![]() Join Date: Jun 2012 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 927
| Not Ranked : 0 score FYI, here is the easiest way I found to remove the oil return line from the turbo (as done on my CX-7...with the transfer case in the way like on the MS6) : - Remove all heat shields - Get the downpipe out of the way - Remove the exhaust manifold - Remove or loosen the coolant line that is between the block and turbo (to get access to the bolt nearest the block) - Take a small (1/4) ratchet with a 8mm socket (you will need a 2’’ extension to get to the bolt nearest to the block) - Lay on the engine with your face against the cowl/wiper section, then reach the bolt from where the downpipe was (removing the exhaust manifold gives some more space...) - At that point, the only issue is applying enough torque to unscrew the bolts in this awkward position Hope this help...
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement |
| Stock catback removal - tips, tricks, gotchas? | TheRealDefman | 2010 MS3 - How-To's | 20 | 02-01-2012 09:36 PM |
| removal of exhaust manifold bolt behind turbo | dooderek | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 02-27-2011 08:07 PM |
| Stock PCV Valve Removal | dizzin9 | MazdaSpeed 3/6 - Turbo Induction | 16 | 03-09-2010 09:21 AM |
