![]() Join Date: Mar 2012 Location: Middletown, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 7 Times in 5 Posts
(Thread Starter) | Not Ranked : 0 score I had a look at where the oil return bolts to the block, not sure if I can get a wrench on that either. So close and can't get it off. One thing I noticed is that even with just these two lines still connected it still feels like it's attached somehow, is that normal or am I maybe missing a bolt. It moves around a lot but just feels like there's more holding it on than just the oil and coolant return lines. I removed the 5 from the DP and the 4 from the mani, the bolt down under the EGR, I can't see anything else. Does anyone have any suggestions - do not want to put it back together and drive it to Mazda. |
![]() Join Date: Mar 2011 Location: Iceland
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score You should be able to remove the two bolts for the oil outlet from under the car. There is also a 10 mm bolt (14 or 17mm wrench) that is holding the turbo from beneath . Hope you have solved this, or this will help |
(Thread Starter) | Not Ranked : 0 score Unfortunately I ran out of time, this is my daily driver so I had to put it back together again. I couldn’t even see the turbo from underneath the car unless I was just not looking in the right place. I was kinda feeling defeated by then anyway. A local shop just quoted me $850 to do it. F me, two bolts and a hose clamp away. Maybe I’ll have another go at it before I take it in. For one thing, I can’t see it taking me 3 hours to get the manifold off next time. Where is the bolt holding the turbo on underneath, on the turbo bracket which is triangular shaped ? If so the dealer didn't bother to put it back in when they replaced it under warranty at 20K. The cold side of my turbo looks like this, caked on oil residue. Could just be that the seals are failing…. |
| Not Ranked : 0 score ![]() Yes it´s in the triangle shaped one, you can see on the picture. The bracket on the oil inlet bolts to the exhaust manual, so it has to go if you are removing the manifold to. This is not easy work to do, but it´s better to remove the hood to get better access. Some have also removed the plastic on the firewall to get better space. You can find it in how to´s Are you going to use stock k04 again? If it´s smoking a lot, it could be good idea to measure the crankcase pressure, before you remove the turbo. Easy to do, just use cheap pressure gauge and route it from the engine dipstick pipe to inside, then take a run (wot) and see what it does. My car was smoking a lot in i pulled to turbo out and got it reworked, but was still smoking a lot. Then I did measure the pressure and got 7 psi, which is way to HIGH. Afterwards I did a compression test, which resulted to be a crack in cylinder sleeve. Last edited by ladan; 04-16-2013 at 06:49 PM. |
(Thread Starter) | Not Ranked : 0 score What kind of pressure gauge am I looking for and do I put it in the end of the dipstick pipe or does it need to be inserted into the block where the dipstick pipe connects ? I may as well test the pressure before I start trying to replace this KO4 again. I recently replaced the PCV valve as well. I checked my compressions and got varying results, sometimes 2 and 3 would read as low as 90 (if I did 8 cranks) and other times it was up to 180, on the same cylinder.(if I cranked for 8 seconds). The low reading was strange but the high reading was right on the numbers from the shop manual. I’m using a rebuilt KO4 to replace the old one. |
![]() Join Date: Mar 2010 Location: Philadelphia, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 413
| Not Ranked : 0 score FWIW i couldnt really see the bolts from underneath either. transfer case/awd on ms6 really makes the job harder. i posted up on your thread on m6c how i did it but it likely will be harder for you with your stock DP. also i loosened/moved the black bracket at the bottom of the picture you posted in order to help fit my hand underneath the turbo from that side.
__________________ 2006 White Water Pearl Mazdaspeed6 Grand Touring #5430 HTA3076 Tial .82 Turbine Housing, CPE tial Mani, Tial MVR 44mm 20psi spring VTA DO Stage 2 Meth w/ D07 & 100% - NJSPEED3 PnPed IM - HTP 3" TIP - SSP BigMAF SRI w/ AEM Dryflow and filter wrap - GS EBCS - Fabbed M2 Catless DP - Autotech HPFP Internals - Cobb AP - Custom 2.5" w/ TR8 FMIC - GHL Resonated Dual Catback Exhaust - TS/SU DP BOV - SP63 Aux Fan Old: BNR S3 370/380 VD 91 + Meth BNR S3 400/410 VD E21 + Meth - Dyno confirmed: http://www.mazdaspeedforum.org/forum/forum/f338/mazdaspeed6-bnr-s3-dyno-400-410-a-180820/ |
Are you DubD on M6c ? Last edited by Mandinca; 04-18-2013 at 09:53 AM. | |
| Not Ranked : 0 score i have the same name on both as for the bracket maybe im confusing two brackets but i know i moved a black bracket on the intake side below the turbo. it may have been a rotational move so that it wasnt sticking up but it definitely moved. look at the picture you posted i may have unclipped it from the top hose then rotated it down so that it didnt stick up. gave a bit of room. either way read my post of m6c and see if any of that is possible for you with the stock DP
2" 52mm Motor Car Mechanical Tinted Turbo Boost Gauge Bar LED | eBay Remove the dipstik and get hose that fits tight over it, then route the hose inside your car. | |
Groans: 136
| Not Ranked : 0 score The oil drain bolts are 8mm. I use a ratcheting wrench for the bolts to the block, and a socket and a shit-ton of extensions to get to the bolts on the turbo. Unbolt it all from underneath the car.
__________________ |
I can't see it from underneath the car, the transfer case completely blocks it. Last edited by Mandinca; 04-18-2013 at 02:12 PM. Reason: MSF Database - Automerged Doublepost | ||
| Not Ranked : 0 score It would be better to use psi gauge, but you could try, of it goes over zero you have some kind of a problem. |
![]() Join Date: Nov 2013
Rep Power: 0 ![]() Thanks: 0
For heatshield bolts, spray them with PB Blaster, maybe bang on them gently with a rubber mallet or something to loosen them up. In the worst case, cut the shield and buy a replacement on the forum for cheap.
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned Last edited by Code Monkey; 01-13-2014 at 06:44 AM. | |
(Thread Starter) | Not Ranked : 0 score I took mine off and never bothered putting them back on again. PB Blaster works wonders, use some of that if the WD40 doesn't work.
__________________ Black 2006 MS6 GT with Navigation // Cobb AP V2 // Cobb SRI // M2 Catless DP // Autotech internals // JBR 80 Duro RMM |
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned | |
(Thread Starter) | Not Ranked : 0 score I'm curious to hear how @Heartbreak1; gets on with the oil drain removal. It stopped me dead in my tracks. I think the next time I do the turbo removal I'm just going to saw that fucker in half and put a new one on. Even at $120 it's porobably worth it to avoid the aggravation. I'm actually going to try to mod one using braided hose with hex nut connectors at both ends - much easier to get a wrench to making turbo removal much much easier :-)
| Not Ranked : 0 score Make sure you do not fail like me here. ![]() To get around the TC, I think this will work on the TC side: -- flange with a female thread -- either a 45 or a 90 degree fitting, 1/2" NPT to -10an -- then a -10an straight swivel hose end fitting When I get my engine built, I think I will go with a weld-on oil drain bung.
(Thread Starter) | Not Ranked : 0 score I would never have known that the transfer case was in the way and would have cut my OEM pipe just to get the turbo off......leaving me with no car. I'm glad we had this conversation ! I actually have a spare motor in my garage so I can mock up the oil drain on that. No spare transfer case although I could probably mock up the piece of transfer case that is in the way using a piece of cardboard. How do you plan to protect your drain pipe from heat ?
![]() Join Date: Jun 2012 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 927
The custom or DIY oil return line is a very good idea...
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement | |
I didn't attempt to undo it from underneath when I attempted the turbo removal because I was paranoid that the bolts would shear and I'd be completely fucked then. With the turbo out of the way I would be able to access the block end of the oil drain much more easily and removal of the bolts would be easier. Also, prefabbing the modded oil line with a hex nut to a male flange bolted to the block would take most of the drama out of this.
__________________ Black 2006 MS6 GT with Navigation // Cobb AP V2 // Cobb SRI // M2 Catless DP // Autotech internals // JBR 80 Duro RMM | |
| Not Ranked : 0 score since im awd, i think my transfer case is in the way. If that's the case, will I have to pull the turbo form the to by removing the exhaust manifold? |
| Not Ranked : 0 score so nvm guys, there's a whole in my block. This turned into a whole bottom end build and turbo replacement. |
![]() | | #24 | ![]() |
@aviator79; and I just did a full motor swap in about 30 hours. About 2 hours of that was just spent trying to get the driver side drive shaft back in. We took the motor out of the top but it might have been easier to pull the whole front off. I didn't want to discharge the AC so we decided just to unbolt everything and tilt it forwards. Without doing that we weren't able to create enough room for the PTO flange to clear the bulkhead. Engine hoist with a load leveler.....and two people preferably.
__________________ Black 2006 MS6 GT with Navigation // Cobb AP V2 // Cobb SRI // M2 Catless DP // Autotech internals // JBR 80 Duro RMM Last edited by Mandinca; 01-13-2014 at 11:14 AM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #25 | ![]() |
I will be trying (again) the stock line tomorrow or Wednesday. If this does not work, I will go the route I outlined above.
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned Last edited by Code Monkey; 01-13-2014 at 11:19 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #26 | ![]() |
What about cutting the stocker in half and inserting a piece of flexible hose so that once the turbo is unbolted you can flex it in a direction that gives you access to the oil drain on the underside. Let me know which of those flanges and connectors you end up using. There has to be a way to make this easier.
![]() | | #27 | ![]() |
| Not Ranked : 0 score I am pretty sure they pull the engine.
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score In a freakin day ? I guess it's easier when you have a lift but still....
| The Following User Says NO Thank You to Mandinca For This Un-useful Post: | fengrs (01-15-2014) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score I am about to slit my wrists, FML.
![]() | | #30 | ![]() |
| Not Ranked : 0 score Ok, per workshop manual section 01-13B-7 to remove the oil lines you need to pull the cowl and the alternator, lol.
![]() | | #31 | ![]() |
Rep Power: 3167 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score damn thats a bitch. on the 3, you can just pull the intake/battery/egr, and pull the turbo out the side, leave the exh mani bolted to the head. good luck man.
![]() | | #32 | ![]() |
Yeah, right.
![]() | | #33 | ![]() |
| Not Ranked : 0 score FYI, here is the easiest way I found to remove the oil return line from the turbo (as done on my CX-7...with the transfer case in the way like on the MS6) : - Remove all heat shields - Get the downpipe out of the way - Remove the exhaust manifold - Remove or loosen the coolant line that is between the block and turbo (to get access to the bolt nearest the block) - Take a small (1/4) ratchet with a 8mm socket (you will need a 2’’ extension to get to the bolt nearest to the block) - Lay on the engine with your face against the cowl/wiper section, then reach the bolt from where the downpipe was (removing the exhaust manifold gives some more space...) - At that point, the only issue is applying enough torque to unscrew the bolts in this awkward position Hope this help...
| Stock catback removal - tips, tricks, gotchas? | TheRealDefman | 2010 MS3 - How-To's | 20 | 02-01-2012 09:36 PM |
| removal of exhaust manifold bolt behind turbo | dooderek | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 02-27-2011 08:07 PM |
| Stock PCV Valve Removal | dizzin9 | MazdaSpeed 3/6 - Turbo Induction | 16 | 03-09-2010 09:21 AM |
