 Old 02-29-2016, 03:58 PM   #1
wes3id's Avatar
Posts: 611   (View Stats)
update: 2nd revision of full freektune with newly installed BNR S3 pushing 20 psi, justin tells me i'm maxing my MAF voltage at 17 psi with my POS Sure full 3" aeros intake....ordered JBR 3.5" wide path.
wes3id is offline   Reply With Quote
The Following User Says Thank You to wes3id For This Useful Post:
robbspeed (02-29-2016)
Page generated in 0.23295 seconds with 21 queries
