 Old 02-11-2016, 05:40 PM   #1
wes3id's Avatar
Posts: 611   (View Stats)
Default need advice from ms6'rs with bnr s3
Expecting my BNR S3 in the mail tomorrow, was doing some reading about not going above 24 psi due to blow by/dipstick popping. i have a single JBR catch can non vta. would getting a pcv plate and vta valve cover be sufficient? i don't currently have and problems with oil in my intake or intercooler and my dry compression is 176 across all 4. any suggestions or advice would be helpful
wes3id is offline   Reply With Quote
 Old 02-11-2016, 05:47 PM   #2
wes3id's Avatar
also, will a 3.5" intake net me anything substantial over the 3" i have currently?
thanks guys
 Old 02-11-2016, 07:05 PM   #3
dale_gribble's Avatar
Posts: 4,720   (View Stats)
3" is fine. I'm flowing 24psi, ~350g/s and maf sensor is only around 4.5 volts.
Btw, never popped a dipstick.
MINI H1 6.0 - CAR LED TAILS
Last edited by dale_gribble; 02-11-2016 at 07:05 PM. Reason: MSF Database - Automerged Doublepost
Vansquish (02-11-2016), wes3id (02-11-2016)
 Old 02-11-2016, 07:17 PM   #4
Police - Grammarhead
Vansquish's Avatar
thanks guys
Depends on where you live, but as long as your intake has an ID of at least 3", you should be just fine in most places at most times of the year.
My CP-E Nano has a 2.715" inner diameter (I busted out the calipers and measured), and I'm hitting MAF cut at about 365g/s at ~24psi in cold weather.
Once you go to a 3.5" ID or above, the aggressive scaling, and loss of granularity on the MAF curve tends to mean that drivability goes downhill pretty quickly at low revs and low load.
Oh yeah, haven't popped a dipstick yet myself, and I'm running a non-VTA JBR OCC from the PCV plate, as well as a non-vented JLT OCC for the valve cover breather.
dale_gribble (02-11-2016), wes3id (02-11-2016)
 Old 02-11-2016, 10:54 PM   #5
Nitro's Avatar
Posts: 229   (View Stats)
Nitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond repute
I am running 25 psi and have not had any problems with the dipstick blowing out.
COBB AP : JBR 3 Inch Full Intake : CORKSPORT TMIC : AUTOTECH INTERNALS : JBR SSP
CPE Full RMM : Cobb Catted DOWNPIPE : BNR S3 : KW V1 Coilovers : Klutch SL18 Rims
Guardian Angel : Stratified 3 Port : Michelin PSS 235/40/18 : SNOW PERFORMANCE : E85
Stratified Tune
Nitro is offline   Reply With Quote
The Following User Says Thank You to Nitro For This Useful Post:
wes3id (02-12-2016)
 Old 02-11-2016, 11:03 PM   #6
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
I'm riding the limit of a Bosch 3BAR (300-305kPa, so 29-29.5PSI) and never had the dipstick move. The intake is relatively dry where the PCV hose connects to it and because I'm on the factory PCV system I'm losing quite a bit of power, but that's a different story.
Check your compression, if it's good and the PCV and the rest of the crankcase ventilation system is sane you will not pop a dipstick that easily.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
wes3id (02-12-2016)
 Old 02-29-2016, 03:58 PM   #7
wes3id's Avatar
update: 2nd revision of full freektune with newly installed BNR S3 pushing 20 psi, justin tells me i'm maxing my MAF voltage at 17 psi with my POS Sure full 3" aeros intake....ordered JBR 3.5" wide path.
The Following User Says Thank You to wes3id For This Useful Post:
robbspeed (02-29-2016)
Page generated in 0.28245 seconds with 24 queries
