 Old 02-14-2011, 03:55 PM   #81
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
Groans: 53
Well even with Silverdemons IM he's out flowing the stock head. It would be nice to see some of these BT guys do a before and after on some of this flow mods (IM, head work and cams). Just to get a good feel for what gains are to be had at that power level.
You know.... Moose stuff
The Following User Says Thank You to amoosenamedhank For This Useful Post:
Alpha (11-08-2011)
 Old 02-14-2011, 05:05 PM   #82
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Originally Posted by TRex View Post
^but it is safe to assume you wouldnt reach it with anything currently out there (pushing higher than 400 hp anyway)
Boost fixes all... Once your out flowing the head/cams you can still get more HP by increasing the boost....until you actually reach the choke point--which IMO we are no where near...
You just wont see the same gains per # of added boost as you would with a better flowing head and cams.
Dano (02-15-2011)
 Old 02-14-2011, 07:01 PM   #83
MS3inDC's Avatar
Posts: 3,070   (View Stats)
MS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the world
Groaned at 56 Times in 37 Posts
but steed's arent tubular...they are cast...
True, and correct me if I'm wrong, but the length of the tubular allows you to more efficiently use (apply) exhaust pulses to the turbine. Which I why I said what I did.
For a twin-scroll set up, a tubular design is more desirable because it delivers exhaust pulses to the turbine in calculated timing, allowing you to maximize pulse duration and frequency to spin the turbine resulting in quicker spool and the ability to use turbos that you would normally not move enough air to use... But usually inherently weak due to design. F-R has made their mark by producing tubular manis that can sustain incredible amounts of abuse... like cast manis...
cobb ap v3 // RICHTUNE // autotech fpi // sp63 afc // cp-e nano // htp tip // nator dc fmic // nator dc PnP intake mani // hks ssqv *vta* // cs dp // su tp
jbr rmm(88duro) // jbr pmm(80duro) // cpe tm(75duro) // act 6-puck // act streetlite fw // jbr egr delete // md occ // sure ssb // nator dc sts // jbr hw shift knob
ebc red // rx-8s wrapped in conti dws 235/40s (winter) evo Xs wrapped in conti dw 235/40s (summer) www.sonictuning.com
311 whp - 345 lb/ft : Dynojet @ Moore Automotive *93 pump [4/13/13 MNM]
12.94 @ 109.00 @ Capitol Raceway *18' ASL [11/07/14]
I would wear a pink unicorn shirt, and still call someone a faggot. Since when did MSFers begin to give fucks?...
MS3inDC is offline   Reply With Quote
The Following User Says Thank You to MS3inDC For This Useful Post:
Alpha (02-15-2011)
 Old 02-15-2011, 08:21 AM   #84
steedspeed's Avatar
Posts: 582   (View Stats)
Actually my manifolds are machined from solid steel billet on CNC machining centers with the sections then TIG welded together and then ceramic coated.
Also, the top mount version is a true twin scroll manifold.
The Following 8 Users Say Thank You to steedspeed For This Useful Post:
Alpha (02-15-2011), amoosenamedhank (02-15-2011), banditscout (02-17-2011), breakfstincluded (11-08-2011), crazyp (11-08-2011), mason (02-16-2011), Mazdanspeed3 (11-10-2011), TRex (02-15-2011)
 Old 02-15-2011, 08:22 AM   #85
TRex's Avatar
Posts: 3,139   (View Stats)
^well there ya go haha
 Old 02-15-2011, 08:33 AM   #86
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
What if anything will you be doing to accommodate this turbo in an MS3/6 application?
Alpha (02-15-2011)
 Old 02-15-2011, 08:36 AM   #87
Alpha's Avatar
Posts: 3,711   (View Stats)
+1. Leen. It would be sick if you could make us a manifold to runs these EFRs. How hard is it to shift the flange more toward the driver's side while maintaining the twin scroll design?
 Old 02-15-2011, 08:42 AM   #88
TRex's Avatar
well he already does offer a top mount twin scroll...so start there....maybe it will already work...i dont anyone believe has tried it and i dont know many running the steed mani (top mount or otherwise) but i have always wanted one...they look top notch
 Old 02-15-2011, 08:54 AM   #89
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
The HPF M3 turbo kits are serious and having your manifold with those kits is a good sign of what it can handle.
 Old 02-15-2011, 02:16 PM   #90
MS3inDC's Avatar
Regardless of how any of these are made, we need a "take-no-shit" mani for our car that will allow us to run the EFRs.
I only push for the F-R mani because I have experience with their product. Their manis are damn near works of art. However, their support of Mazda platforms has left a little to be desired in the past. Getting a reputable shop like F-R to make products for our cars would be awesome.
But don't get me wrong. If leen is the only one who wants to show mazdas some then what choice would I have. The turbo is the end goal here. As long as I can run the EFR, and shit won't break, I don't care who's name is on the mani...
Alpha (02-15-2011)
 Old 02-15-2011, 02:27 PM   #91
Alpha's Avatar
Exactly. I really hope we can get this going, an EFR on these cars would be awesome if someone stepped up to the manifold.
 Old 02-16-2011, 06:52 AM   #92
Alpha's Avatar
Thumbs up
Okay guys, HUGE NEWS!!!
I just got a response from the owner of Full-Race, Geoff. He sounds VERY cool and interested in helping us out so let's show him that the market is here with the Mazdaspeeds!
Here's the email I received:
"Hello Fernando - Thank you very much for the email, I am excited to hear about your enthusiasm for the EFR turbochargers and we are certainly interested in taking a look at your platform. As you mentioned it would be greatly appreciated for you to put together some sort of interest thread/poll (as you mentioned) in order to help us gauge what it is that the community wants. Also if you could get a handle on what fuel mgt options they are most interested in: IE: do most people use COBB? What injector size? If there is anyone local in Phoenix, AZ interested in this, I'd also like to take a look at their engine bay and take some preliminary measurements.
As you know, these EFR turbos were designed from the ground up to be "revolutionary" in their design elements in everything from the materials used to the design of the flow paths (like the wastegate you mentioned). With regards to the wasteges, we have just completed a test which showed the EFR's 42mm internal wg controlling boost *better* than an external 44mm wastegate. This was very good to see, particularly since it allows a huge amount of $$ and complexity to be saved from the turbokit. Also - we were fortunate to work with BorgWarner and Ford, integrating the EFR turbos to their 2.0L ecoboost motors which i know are similar to the L-series engines, and were able to do some testing with them.
All that being said, I just registered for the forum, and please send me a link to your thread so I may start reading up and seeing peoples' comments. Thanks Fernando, talk to you soon!
Respectfully Yours,
Geoff Raicer"
I know we have some local MS6/3s in AZ so hopefully we can get FR a mule to take some measurements from so please chim in.
I'm going to start an interest poll for Geoff so please post up here:
http://www.mazdaspeedforum.org/forum/foru...-inside-72521/
Let's make this happen guys!!!
The Following 9 Users Say Thank You to Alpha For This Useful Post:
-cj- (02-16-2011), Ckmazdaspeed3 (02-16-2011), FreeFlyFreak (02-16-2011), jayspeed3 (02-16-2011), Jedyboyrokr (02-26-2011), MGM_GT3 (02-26-2011), MS3inDC (02-16-2011), NoRegrets (02-16-2011), zx2man (02-16-2011)
 Old 02-16-2011, 08:20 AM   #93
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Paging Haltech to thread.
 Old 02-16-2011, 08:37 AM   #94
Alpha's Avatar
This is a gauging interest topic to better the aftermarket for turbo kits available to this community. Geoff isn't selling anything yet. Relax.
The Following 2 Users Say Thank You to Alpha For This Useful Post:
FreeFlyFreak (02-16-2011), SpeedSixxx (02-26-2011)
 Old 02-16-2011, 09:15 AM   #95
Enki's Avatar
Groans: 189
I am relaxed. Just making sure Geoff gets a warm welcome and Hal is in the know.
Alpha (02-16-2011)
 Old 02-16-2011, 09:38 AM   #96
MS3inDC's Avatar
Word, cuz right now Geoff is a brownie...
 Old 02-16-2011, 10:29 AM   #97
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
oh god...that could be bad LOL
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
The Following User Says Thank You to Cataphract_40 For This Useful Post:
 Old 02-16-2011, 05:32 PM   #98
steedspeed's Avatar
It is a very simple task. I could probably just mirror image the CAD file as the turbo flange is already offset to one side. Total redesign time about 1 minute lol!
Manifold will work fine with MS6 and we are close to getting it worked out for the 3 too.
The Following User Says Thank You to steedspeed For This Useful Post:
Fobio (02-16-2011)
 Old 02-16-2011, 06:33 PM   #99
Tokay444's Avatar
Groans: 793
What kind of maths are involved for calculating runner length vs pulse length so that the twin scroll is fully efficient?
 Old 02-16-2011, 07:42 PM   #100
Groans: 60
I'm sure there is some horribly complex equations that will give you the perfect runner diameter and length for your engine/turbo/boost, but once you work it through, good luck fitting it under your hood...
IMO, you just need to pair the cylinders properly, and try to keep the runners as close to equal length as possible--it might not get you the 100% perfect twin scroll setup, but I'm sure it'll get you 95-99% of the same performance...
The Following 4 Users Say Thank You to SSinstaller For This Useful Post:
Alpha (02-16-2011), Enki (02-17-2011), Fobio (02-25-2011), xcoldricex (02-17-2011)
 Old 02-17-2011, 12:25 PM   #101
Alpha's Avatar
Twin Scroll 7064? What?
 Old 02-17-2011, 01:15 PM   #102
MS3inDC's Avatar
Tasty bits.
I did read that for some transversal applications that the IWG may not be an option -- the compressor housing would be too large
I don't want to jump the gun, but there are so many possibilities. I just know that my turbo is probably already smoking and I don't even know it. So replacing the K04 fail snail with some state-of-the-art shit will be a top priority.
 Old 02-17-2011, 01:23 PM   #103
Rayd's Avatar
Posts: 171   (View Stats)
Rayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond repute
Hrrm, a small part of me wants my K04 to fail O.o
05 MPS 6 - Self Tuned
Borg Warner EFR T4 Twin Scrolled, Forged Block, Snow Performance S3 WMI, 5th/6th Port Injection, CPe: Ex Mani, Custom intake 3.75" MAF, CPe HPFP, Injector Seals, REM, SURE: Rear Diff Front mount & Brace, TIG's; Tial EWG, HDI FMIC, Custom 3" TBE, 3.5-Bar MAP sensor, AWR SEM, SouthBend S4 Clutch, Custom Head Unit, Car-LED Tails, 6000K HIDs, Auto Head-light Kit, Mugen Visors, LED conv., BC Coilovers, SPC Ball Joints, Brembo BBK
Rayd is offline   Reply With Quote
The Following User Says Thank You to Rayd For This Useful Post:
Alpha (02-17-2011)
 Old 02-18-2011, 09:01 AM   #104
steedspeed's Avatar
I think the best thing would be to try and get hold of a turbo to see how best to locate it in the engine bay. With the long outlet to the turbne it might need to be pushed over to one side substantially to make it easier to fit the downpipe.
On the + side though the turbo makes the manifold a much simpler design with no EWG ports so the price would be more around the $550 range which helps cover the extra cost of the turbo. Also don't need to spend $250 per wastegate and no need to buy a BOV so all in all this is probably the best value turbo upgrade there is.
Hence I will make this one a priority.
The Following 10 Users Say Thank You to steedspeed For This Useful Post:
802MS3 (02-25-2011), Alpha (02-18-2011), amoosenamedhank (02-18-2011), Enki (02-18-2011), Fobio (02-25-2011), Jedyboyrokr (02-26-2011), NoRegrets (02-18-2011), Speed3eak (02-25-2011), Tokay444 (02-18-2011), triplejumper18 (02-25-2011)
 Old 02-18-2011, 09:12 AM   #105
Alpha's Avatar
Thumbs up
Right, the simplicity of it is attractive in it's own right, let alone the performance benefts.
 Old 02-18-2011, 09:50 AM   #106
Groans: 53
If it can give you ATP simplicity without the ATP creep issues or EWG expensive and hassle... how could it not be win?!
I would much rather spend money on a quality turbo than supporting mods for another.
Alpha (02-18-2011)
 Old 02-25-2011, 09:44 AM   #107
steedspeed's Avatar
I just built a T3 flanged IWG manifold. If someone is up to the task of trying it with one of these turbos they can have the manifold for $450 shipped.
The Following 4 Users Say Thank You to steedspeed For This Useful Post:
Alpha (02-25-2011), amoosenamedhank (02-25-2011), Fobio (02-25-2011), Speed3eak (02-25-2011)
 Old 02-25-2011, 12:41 PM   #108
turboneil's Avatar
Posts: 248   (View Stats)
turboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond repute
Someone jump on this! I would if my car wasn't my DD.
turboneil is offline   Reply With Quote
 Old 02-25-2011, 02:36 PM   #109
Tokay444's Avatar
Groans: 793
that's some quick turnaround right there.
kudos.
 Old 02-25-2011, 09:51 PM   #110
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
just a small matter of actually having one of these turbo's handy for a test fit...lol...
thanks for looking out leen...
-- Mario Andretti --
 Old 02-26-2011, 01:33 AM   #111
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Top Mount?
 Old 02-26-2011, 09:22 AM   #112
steedspeed's Avatar
Top Mount?
I have either but I'm also seeing if the top mount can be flipped and change the turbo flange angle to allow bottom mount TS.
Top mount will work fine on MS6 already but no sure on these turbos with the MS3. I hear they are slimmer than an equivalent hp Garrett
Fobio (02-26-2011)
 Old 11-06-2011, 02:43 PM   #113
InFeXIoN's Avatar
Posts: 1,159   (View Stats)
InFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the world
Groaned at 42 Times in 15 Posts
So whatever happened to all this?
GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff.
Build Complete!!!!
InFeXIoN is offline   Reply With Quote
The Following User Says Thank You to InFeXIoN For This Useful Post:
f-castrillo (11-06-2011)
 Old 11-06-2011, 08:24 PM   #114
Alpha's Avatar
Thumbs up
My 6 along with another member's 3 are currently at Full Race getting mocked up for their new EFR kits as we speak.
 Old 11-07-2011, 06:58 AM   #115
Groans: 53
You actually drove your car down to Phoenix for this? Wow... that's dedication.
InFeXIoN (11-08-2011)
 Old 11-07-2011, 10:13 AM   #116
Alpha's Avatar
Nah, I had it transported bro.
 Old 11-08-2011, 02:27 AM   #117
paveltol's Avatar
Posts: 520   (View Stats)
How much time will it take to test the kit?
paveltol is offline   Reply With Quote
 Old 11-08-2011, 09:29 AM   #118
Alpha's Avatar
I'm sure Full Race will chim in with progress and projections as things take form.
They already have the manifold prototype made, FMICs nearly completed etc so... Not bad for only having an MS3 and my MS6 in the shop for a couple weeks.
I'd post all your questions in the main thread: http://www.mazdaspeedforum.org/forum/foru...-inside-72521/
Thanks!
 Old 11-08-2011, 04:39 PM   #119
InFeXIoN's Avatar
Sounds good man. Cant wait for this to become available. Very interested.
Build Complete!!!!
Alpha (11-08-2011)
 Old 11-05-2018, 06:05 PM   #120
brownv157643's Avatar
Posts: 1   (View Stats)
brownv157643 can only hope to improve
Groaned at 3 Times in 1 Post
Default MPS6
I'm new here to the forum just saying hey to every one.
My car 06 MPS6
Thanks,
Andrew
brownv157643 is offline   Reply With Quote
The Following 3 Users Say NO Thank You to brownv157643 For This Un-useful Post:
JSmith (11-05-2018), Thor Hammer (11-08-2018), Vansquish (11-06-2018)
Bullseye / Borg Warner .55 A/R T3 S256 Turbo, Need input! JumpingJackson MazdaSpeed 3/6 - Turbo Induction 5 09-03-2009 07:45 AM
Nissan studying turbochargers for future vehicles? Haltech Automotive News 0 08-03-2009 12:00 PM
Honeywell discussing U.S. gas turbochargers with GM Haltech Automotive News 1 09-16-2008 03:42 PM
Honeywell to sell turbochargers to Ford in U.S. Haltech Automotive News 0 07-30-2008 10:50 AM
Page generated in 0.59829 seconds with 37 queries
