 Old 09-20-2017, 10:01 PM   #1
delirium7777's Avatar
Posts: 2   (View Stats)
delirium7777 is an unknown quantity at this point
Default Need P/N for downstream O2 sensor on my 2006 MS6
Hi, everyone.
Sorry if this is a repeat post! I have searched all over the net for an affirmative answer, but I cannot seem to find one.
I've got the stutter issue and decided to replace both oxygen sensors. I got the upstream one done with no problems and it made a huge difference.
However, when I went to replace the downstream one, the electrical connector did not fit in the mating connector under the battery tray. Every site I've seen says DENSO 234-4395 should fit, but that's what I ordered (Amazon)...
Did they just send me the wrong part maybe? What P/N and brand downstream sensor have you guys used?
Thanks in advance for your help here!
delirium7777 is offline   Reply With Quote
 Old 09-21-2017, 10:13 AM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Originally Posted by delirium7777 View Post
Hi, everyone.
Go to Rock Auto and get the NTK brand.
A stutter in what way? Under throttle application when you get into boost? What are your plugs gapped to? If you don't know, check.
Downstream O2 for Speed6 Mazdazilla6 Mazdaspeed3/6 General Discussion 3 02-02-2014 03:28 AM
Page generated in 0.23533 seconds with 21 queries
