Like Tree57Likes
 Old 02-11-2013, 04:17 PM   #81
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I prefer.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 02-22-2013, 11:50 AM   #82
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
So what is still needed to produce adapters? If they're just going to be a flat spacer style adapter I can probably have some water jetted out of stainless....
You guys get me specs or a file to have cut and if its something I can have cut out of stainless on a waterjet I can probably have it within 2 weeks depending on complexity.
The Following 3 Users Say Thank You to El_Diablo For This Useful Post:
alphasaur (10-26-2013), Boosted Beluga (02-22-2013), sidekick (02-22-2013)
 Old 02-28-2013, 12:43 PM   #83
Turbo_Steve's Avatar
Posts: 944   (View Stats)
I have been working 2 jobs like crazy to save and buy a house. Will be closing on the 15th and moving by the end of march. I will not have much time to work on drawing up flanges. The problem with the mitsu to MS turbo inlet flange is that they are both threaded for studs. The flange would need to be 3/4 inch thick and countersunk, finding / having custom bolts made in the right thread, shoulder and length have been tough. You would bolt a studded flange to the mitsu turbo.
I have all the flange dimensions drawn up. I plan to make a flange and build a jig for a custom downpipe. I want to use the dsm housing with an external wastegate.
This does need to be said though. I purchased a stock turbo manifold from a mazdaspeed for mock up. The manifold internally sucks for flow. I think the best solution would be for a custom mani with a custom flange. But that will still require a downpipe to be made too and therefore will kind of make doing all this pointless.
I do however have drawn up A pair of conversion flanges for a t2 turbine housing that would allow it to bolt in with the stock manifold/downpipe.
You can order a t2 turbine housing made for a td06 mitsu chra. This would make it a true bolt on with only needing a different thread pitch banjo bolt for the oil feed.
Soon to come.
WHO KNOWS? A.D.D. FTW!
The Following 3 Users Say Thank You to Turbo_Steve For This Useful Post:
Boosted Beluga (02-28-2013), El_Diablo (02-28-2013), Koke382 (02-28-2013)
 Old 09-17-2013, 08:11 AM   #84
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Any updates to this? @Turbo_Steve;
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 09-17-2013, 07:28 PM   #85
I have in the works is a k04 - mitsu hybrid.
I have a subaru td06 20g turbo and a stock k04 exhaust housing.
I always thought they could work together and now I know the td05/6 bearing housing can fit the k04 but with a td05 wheel. I am trying to see if a td06sl2 or hopefully a full td06 can fit.
Soon to come.
The Following 5 Users Say Thank You to Turbo_Steve For This Useful Post:
BigRedSpecial (09-18-2013), Boosted Beluga (09-17-2013), btstarcher (09-17-2013), El_Diablo (09-18-2013), speed3sailor (09-18-2013)
 Old 09-25-2013, 07:45 AM   #86
So I am going into the slow season at work. I will have lots of time to devote to this project. I have pretty much deemed the factory k04 turbine housing a worthless piece of junk. I can definetly make a td05 / k04 hybrid. The machine work isn't that involved but the down side is it looks like it can only be done with an oil cooled only chra. The chra needs to be turned down pretty far to fit the k04. It has enough material to do this but it looks like a water passage will be cut into. It may be weldable but this isn't something you want to risk.
I also feel like the turbine itself is too restrictive. So the only answer is to make a new turbine housing.
I am in the process of designing a high flow 8cm^2 td06sl2 bolt on turbine housing for the mazdaspeed.
Soon to come.
The Following 9 Users Say Thank You to Turbo_Steve For This Useful Post:
BigRedSpecial (09-25-2013), Boosted Beluga (09-25-2013), btstarcher (09-25-2013), cshunter (09-25-2013), Easter Bunny (09-26-2013), El_Diablo (09-25-2013), JTMS3 (09-25-2013), speed3sailor (09-25-2013), Voltwings (09-25-2013)
 Old 09-25-2013, 09:34 AM   #87
6ixof1's Avatar
Posts: 700   (View Stats)
Default Wow
Damn, that's awesome!
Subbed.
Black Mica Mazdaspeed 6
The Mad Scientist Tunings
 Old 09-25-2013, 03:05 PM   #88
Voltwings's Avatar
Posts: 3,713   (View Stats)
So if im understanding you correctly, its basically a reverse BNR? Same compressor just different turbine?
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 09-26-2013, 07:36 AM   #89
No, I am designing a custom turbine housing that will make use of a mitsubishi td06sl2 20g wheels and center section. Should be rated to about 47 lb/min and have decent spool.
Think more like ATP a full replacement turbo that is a bolt on, but this will use all the oem oil / coolant lines.
Soon to come.
The Following 8 Users Say Thank You to Turbo_Steve For This Useful Post:
Agent_Orange (10-10-2013), Boosted Beluga (11-13-2013), btstarcher (09-26-2013), cshunter (09-26-2013), El_Diablo (09-26-2013), KiwiFlavor (08-04-2014), Koke382 (09-26-2013), Voltwings (09-26-2013)
 Old 09-26-2013, 09:02 AM   #90
Koke382's Avatar
Posts: 4,361   (View Stats)
Groans: 32
Subbed for sure
sent from my peepee
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
 Old 10-04-2013, 11:59 AM   #91
Headache..... Check!
Empty Wallet....... Check!
Light at the end of the tunnel.... Check!
I have sent off a td06 sl2 turbine housing to be cut into 2 pieces with a wire edm machine and then to be digitized.
When I get the digitized file back I can then use the design of the td06 turbine housing and scroll. I will then add in the mazdaspeed flanges and wastegate swing valve with a 34/36 mm flapper.
This file will then be used to make a pvc prototype using a 3d printer. If it all fits properly and looks good I then need to find a manufacturer who can cast turbine housings.
Soon to come.
The Following 15 Users Say Thank You to Turbo_Steve For This Useful Post:
6ixof1 (10-04-2013), Agent_Orange (10-10-2013), BigjohnB20 (10-04-2013), BigRedSpecial (10-04-2013), Boosted Beluga (10-04-2013), btstarcher (10-05-2013), cshunter (10-04-2013), Dimenus (10-04-2013), El_Diablo (10-04-2013), KiwiFlavor (08-04-2014), Koke382 (10-07-2013), Kyle Undefined (10-04-2013), manila (10-04-2013), silvapain (10-10-2013), Voltwings (10-04-2013)
 Old 10-10-2013, 05:27 PM   #92
The next time you see these.... They will be one piece.
Check back soon.
Koke382 likes this.
Soon to come.
Agent_Orange (10-10-2013), alphasaur (10-26-2013), Boosted Beluga (10-11-2013), btstarcher (10-11-2013), cshunter (10-11-2013), Dimenus (10-28-2013), El_Diablo (10-11-2013), goo (10-16-2013), guitarzan134 (10-11-2013), ItsNox (10-11-2013), jtt (10-10-2013), KiwiFlavor (08-04-2014), Koke382 (10-10-2013), memin (10-26-2013), Voltwings (10-10-2013)
 Old 10-26-2013, 05:21 PM   #93
2 weeks and i should have a prototype turbine housing. I need to come up with a good name for this turbo. Something awesome to have cast into the compressor housing cover.
Soon to come.
The Following User Says Thank You to Turbo_Steve For This Useful Post:
Koke382 (10-26-2013)
 Old 10-26-2013, 06:06 PM   #94
Groans: 50
FYHN
Sixxer likes this.
08 Mazdaspeed 3
The Following 4 Users Say Thank You to Boosted Beluga For This Useful Post:
Koke382 (10-26-2013), Roddiy (10-31-2013), Sixxer (10-26-2013), Turbo_Steve (10-31-2013)
 Old 10-26-2013, 06:08 PM   #95
Koke382's Avatar
Groans: 32
I want a turbooooo
sent from my peepee
1993 Red Na6
 Old 10-27-2013, 07:28 PM   #96
Voltwings's Avatar
introducing the new BNR, the BFA (bad fuckin ass).
Past:
-Sold-
-Sold-
Current:
Koke382 (10-27-2013), Turbo_Steve (10-27-2013)
 Old 10-28-2013, 09:37 AM   #97
El_Diablo's Avatar
Groans: 769
BAMF-T
 Old 10-28-2013, 09:43 AM   #98
Koke382's Avatar
Groans: 32
IHTFT "I haz teh fast turblo"
sent from my peepee
1993 Red Na6
 Old 10-31-2013, 11:02 AM   #99
BOHICA
Bend Over Here It Comes Again?
Koke382 likes this.
Soon to come.
The Following 2 Users Say Thank You to Turbo_Steve For This Useful Post:
Koke382 (10-31-2013), nybe0010 (10-31-2013)
 Old 10-31-2013, 11:33 AM   #100
Koke382's Avatar
Groans: 32
TSRT
sent from my peepee
1993 Red Na6
 Old 11-13-2013, 08:46 AM   #101
Still waiting for the turbine housing... 1-2 more weeks
But the rest of the turbo is almost ready. Just need to weld the extension on the compressor outlet and install the wga when the turbine housing is here.
Koke382 likes this.
Soon to come.
The Following 10 Users Say Thank You to Turbo_Steve For This Useful Post:
BobtailedSnail (11-13-2013), Boosted Beluga (11-13-2013), btstarcher (11-14-2013), dsb_chicago (11-13-2013), El_Diablo (11-13-2013), KiwiFlavor (08-04-2014), Koke382 (11-13-2013), mdl3v8 (11-13-2013), Status Update (11-13-2013), timjs (11-13-2013)
 Old 11-13-2013, 09:26 AM   #102
heisenburg's Avatar
Posts: 357   (View Stats)
heisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the worldheisenburg is the leader of the world
Please do this!
I'd love to use the T25's, 14b's, 16g's, 18g's and 20g's I have laying around my house. Lol
the t25 and 14b wont do much better than the k04. take your 16g and your 20g and make a hybrid. theres instructions on the dsmtuners forum.
heisenburg is offline   Reply With Quote
 Old 11-13-2013, 09:51 AM   #103
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Lol I'm way ahead of you
NATOR PA
The Following 3 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
Boosted Beluga (11-13-2013), El_Diablo (11-13-2013), Turbo_Steve (11-13-2013)
 Old 11-13-2013, 11:59 AM   #104
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
This turbo is going to be nuts.
 Old 11-13-2013, 12:10 PM   #105
Groans: 50
Realistically what kind of numbers at what boost do you think this would put out? IF you need/want any testers I can. I have a built motor, ported intake mani, ported head, 3.5" intake, 3port, catless exhaust, e85, rtubular exhaust mani.
08 Mazdaspeed 3
 Old 11-13-2013, 12:58 PM   #106
Koke382's Avatar
Groans: 32
Same as me in for beta testing lol
If not make some and sell here id be a customer for sure.
sent from my peepee
1993 Red Na6
 Old 11-13-2013, 03:58 PM   #107
Should be good for anywhere from 44 - 47 lb/hr so I would say that this is going to be good for 425+whp with proper fueling. Probably 450+ with e85 and added fuel.
Should be pretty efficient at about 20-22 psi.
I think the best thing about mitsubishi turbos is that they are inexpensive, reliable, don't have issues with smoking, and make great power.
Soon to come.
Boosted Beluga (11-13-2013), El_Diablo (11-13-2013), Koke382 (11-13-2013), MonstaSpeed6 (11-13-2013), Status Update (11-13-2013)
 Old 11-13-2013, 04:07 PM   #108
Koke382's Avatar
Groans: 32
Im in for sure then lol
sent from my peepee
1993 Red Na6
 Old 11-13-2013, 05:50 PM   #109
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
So is this a 20g with a mazda flange? Sry, glanced through the thread and saw the turbo.
And what is this costing you? I can do a setup just like this......I was thinking of doing a big 16g or 20g swap on the ms3.....Guy that i take my car and big on dsm/evos has these turbos sitting around ((also rebuilds those turbos))
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
The Following User Says Thank You to mazdafreak For This Useful Post:
 Old 11-13-2013, 05:54 PM   #110
Groans: 50
20g td06 is what I got out of it. Lol I could be mislead with all the different talk in this thread.
08 Mazdaspeed 3
The Following User Says Thank You to Boosted Beluga For This Useful Post:
mazdafreak (11-13-2013)
 Old 11-13-2013, 05:58 PM   #111
mazdafreak's Avatar
Groans: 124
hahaha, thats why i asked.
okay sweet. Gonna ask my guy about that setup too....Was planning on going with the pte5858 after winter. I could always try this setup out and have faster spool.
713whp/569wtq!
 Old 11-13-2013, 06:14 PM   #112
i think you are missing what he's doing. he's not just machining a 20g into a k04 housing he's getting a new housing cast that will flow better then the stock housing but it will still have the stock flanges on it.
The Following 2 Users Say Thank You to 2.0t03speed For This Useful Post:
btstarcher (11-14-2013), El_Diablo (11-14-2013)
 Old 11-13-2013, 07:05 PM   #113
manila's Avatar
Posts: 1,767   (View Stats)
@Turbo_Steve;
Progress is coming along nicely!
I too would like to know the cost out of all this?
(If you don't mind answering that)
'12 MS3 Black Mica w/ Tech
The Following User Says Thank You to manila For This Useful Post:
mdl3v8 (11-13-2013)
 Old 11-13-2013, 07:15 PM   #114
mazdafreak's Avatar
Groans: 124
Yeah that's what I saw when he posted those two pics of the vband and mazda flange hotside.
Either way, I'd be done to try something similar.
713whp/569wtq!
 Old 11-13-2013, 07:35 PM   #115
My thoughts for doing this are that mitsubishi turbos rock. Ko4 turbine housing sucks and can only go as big as a td05 wheel with an oil cooled only mitsubishi chra. So this required a custom housing. Lets add a 34mm wastegate port while we are at it.
This design will hopefully open up a ton of options for the platform. There will be at least 4 turbos built. What happens with them is to be determined. Please stay tuned for more info when the prototype is finished.
If this works out well and there is demand, I may have a run of these made for sale, but I will have to get an ok from the proper channels on here to sell them. I have some contacts I am going through and may be able to get these out for a really great price.
Soon to come.
6ixof1 (11-14-2013), Boosted Beluga (11-13-2013), btstarcher (11-14-2013), El_Diablo (11-14-2013), manila (11-13-2013), mdl3v8 (11-13-2013), Status Update (11-14-2013), Vansquish (11-14-2013)
 Old 11-13-2013, 07:40 PM   #116
Koke382's Avatar
Groans: 32
Let me know id be a buyer for sure especially if its ewg. Ill start saving lol k thanks
And mad props on working on this seriously.
sent from my peepee
1993 Red Na6
 Old 11-13-2013, 08:31 PM   #117
sent from my peepee
it's going to be iwg according to his last post. it's just going to have a bigger port.
The Following 3 Users Say Thank You to 2.0t03speed For This Useful Post:
Boosted Beluga (11-13-2013), Turbo_Steve (11-14-2013), Vansquish (11-14-2013)
 Old 11-13-2013, 08:47 PM   #118
Koke382's Avatar
Groans: 32
Oh :/ lol reading fail
sent from my peepee
1993 Red Na6
 Old 11-13-2013, 08:55 PM   #119
Groans: 50
Block off the iwg.
Koke382 likes this.
08 Mazdaspeed 3
 Old 11-13-2013, 09:05 PM   #120
manila's Avatar
sent from my peepee
@Turbo_Steve; I second this
Koke382 likes this.
New Borg Warner EFR Turbochargers!!! Alpha MazdaSpeed 3/6 - Turbo Induction 122 11-06-2018 07:05 PM
BorgWarner sues Cummins over patents on titanium turbochargers Haltech Automotive News 0 10-26-2011 05:10 PM
Nissan studying turbochargers for future vehicles? Haltech Automotive News 0 08-03-2009 12:00 PM
Honeywell discussing U.S. gas turbochargers with GM Haltech Automotive News 1 09-16-2008 03:42 PM
Honeywell to sell turbochargers to Ford in U.S. Haltech Automotive News 0 07-30-2008 10:50 AM
Page generated in 0.60786 seconds with 32 queries
