![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
(Thread Starter) | Not Ranked : 0 score Initial Impressions: The Gauge Display on ATR does not update fast enough to really catch spool, even though the dyno was loading me less than the street and I was spooling slower than normal. The go-pro was running @ 60fps, and it was ~6 frames between updates on the computer, which makes me doubt what the latency really is. Seems like the pressure differential really starts to grow at the 3900RPM, going from a fairly constant -3.5PSI to -6.8PSI and then again jumping at the 4130 point to -10.28PSI. Unfortunately I don't have data to redline because of a CAI + rain + MAF issue. But its clear that at 4000RPM the backpressure is already growing substantially, requiring negative cam overlap to combat reversion. It also appears that with this turbo, you never really get out of the negative pressure differential zone where you would want overlap for scavenging. I wouldn't expect results for an ATP GT30 series turbo to be much different as the hotsides are comparable and the exhaust wheel isn't THAT much bigger. Probably follows the same curve with just a few PSI difference, but until one is measured its up in the air. Corresponding log attached. You can see in the last line the MAF railed out, and AFRs going super rich. My suspicion being that water was getting on it, causing it to cool abnormally, supported by the fact that when the MAF sensor was removed it was covered in water.... 10PSI Backpressure, 6.5PSI Boost, 2768RPM 15 Psi Backpressure, 11.6PSI Boost, 3227RPM 20 Psi Backpressue, 16.33PSI Boost, 3553RPM 25 Psi Backpressure, 18.2PSI Boost, 3900RPM 30 Psi Backpressure, 19.72PSI Boost, 4130RPM
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk Last edited by Ziggo; 06-08-2012 at 08:33 PM. |
| The Following 22 Users Say Thank You to Ziggo For This Useful Post: | 06Speed6 (06-09-2012), atvfreek (06-11-2012), AZSPEED3 (06-10-2012), BlueStreak (02-16-2013), cld12pk2go (06-21-2012), Dano (06-10-2012), Dash08 (06-10-2012), djuosnteisn (06-11-2012), Dmurray06 (06-08-2012), Easter Bunny (06-08-2012), EdgeAutosport.com (06-11-2012), JacksonMS30 (06-11-2012), Lex (06-08-2012), MPSdriver (06-10-2012), ms3blackmica (04-24-2013), rfinkle2 (06-08-2012), Sid3wayS (06-11-2012), silvapain (06-10-2012), skeurton (06-08-2012), Tomas (06-08-2012), torquemaniac (04-06-2016), vrspeed10 (07-26-2012) |
(Thread Starter) | Not Ranked : 0 score Post reserved for same measurements with JBR 3.5" SRI
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
| The Following User Says Thank You to Ziggo For This Useful Post: | rfinkle2 (06-08-2012) |
| Not Ranked : 0 score Where were you taking the measurement?
| The Following User Says Thank You to Lex For This Useful Post: | Ziggo (06-08-2012) |
| Not Ranked : 0 score im going to tackle this next week. you peaked my curiosity but i believe your measurements are somewhat skewed because you should have your largest pressure right at peak spool/tq where the turbo is trying to overcome its inertia to spool. once it spools and the air is flowing free-er through the turbine/wg the pressure should subside or atleast not grow as a linear rate.
| The Following User Says Thank You to superskaterxes For This Useful Post: | Ziggo (06-08-2012) |
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk | |
im interested to see how my much larger turbine wheel on the smaller ATP housing will perform.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
(Thread Starter) | Not Ranked : 0 score Yeah I have no idea what the profile will look like. I certainly hope it does not continue to climb at such a high rate, after it reaches full spool hopefully it will increase at a much more linear rate.
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 2281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,142
Groans: 324
| Not Ranked : 0 score |
| Not Ranked : 0 score So that's just a standard differential pressure gauge measuring pressure at turbine inlet WRT atmosphere correct?
Zigatapatalka
| Not Ranked : 0 score There isn't much you can do about the size of the turbine but I wonder how much backpressure the turbo-back is adding. It would be very cool if you put that gauge post turbine so that you knew how much the turbine contributes versus the rest of the exhaust.
| The Following 2 Users Say Thank You to Lex For This Useful Post: | Dash08 (06-10-2012), Easter Bunny (06-10-2012) |
| Not Ranked : 0 score I'd be surprised to see more than 2-3 psi post turbo pressure on the exhaust at red line. To flip the video 180* get windows live movie maker here. http://windows.microsoft.com/en-US/w...es/movie-maker
__________________ Last edited by Tomas; 06-09-2012 at 01:15 PM. |
I tried to pull the second 02 bung out to verify threads but that sucker is seized in there. and its in a spot I cant use a deadblow. Sprayed some PB on it and I'll try again later. Considering buying something like this Since I don't think the tire pressure gauge has fine enough resolution to make it work and some brief shopping has a 0-15psi gauge alone running $30 S And G Tool Aid , 33600 Exhaust Back Pressure Tester
| The Following User Says Thank You to Ziggo For This Useful Post: | djuosnteisn (06-11-2012) |
| Not Ranked : 0 score Or just pull the exhaust off and measure in the same spot
| The Following User Says Thank You to Lex For This Useful Post: | Mizzle (06-10-2012) |
Groans: 324
(Thread Starter) | Not Ranked : 0 score Thx for the suggestion, but the car is actually in-operable right now while I modify a couple pipes for the 5th port.
Groans: 136
| Not Ranked : 0 score Sounds like the BNR S3 needs a larger A/R @Ziggo.
__________________ |
Groans: 324
| I <3 your mom ![]() ![]() Join Date: Jul 2008 Location: Long Beach, CA.
Rep Power: 14358 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,316
Groans: 293
| Not Ranked : 0 score Subbed for results of further testing. This is very interesting. |
@Tomas the link you sent me only works for windows 7. I looked around for an xp version but couldn't find one. Windows movie maker doesn't process .mp4s The videos are not really worth it anyway. Just quick pulls and @JacksonMS30 telling the dyno operator all about @djuosnteisn methlocking his motor.
| The Following 4 Users Say Thank You to Ziggo For This Useful Post: |
Groans: 136
| Not Ranked : 0 score I'm not up to speed on those BNRs... are they stock turbine? What actually is the A/R?
I measured it before at .57 or so. Not the most exact measurement, but I trust it to within .05, which makes it roughly comparable to the ATP housings.
| The Following 5 Users Say Thank You to Ziggo For This Useful Post: | atvfreek (06-11-2012), Dano (06-11-2012), djuosnteisn (06-11-2012), silvapain (06-10-2012), Tomas (06-10-2012) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score A nice conical port job on the housing right after the turbine could yield some improvements. I am very curious how well an aftermarket high flow cat flows versus the OEM which has a much larger cross section but probably offers more restriction.
![]() | | #25 | ![]() |
is this correct?
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
| The Following User Says Thank You to Dano For This Useful Post: | silvapain (06-11-2012) |
![]() | | #26 | ![]() |
| Approved MSF Vendor ![]() Join Date: Sep 2011 Location: Denver Colorado
Rep Power: 5796 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,830
| Not Ranked : 0 score Yes .55 sounds correct, ATP has told me at one point or another it was .72 but I dont think the lady knew what she was talking about lol |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | Dano (06-11-2012) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score LoL @ .72 AR...I wish.....well maybe I don't...how about .64 just to keep things exciting and responsive for a 53.85mm turbine wheel.
![]() | | #28 | ![]() |
| Not Ranked : 0 score Ziggo, if your going to measure the exhaust restriction, you should try to measure it as close as possible to the turbine outlet. The 2nd o2 sensor will be a ways away, and may only show like 2/3 what the actual pressure is presented to the turbine outlet. PITA, but i suppose we could just infer what it would be by the length of pipe before and after the spot you measure it. That would probably be close enough. Great testing man!
![]() | | #29 | ![]() |
A third sensor post cat in the stock narrowband would be interesting, but I doubt it's more than 1psi at that point and I think I would need an expensive gauge to measure that accurately. It would really just be an engineering exercise to see exactly how much backpressure a high flow cat adds to the system. Zigatapatalka
![]() | | #30 | ![]() |
| Not Ranked : 0 score Ah, perfect. Yea, i thought you were using the narrow band o2 bung. Eager to see results so we can see what kind of pressure ratio there is across that hot side.
![]() | | #31 | ![]() |
![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score When boost pressure > exhaust pressure = crossover and you can really take advantage of cam overlap. Small 4 cyl acts like large NA V10 . That's how 1.6L 4cyl make 1000hp. But only for 2000RPM ![]() 2 to 1 crossover ratio is Heaven like the F1 cars of the 80s
__________________ 2009 MS3 Cpe nano, dashhawk, turboxs fmic, cpe rmm, AP stage 1+ fmic, Cobb tip |
| exhaust manifold? | tbone | MazdaSpeed 3/6 - Turbo Induction | 14 | 04-30-2009 12:52 AM |
| What is your manifold pressure at idle? | florindi | Cobb Access Port/Maps | 3 | 02-19-2009 07:37 PM |
| Exhaust Manifold | speed3wannabe | Mazdaspeed3/6 General Discussion | 22 | 04-08-2008 08:52 AM |
