
 Old 04-25-2008, 11:52 AM   #6
O.K. I have a MAP clamp on order and a Turbo Tee also FTW.
Now back to installation, now that I've done more homework, what about connecting the boost tee to the top of the WGA and capping the other end?
I believe this would have the same effect as attaching to the bottom of the WGA and capping the outlet of the WGA, but places the MBC in a more accessible position.
Tru-Boost - your thoughts on this?
 Old 04-25-2008, 07:49 PM   #7
TRU-BOOST's Avatar
it would work from either WGA port but it must come from the turbo nipple to the WGA. so, since you have to remove the lower hose that connects to the turbo, you may as well put it there IMO. if you left the lower hose connected as it is and connected the top WGA port to the WGA, where would the other end of the MBC go ?? you cant just leave it open or bleed it into the intake like the stock electronic solenoid does. it must connect from a boost source then to the WGA.
Fuel Pump Installation Guide 3/08 mrlilguy157 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 11 09-27-2012 08:49 PM
Panasonic TH-42PX80U 42 inch Plasma HDTV w/ In-Home Installation $799.99 Free Shipping Haltech Hot Deals Section 0 04-07-2008 01:20 PM
Page generated in 0.26802 seconds with 21 queries
