Like Tree57Likes
 Old 11-14-2012, 01:26 PM   #1
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Default Mitsubishi turbochargers & the mazdaspeed....
So i was looking at my junk turbo collection in the garage the other day and found an old gt2860 I have had for a while. I also stumbled upon an old stock subaru mitsubishi turbo too. I was eyeballing them and the wheels in my head began turning. I was bored the last few days at work so I designed a set of flanges to make a garrett t25/28 flange bolt up to a stock mazdaspeed manifold. I also designed the correct amount of offset to put the oil and coolant feeds in the correct spot to be used on the speed with minimal modification. I also designed an adapter flange for the downpipe which would allow you to bolt up a mazdaspeed downpipe to the T28 turbo.
The biggest I could go with this exhaust housing is a 2876 or 3076, but at the cost of those turbos + the fact that the garrett has different threads and locations for the oil / coolant lines, It would be about the same money to buy a ms specific turbo from atp, and therefore not worth the conversion flanges being used.
Now on to the subaru/mitsu turbo.... I was thinking of maybe using a td06 20g turbo as it would supply about 43 lb's a minute which should easily get me to my 350whp goal. I designed a set of flanges for it as well, but determined that it wouldn't work as a bolt on solution. Alignment and fitment would have been terrible.
I did however notice that the mitsubishi turbo chra's use the same thread pattern as the k04 and the oil return line flange is the same... Got me thinking... You can purchase a t28 turbine housing that is made to accept a mitsubishi td06sl2 chra. You can put either a 20G or a 25G compressor housing on the other side.
So if i get everything right I can have a decent journal bearing mitsubishi td06 20g for about $900 with the flanges and it will for the most part bolt right on. td06sl2 20g will make 430 crank hp if properly supported. Clip the turbine wheel and use a 25g compressor and wheel and possibly get 48-50lb/min out of one, but the smaller sl2 turbine will be the limiting factor.
I am going to be making some mock up flanges and see if everything fits using the gt2860 I have. I might be on to a less expensive but still good alternative to an atp turbo.
So far this is just an idea coming from my boredom. Am I crazy, or is this worthwhile to pursue? Let me know what you think!!! Oh, and I know the stock manifold sucks, but I am trying to come up with a low cost bolt on option here.
Renderings Below.
Flange
Studs top And bottom
And the downpipe adapter
Koke382 likes this.
Soon to come.
WHO KNOWS? A.D.D. FTW!
The Following 34 Users Say Thank You to Turbo_Steve For This Useful Post:
06Speed6 (11-15-2012), ABolewski (11-15-2012), AJ713 (11-14-2012), amggilly305 (02-06-2013), brandon3212 (11-24-2014), btstarcher (09-17-2013), cbspd3flip (11-14-2012), chuckms6 (11-14-2012), Constantin (11-19-2012), Dahouse702 (11-14-2012), El_Diablo (02-22-2013), forcedinduktion (11-14-2012), GartzSpeed (11-14-2012), J'sSpeed3 (11-14-2012), jack_hammer (11-15-2012), Jh8909 (11-14-2012), Koke382 (09-26-2013), leon78 (11-14-2012), MD1032 (05-10-2015), MS3-a(sore)ASS-rex (11-14-2012), Ms3_Miami (02-22-2013), mxlplx71 (11-14-2012), Roddiy (11-14-2012), SC08Speed3 (11-14-2012), SofaKingAwesome (11-27-2012), Speed3eak (11-14-2012), SpeedLife (11-13-2013), Tibu (11-14-2012), Tokay444 (11-18-2012), Tomas (11-14-2012), Twinturbo6 (03-06-2013), uncorked11 (11-14-2012), Voltwings (11-14-2012), xI Leveler Ix (11-14-2012)
 Old 11-14-2012, 01:31 PM   #2
93silvergt's Avatar
Posts: 554   (View Stats)
93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world
Groaned at 18 Times in 11 Posts
pretty cool research you've done! I like the initiative and the creativity.
2009 Mazdaspeed3 GT
Cobb SRI E4P Short Throw shifter
93silvergt is offline   Reply With Quote
The Following User Says Thank You to 93silvergt For This Useful Post:
 Old 11-14-2012, 01:37 PM   #3
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
I'd be interested in seeing you use the mitsu turbo honestly, but I think the idea of using an adapter flange for the DP is going to cause some clearance issues with the downpipe downstream of the turbo.
07 MS3
The original Genpoo Hater
helmetface (11-14-2012)
 Old 11-14-2012, 01:41 PM   #4
I also am in the process of drawing up a flange for a 1g dsm turbine housing, but it would require a custom downpipe. You could run a bigger turbine wheel and a 25g compressor and make 400+ whp easily with this setup. And the beauty is you could run an external wastegate on a stock manifold or stock style manifold as the wastegate is divorced on the 1g dsm. Just remove the flapper and port the housing. But again, may be pointless.
Soon to come.
 Old 11-14-2012, 02:07 PM   #5
Voltwings's Avatar
Posts: 3,713   (View Stats)
Im not a normal 247 browser, i just remember coming across this in my turbo research. It may be something you've already seen but im just playing the devils advocate and wanting to make sure you have your bases covered. Good Luck
Posts 24 and 32.
MS3 Mitsubishi 20G turbo project - Page 3
This is from like 07-08 so it could very well be an outdated issue, but still, just wanna make sure you dont ZZB haha.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 11-14-2012, 02:35 PM   #6
Posts 24 and 32.
Ya, found this too. Someone put a bigger turbo on his car and blew up in 2008.....
Thanks.
Soon to come.
The Following User Says Thank You to Turbo_Steve For This Useful Post:
 Old 11-14-2012, 02:44 PM   #7
Voltwings's Avatar
the point that caught my eye was apparently how fast the 20G seemd to spool on this platform. Fueling "may" have been the issue, but i have seen evos with 20g's move, and we have a 2.3L. I dont doubt that things capable of some serious low end grunt, but hell with all the breakthroughs Cobb has had recently, we can tune for damn near anything.
Past:
-Sold-
-Sold-
Current:
 Old 11-14-2012, 02:57 PM   #8
Search for posts on here by "cageyvet" He blew his motor on the stock k04. Never put the 20g on it.
I know you are just trying to help out. Thanks.
How are the mitsu turbos for reliability and availability?
Mitsubishi turbos are known to be very reliable. And easily rebuildable if need be. You can source tons of parts online from various reputable suppliers.
Soon to come.
Last edited by Turbo_Steve; 11-14-2012 at 02:58 PM. Reason: MSF Database - Automerged Doublepost
The Following 3 Users Say Thank You to Turbo_Steve For This Useful Post:
Chimmike (11-14-2012), Lex (11-14-2012), Tokay444 (11-18-2012)
 Old 11-14-2012, 01:58 PM   #9
manila's Avatar
Posts: 1,767   (View Stats)
Subb'd. OP keep us updated
'12 MS3 Black Mica w/ Tech
 Old 11-14-2012, 02:33 PM   #10
 Old 11-14-2012, 03:33 PM   #11
vroom4's Avatar
Posts: 145   (View Stats)
vroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond repute
Groaned at 8 Times in 3 Posts
The 20g is kind of outdated isnt it? I would think one of the more modern turbos would be better.
vroom4 is offline   Reply With Quote
 Old 11-14-2012, 03:39 PM   #12
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
A buddy of mine with a ford Focus did this. He had a exhaust shop modify his Exhaust Mani to fit a mitsu Evo turbo. Worked well till he blew the motor lol.
The Following 3 Users Say Thank You to crazyp For This Useful Post:
06Speed6 (11-15-2012), atvfreek (11-14-2012), Speed_j23 (11-14-2012)
 Old 11-14-2012, 03:46 PM   #13
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Please do this!
I'd love to use the T25's, 14b's, 16g's, 18g's and 20g's I have laying around my house. Lol
NATOR PA
The Following 2 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
 Old 11-13-2013, 09:26 AM   #14
heisenburg's Avatar
Posts: 357   (View Stats)
heisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the world
Please do this!
the t25 and 14b wont do much better than the k04. take your 16g and your 20g and make a hybrid. theres instructions on the dsmtuners forum.
heisenburg is offline   Reply With Quote
 Old 11-13-2013, 09:51 AM   #15
Groans: 224
Lol I'm way ahead of you
NATOR PA
The Following 3 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
Boosted Beluga (11-13-2013), El_Diablo (11-13-2013), Turbo_Steve (11-13-2013)
 Old 11-14-2012, 05:27 PM   #16
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
What do you think a 25g could make with supporting mods?
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 11-14-2012, 05:35 PM   #17
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
Subbed for more info!
 Old 11-14-2012, 05:48 PM   #18
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
in for win.
I actually had the same idea of just designing an adapter that would allow us to use different flanged turbos, but I never got around to actually drawing it.
Keep up the work!
A 2.3L on a 20g would spool the fuck out of that thing, and probably hold pretty good up top too.
2010 LSM Speed3
#BakeryTuned
 Old 11-14-2012, 06:11 PM   #19
Sweetsandman's Avatar
Posts: 334   (View Stats)
Sweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the world
So is Garrett's GT series...but people put those on everything.
This would be a nice inexpensive option for those folks aiming for the roughly 350-425whp range.
I Tapped that
'08 Cobalt SS - 334whp- SOLD
'09 WRX - Stage 1 - SOLD
'12 Mazdaspeed3
Sweetsandman is offline   Reply With Quote
The Following User Says Thank You to Sweetsandman For This Useful Post:
 Old 11-14-2012, 06:35 PM   #20
SC08Speed3's Avatar
Posts: 298   (View Stats)
SC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the world
Subbed.. Seems like you've got some good ideas!
08 MGM Speed 3=SURE Rmm/ShortCut/Anchors/Return,COBB AP/SF/TIP,TurboSmart B.O.V,BC Coilovers/SWIFT Springs,SPC R.C.A, M2 DP, CNT CBE, Autotech Internals, SSP EGR Delete, DDM 6K
SC08Speed3 is offline   Reply With Quote
 Old 11-14-2012, 07:59 PM   #21
Ur moms boyfriend
Groans: 70
Just wondering how well would that seal? Flange:flange:gasket
 Old 11-14-2012, 08:04 PM   #22
SC08Speed3's Avatar
In theory as long as you had a "proper" gasket placed in the "proper" place's you should be ok... I think..lol
 Old 11-14-2012, 08:05 PM   #23
Ur moms boyfriend
Groans: 70
That sounds like a whole lot of hoping
 Old 11-14-2012, 08:11 PM   #24
Voltwings's Avatar
Here @Turbo_Steve;, ill save you the trouble...
Past:
-Sold-
-Sold-
Current:
 Old 11-15-2012, 12:08 PM   #25
SC08Speed3's Avatar
This is true! But should be very interesting to see how it plays out..
 Old 11-14-2012, 08:23 PM   #26
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
Big 16G or 20g will make good ass power and spool fast as shit....The highest hp 16g evo is 500 whp with full bolt ons and E85 and boost them at like 30-35lbs and make good ass power and hold up decently long....Plus they are cheap to rebuild.
Buddy of mine also has a 16g on his talon and that bitch moves, on race gas or 85, can't remember....Another buddy with an sti just put a 20g on with a fully bolt motor.
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
 Old 11-15-2012, 10:47 AM   #27
Anybody have a spare/junk k04 Mainly need the turbine housing laying around? I have a spare stock manifold, and am going to build a jig to position the downpipe and test fit everything.
Soon to come.
 Old 11-15-2012, 10:55 AM   #28
Groans: 50
I'll see if i can get one.
Turbo_Steve likes this.
08 Mazdaspeed 3
The Following User Says Thank You to Boosted Beluga For This Useful Post:
 Old 11-15-2012, 11:39 AM   #29
Groans: 50
@ekanddsm; is the guy you need to talk to.
08 Mazdaspeed 3
 Old 11-15-2012, 12:00 PM   #30
ekanddsm's Avatar
Posts: 167   (View Stats)
ekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the world
Seeing your drawings gave me some ideas.
I would not use the k04 turbine housing because you would limit flow. If you make a adaptor flange for the 20g, and get the oil feed line close. You would have something there. 20g's are cheap, china versions are less than 500 bucks. and comes with gaskets. A true big 16g, with flanges would out flow the k04. And it woud spool crazy quick.
I have some housings, if you need them. I have been selling them as cores for bnr upgrades.
I like the idea of a 20g or even the 25 wheels. Problem with those turbos is past 22 psi they need ewgs anyways. They never run out of flow, good design, and are relativley cheap.
Id say put together a package with a 20g, with adaptors to mate the stock downpipeand stock mani, get the oil feed line close, cause it has a little movement. and supply a new oil drain line and you would have a good upgrade for less than a bnr.
cxracing.com: TD05 Big 20G Turbocharger ,oil and water cooled, Fits 89-99 1G 2G Eclipse, Talon, Laser
Cheap 20g, would require a j pipe to make the turbo outlet close to tmic location. Plus turbo inlet.....
Tibu likes this.
Last edited by ekanddsm; 11-15-2012 at 12:00 PM. Reason: MSF Database - Automerged Doublepost
ekanddsm is offline   Reply With Quote
The Following 3 Users Say Thank You to ekanddsm For This Useful Post:
Boosted Beluga (11-15-2012), Koke382 (01-16-2013), Tibu (11-19-2012)
 Old 11-15-2012, 12:21 PM   #31
I'm not intending to use the k04 housing. I have a spare mazdaspeed manifold and an aftermarket downpipe. I want to bolt them together and make a test fit jig out of them. Then I can double check my measurements and make a true bolt on solution before spending big money to have some flanges made that may not be right.
I would only need to borrow one for a week or so... Let me know via pm.
Thanks!!!
Soon to come.
Boosted Beluga (11-15-2012), MS3-a(sore)ASS-rex (11-15-2012), Tokay444 (11-18-2012)
 Old 11-15-2012, 12:06 PM   #32
Groans: 50
I'll take a 20g since I'm fully bolted and built with an EWG mani.
08 Mazdaspeed 3
 Old 11-15-2012, 12:34 PM   #33
DSM to mazdaspeed flange.
Dsm TDO6 Divorced turbine housing.
Remove the wastegate flapper and port the housing.
Then a custom down pipe mimic this.
Soon to come.
The Following 7 Users Say Thank You to Turbo_Steve For This Useful Post:
Boosted Beluga (11-15-2012), Easter Bunny (11-19-2012), Mazdanspeed3 (11-16-2012), MonstaSpeed6 (01-17-2013), MS3-a(sore)ASS-rex (11-15-2012), speedms6 (11-16-2012), Tibu (11-19-2012)
 Old 11-16-2012, 08:43 PM   #34
Mazdanspeed3's Avatar
Posts: 157   (View Stats)
Mazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond repute
Wow i was trying to do this also, i have a td05h 20g i was gonna rebuild with a td06h turbine, performance thrust bearing, 3" inlet compressor housing, billet compressor wheel, etc. when i priced it out, it cost like 600 to do this to the turbo. i wish i had autocad still, as i was going to ask if someone can design an adapter flange like you did (NICE). i figured to ease fabrication, buy a mitsu and mzr flange and use a 3" length of 2.25" pipe with a 38mm vband in the middle to integrate a wastegate. I'd love to see where you go with this bro. PM me also we can bounce ideas off each other.
EDIT: Also, looked at forced performance, they have a 8cm (.63 a/r) td05 turbine housing that they can modify to fit a td06 OR use the trick ass Bullseye power stainless turbine housing if you can find it.
2009 Mazdaspeed 3 MGM
-PG Full intake -Cooper813 Testpipe -E2 short shifter and bushings -Weapon R ETD -TRZ RMM/TMM -Deleted resonator -Cobb shifter weight -Prosport boost gauge -Greddy Turbo Timer -Synapse DV -Ford Tranny Fluid Change-K2 Oil Pan Baffle -PT-P BSD -ITV22 -HD Valve Cover Catch Can -PG FMIC piping with modified DSM core -SU Tranny/Passenger Billet Mounts -Mazdaspeed 3" Catback
-Awaiting Installment-
-DLP OCC and Check Valve
Mazdanspeed3 is offline   Reply With Quote
The Following User Says Thank You to Mazdanspeed3 For This Useful Post:
forcedinduktion (11-16-2012)
 Old 11-18-2012, 09:15 AM   #35
sikksohc's Avatar
Posts: 17   (View Stats)
sikksohc will become famous soon enoughsikksohc will become famous soon enough
Neutral  -1 score
I was actually attempting this last month, but due too some complications and time restraints i ended up going with an atp. I will post pictures up tomorrow night of the work i did. I was planning on using a evo3 16g. Over all the compressor and turbine wheel were about 6mm bigger from what i had found.
Speed6- gtx3071r ,mscai, cpe4" tip, eb catless down pipe, corksport rmm & diff mount, autotech hpfp internals, unplugged egr delete, cobb ap custome tune
sikksohc is offline   Reply With Quote
 Old 11-18-2012, 10:09 AM   #36
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Let me know when you have your flange dimensions worked out.
I can likely machine them for you.
"Exclusivity" - CP-enis
Demodded.
The Seals
Boosted Beluga (11-18-2012), Easter Bunny (11-19-2012)
 Old 11-19-2012, 11:14 AM   #37
Tibu's Avatar
Posts: 178   (View Stats)
Tibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the world
Christs sake, $300 for a brand new 20G!? Shit if you can make the whole thing a mostly drop in deal for under $700 this will be THE upgrade after HPFP internals.
2007 Black Mica Mazdaspeed 6
Mods to Date: Cobb AP, Mazdaspeed CAI, Cobb TIP, SU Boost Tubes, 1 step colder plugs, Saikou Michi OCC, HKS BPV, SU Test Pipe, JBR Chrome Molly RMM, RPM Street Springs, SPC Adj. Ball Joints, Racing Hart CP035R 18x9 +35, BF Goodrich G-Force Comp2 245/40 tires
Tibu is offline   Reply With Quote
The Following 2 Users Say Thank You to Tibu For This Useful Post:
BobtailedSnail (11-19-2012), Koke382 (09-26-2013)
 Old 11-19-2012, 11:50 AM   #38
My thoughts on this are telling me to skip the t28 flange route. I am going with a td06 Dsm turbine 20 g wheel and compressor and a custom downpipe to allow an external wastegate. If all works well then I may see about duplicating parts.
I think the 20g won't perform without the external wg. And a td05 turbine would hurt power potential.
Soon to come.
The Following 2 Users Say Thank You to Turbo_Steve For This Useful Post:
Boosted Beluga (11-19-2012), forcedinduktion (11-19-2012)
 Old 11-19-2012, 12:18 PM   #39
sikksohc's Avatar
Fwiw, The tdo5 turbine had a 6mm bigger inducer and exducer on the turbine wheel itself, compared to the stock turbine . As far as the housings a/r size I'm not sure how they would compare. Also on the evo 16g , the water lines are 14mm( same as stock) the oil return uses the same flange and the oil feed is 12x1.25 (stock is 12x1.5). I'm sure the 20g would be the same.
The Following User Says Thank You to sikksohc For This Useful Post:
ChimmyChong (11-19-2012)
 Old 11-19-2012, 02:06 PM   #40
Ur moms boyfriend
Groans: 70
Would it be possible to incorporate something like this...?
T3 T3 T4 5BOLT Downpipe Flange to 2 5" V Band Adaptor | eBay
http://www.ebay.com/itm/3-Inch-V-CLA...14a3ce&vxp=mtr
New Borg Warner EFR Turbochargers!!! Alpha MazdaSpeed 3/6 - Turbo Induction 122 11-06-2018 07:05 PM
BorgWarner sues Cummins over patents on titanium turbochargers Haltech Automotive News 0 10-26-2011 05:10 PM
Nissan studying turbochargers for future vehicles? Haltech Automotive News 0 08-03-2009 12:00 PM
Honeywell discussing U.S. gas turbochargers with GM Haltech Automotive News 1 09-16-2008 03:42 PM
Honeywell to sell turbochargers to Ford in U.S. Haltech Automotive News 0 07-30-2008 10:50 AM
Page generated in 0.72586 seconds with 41 queries
