![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
(Thread Starter) | Not Ranked : 0 score BorgWarner EFR Turbos | Full-Race.com These also have a built in EBC AND BPV for super responsive and efficient means. Please SOMEONE step up and built a kit around these so I don't have to go custom! These will change everything for us, I can feel it. IWG simplicity across the board is priceless IMHO. Let's dig in! ![]() Props to SSinstaller for giving me the heads up!
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() Last edited by Alpha; 01-27-2011 at 03:32 PM. |
| The Following 13 Users Say Thank You to Alpha For This Useful Post: | Ckmazdaspeed3 (01-27-2011), FreeFlyFreak (01-27-2011), I Love Brownies (01-27-2011), kgb (01-27-2011), Kydizzle (01-27-2011), labikesrcool (01-27-2011), MGM_GT3 (01-30-2011), PunjabiPlaya (01-30-2011), RichieRichness (10-29-2013), SpeedSixxx (02-26-2011), SSinstaller (01-27-2011), TRex (01-27-2011), triplejumper18 (01-30-2011) |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
| Not Ranked : 0 score sounds awsome...if i am reading it right we could eliminate need of a bpv on the IC piping...utilize the stock EBCS (but with the Borg solenoid) and leave it as an IWG...really all that leaves is lines and a manifold to fit it... |
| The Following User Says Thank You to TRex For This Useful Post: | Alpha (01-27-2011) |
![]() Honestly, I don't think anyone really WANTS to run EWG, they've just been forced to do it to ensure boost control. This changes everything as that's no longer an issue! Plus the efficiency, quick spool, and overall design is simply unmatched in performance!
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() | |
| The Following User Says Thank You to Alpha For This Useful Post: | FreeFlyFreak (01-27-2011) |
| Not Ranked : 0 score no not even a custom intake...look at the specs for the 6258 (which i think would be perfect) 2.5" intake...you can use any intake that fits the k04...or is the k04 2.25? i forget....regardless it wouldnt be too bad at all |
| The Following User Says Thank You to TRex For This Useful Post: | Alpha (12-17-2015) |
| Team Überfrazn ![]() Join Date: Apr 2008 Location: Plymouth, MN
Rep Power: 324 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 661
| Not Ranked : 0 score geez these things are all in one packages. all they need is the port to mount the injector for the anti-lag haha.
__________________ "My car won't start!" "Well, maybe there's a killer after you."-Mitch Hedberg I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming. - Mitch Hedberg |
| The Following User Says Thank You to labikesrcool For This Useful Post: | Alpha (01-27-2011) |
(Thread Starter) | Not Ranked : 0 score And techincally cheaper than the ATP's considering you don't need an EBC or BPV. Someone use these in a kit or make us DPs!
| Not Ranked : 0 score shouldnt be hard to find a 3" v-band....lots of guys on here are running custom 3" v-bands |
They do have a twin scroll T4 flange available in the smaller line. Or a T3 once you hit the 7064 series.
| Not Ranked : 0 score i guess it would depend on your power goal...personally im liking the 6258....350+ with stock like spool...what could be better? |
![]() Join Date: Jun 2010 Location: Ottawa
Rep Power: 617 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 526
| Not Ranked : 0 score The T-25 Flange is used on turbos up to and including a GT3076 50/0.60 The GT3076 is rated up to 525WHP... It would be fine unless you were trying to run a turbo that was larger than that..
__________________ |
![]() Join Date: Jan 2010 Location: Rosemount, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 946
Groans: 53
| Not Ranked : 0 score Seems like if you could get leen to make you a T25 manifold and grab yourself a V band DP you could get up and running fairly easy.
__________________ You know.... Moose stuff |
| The Following User Says Thank You to amoosenamedhank For This Useful Post: | Alpha (01-27-2011) |
I don't think 340-360 AWHP would be hard to hit reliably with that!
Groans: 60
| Not Ranked : 0 score Their IWG is a work of art...
| The Following User Says Thank You to SSinstaller For This Useful Post: | Alpha (01-27-2011) |
| Not Ranked : 0 score i would recommend comparing the compressor map of both the 6258 and 6758 alpha...i really think you will be running more efficiently with the 6258 under at that power level... |
Groans: 53
Stupid compressor maps and all their lines.
__________________ You know.... Moose stuff | |
(Thread Starter) | Not Ranked : 0 score Yeah? I'm really trying to leave a little room for growth and potentially forged internals and 400 AWHP someday. Plus, with the quick spool characteristics, I think it'd be a pretty good happy median in the meantime. Keep in mind that the MS6 driveline eats A LOT of power before making AWHP.
Groans: 60
| Not Ranked : 0 score go here to find your turbo BorgWarner MatchBot Use the outputs to see where you'll be sitting on the compressor maps for the various turbos..
| Not Ranked : 0 score 6258 ![]() 6758 |
![]() Join Date: Mar 2010 Location: Spanaway, Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 146
| Not Ranked : 0 score im gonna save my pennys up for a build with these turbos. looks real nice
__________________ 2008 Silver MS3 GT - BNR S2, CP-E HPFP, CP-E Nano, Cobb FMIC, Cobb AP(E-85 Mix [FREEKTUNE]), GrimmSpeed EBCS, CNT Exhaust, Corksport DP, SU Test Pipe W/ Magnaflow HFC, Forge BPV v1, EGR Delete, AWR RMM, SU Shifter Bushing, CP-E Towplate, BC Coilovers, Cobb RSB, Motegi SP-10 HyperBlack(19lbs) |
Groans: 60
| Not Ranked : 0 score you need at least .38 kg/sec for 20psi at 7K rpm --6258 and 6758 are too small.. 7064 is good 7670 is great 8374 would be a bad ass high boost turbo..
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks Last edited by SSinstaller; 01-27-2011 at 04:06 PM. |
| The Following 3 Users Say Thank You to SSinstaller For This Useful Post: |
| Not Ranked : 0 score ^my man is right that calculator helps a lot...sry for jumping the gun with 6258 praise...ima have to play with this a bit at 18 psi on the 6258 i wasnt even putting down 305 hp till 5500 rpm this calculator is awsome |
![]() | | #24 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score how about the 7064 BorgWarner EFR 7064 Turbo - Full-Race.com and its on sale... only +$200 from the 62xx
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
![]() | | #25 | ![]() |
![]() Join Date: Dec 2010 Location: Marietta, Ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
MX-5 EFR Turbo Build | |
![]() | | #26 | ![]() |
Groans: 60
BorgWarner EFR 7670 Turbo - Full-Race.com It'll spool slower, but that's not really a bad thing.. It should still hit 20psi around 3.5K rpm.. IMO it's a better turbo than my GT35R, I wish it was available when I did my build..
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks Last edited by SSinstaller; 01-27-2011 at 04:47 PM. | |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Hey ss what values would you use for the various inputs on th calculator? could you just put them in and post the link here (it retains the values)? i was playing arond and cant get a setup to work efficiently with the 7064.... im doing rpm points 3000-5500 in steps of 500 i cant quite get the first or last point to get to the 70 comp .83 a/r phi line... nevermind i figured it out but what exactly is wastegate choke? is it turbine choke? i.e. no more increase in mass flow? im guessing you want to try and avoid this ya? ok read some more...i think creep begins to occur once the wastegate has become choked....right? since you cant flow any more (mass) past the choke point... using the calculator at the top end i would require a 30 mm WG...there is no info on the Borg site stating their IWG size...anyone know the k04 IWG size? Last edited by TRex; 01-28-2011 at 07:31 AM. |
![]() | | #28 | ![]() |
if you go 70 or bigger you'll probably need a top turbo mount set up and FMIC. TMIC would not work. The 6758 should be good for 17 to 18 psi at red line depending on AITs ( edit: at sea level) and you could use a regular low (?) mount manifold and a TMIC. I've taken a few measurements and I am not sure whether the 6758 will fit in the stock location. It is about 2" longer than the K04 and has 3.25" V band flange. I am not sure if it would clear the alternator once the V-band DP goes on. If tit does it would definitely be tight unless you get a manifold with a collector that extends more toward the drivers side. Using the Matchbot calculation do not pay attention to the "wastegate choked yes/no" part. To get all points on the expansion ratio to give you a NO you would need a huge hot side/wastegate. The 36mm Internal wastegate should be plenty for our engines. There would be some boost creep but it would be minimal. Way less than even the 8 psi spring pressure which IIRC is the lowest spring pressure they offer out of 3 different ones. The K04 wastegate is about 25mm.
__________________ Last edited by Tomas; 01-30-2011 at 03:32 PM. | |
| The Following User Says Thank You to Tomas For This Useful Post: | TRex (01-31-2011) |
![]() | | #29 | ![]() |
Groans: 60
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
| The Following User Says Thank You to SSinstaller For This Useful Post: | TRex (01-31-2011) |
![]() | | #30 | ![]() |
| Not Ranked : 0 score got it..thanks tomas and ss....yea tomas i was looking at the sizing of the efr and it seems like it would be a bear....but top mount turbo may not be so bad.... |
![]() | | #31 | ![]() |
I definitely want to go T4 twin scroll either way.
![]() | | #32 | ![]() |
Groans: 60
And if you do decide to build the motor down the road, you don't have to add the expense of swapping the turbo again...
| The Following User Says Thank You to SSinstaller For This Useful Post: | Alpha (02-09-2011) |
![]() | | #33 | ![]() |
With twin scroll, the manifold would have to be designed diferently right?
![]() | | #34 | ![]() |
Groans: 60
![]() | | #35 | ![]() |
"A twin scroll turbine housing uses dual side by side passages into the housing. When coupled with a pulse converter manifold that separates exhaust pulses as many crank degrees in the firing order as possible, a twin scroll or divided housing works to reduce lag, decrease exhaust manifold backpressure on the top end, reduce the potential for reversion, and increase fuel economy. The twin scroll is based off the same reasoning a tri-Y header uses: keep spent exhaust gases out of an adjacent cylinder drawing in fresh air. At high rpm on a turbo car, exhaust backpressure is usually significantly higher than atmospheric pressure, and often higher than intake manifold pressure as well. A divider between each of the two volutes allows the cylinders to expel the exhaust gases without it interfering with the fresh air for combustion. Since there are two openings, each a smaller overall volume than a single scroll design, the exhaust velocity of each pulse can be maintained. This also spins the impeller more easily because lag is a function of the scroll area. A single turbine housing opening isn't as efficient since cylinders on the exhaust stroke of the 4 stroke cycle contaminate the cylinders that are on overlap with exhaust gas. A conventional turbine housing is not as effective in using exhaust pulse energy to help spin the turbine up to speed as it does not exploit the energy contained in the pulses as well." More info on the benefits of a twin scroll setup: http://www.full-race.com/modified-twinscroll/index.html
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() Last edited by Alpha; 02-10-2011 at 12:12 PM. | |
![]() | | #36 | ![]() |
Groans: 60
It shouldn't be a problem for any decent fabricator..
![]() | | #37 | ![]() |
![]() | | #38 | ![]() |
__________________ | |
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score I don't think it's twin scroll. Could be wrong though.
![]() | | #40 | ![]() |
![]() Join Date: Apr 2008 Location: Atlanta, GA
Rep Power: 334 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 247
| Not Ranked : 0 score |
| The Following User Says Thank You to MS6_Auburn_Fan For This Useful Post: | Alpha (02-10-2011) |
| Display Modes | |
| Bullseye / Borg Warner .55 A/R T3 S256 Turbo, Need input! | JumpingJackson | MazdaSpeed 3/6 - Turbo Induction | 5 | 09-03-2009 07:45 AM |
| Nissan studying turbochargers for future vehicles? | Haltech | Automotive News | 0 | 08-03-2009 12:00 PM |
| Honeywell discussing U.S. gas turbochargers with GM | Haltech | Automotive News | 1 | 09-16-2008 03:42 PM |
| Honeywell to sell turbochargers to Ford in U.S. | Haltech | Automotive News | 0 | 07-30-2008 10:50 AM |
