Like Tree3Likes
  • 3 Post By Vansquish
 Old 08-04-2014, 07:58 PM   #1
scottlnt57's Avatar
Posts: 24   (View Stats)
scottlnt57 is a name known to allscottlnt57 is a name known to allscottlnt57 is a name known to allscottlnt57 is a name known to allscottlnt57 is a name known to allscottlnt57 is a name known to all
Default NEW DOWNPPIPE/HPFP/TURBO
HELLO i just installed a Down pipe that is catless, also a new K04 turbo and high pressure fuel pump. i am running with a stage 2 cobb tune. but going into WOT my car starts to pop a lot when i really get into it.
Mods are
Down pipe hatless
Cork-sport HPFP brand new from yesterday
brand new K04
sure motor sports short ram back from turbo
greddy type rs BOV vented to atmosphere.
Cobb acesse port tuner
No check engine light or anything leaking. just confused
any help would be great.
2007 MazdaSpeed 3
I am A NOOB!! CHILL
scottlnt57 is offline   Reply With Quote
 Old 08-04-2014, 08:04 PM   #2
Colepidd55's Avatar
Posts: 211   (View Stats)
Colepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond repute
Do a log and post it.
SOLD
2009 CWP Speed3
Cobb Ap/AT Internals/Cobb Downpipe/Cobb SRI,TIP/TS BPV/sure shortcut/JBR 88a RMM/JBR TMM/JBR solid shifter bushings/Freektune OTS+
Colepidd55 is offline   Reply With Quote
 Old 08-04-2014, 08:04 PM   #3
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
There you go
The Following 7 Users Say Thank You to SarcasticOne For This Useful Post:
1cms1 (08-04-2014), chaser27 (08-04-2014), CWP_MS3 (08-05-2014), Easter Bunny (08-04-2014), Hargarbl (08-04-2014), taf0422 (08-04-2014), Vansquish (08-04-2014)
 Old 08-04-2014, 08:04 PM   #4
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Take some logs so we can see whats going on.
And your car needs to be custom tuned for vent to atmosphere. Ots maps are not set up for that
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 08-04-2014, 08:14 PM   #5
scottlnt57's Avatar
alright hold on
2007 MazdaSpeed 3
I am A NOOB!! CHILL
 Old 08-04-2014, 08:36 PM   #6
scottlnt57's Avatar
ok so update i am currently downloading the cobb racer tuner. forgot to do it earlier today. so ill have it up tomorrow
2007 MazdaSpeed 3
I am A NOOB!! CHILL
 Old 08-04-2014, 08:39 PM   #7
That has nothing to do with taking logs...
Use access port manager
The Following 2 Users Say Thank You to SarcasticOne For This Useful Post:
Easter Bunny (08-04-2014), MazdaBoy2.3 (08-05-2014)
 Old 08-04-2014, 08:39 PM   #8
scottlnt57's Avatar
ahh i did not know this. all knew
2007 MazdaSpeed 3
I am A NOOB!! CHILL
 Old 08-04-2014, 08:45 PM   #9
scottlnt57's Avatar
i believe this is the file. i have many logs on here that i am not sure of which one. i am learning how this works as of right now so bare with me.
thanks
2007 MazdaSpeed 3
I am A NOOB!! CHILL
 Old 08-04-2014, 09:23 PM   #10
thanks
Epic long log, didn't need that much info, but yes, looks like your vta bov is to blame as every time you let off throttle, your AFR's go rich...
Car is expecting air to recirculate, you're letting it into the atmosphere, so there is too much fuel going in on shifts... Change it to recirc, problem fixed...
Or get a proper tune...
Easter Bunny (08-04-2014), Vansquish (08-04-2014)
 Old 08-04-2014, 09:23 PM   #11
Police - Grammarhead
Vansquish's Avatar
I hate to do this to a fellow Michigander, but I just can't let this all slide.
1. You need to read literally everything in your welcome PM and the associated links.
2. You need to read more about the platform before just throwing parts at your car. You've added something that can result in ZZB if not properly tuned-for (the BOV).
3. Your communication skills could use a significant improvement.
Hello, Ijust installed a down(removed space)pipe that is catless, as well as a new K04 turbo and a high pressure fuel pump. I am running with a stage 2 Cobb tune, but going into WOT my car starts to pop a lot when I really get into it. (This is redundant. How can you be at WOT and not, "really get into it?")
Mods are:
Down(removed space)pipe catless
brand new Cork(deleted hyphen)sport HPFP (deleted "from yesterday")
brand new K04
Sure Motor(deleted space)sports Full Intake (Short Ram Intake + Turbo Inlet Pipe (deleted "short ram back from turbo"))
Greddy Type RS BOV vented to atmosphere.
Cobb Accessport (wtf is "acesse?") tuner
There's no check engine light or anything leaking, I'm just confused, and any help would be great.
First, a note about your grammar and spelling:
- You should aim for consistency in the way you list things. If it's "a ___, a ___, and ____" the sentence doesn't work as well as when it's "a _____, a _____, and a____."
Second:
- You should not be running a BOV without a custom tune designed to compensate for it. The stock system uses a bypass valve (BPV) that recirculates air back into the intake tract. The air it circulates is metered, so the ECU is expecting to see it. By running a BOV in VTA mode, you're letting that metered air escape from what should be a "closed" intake system.
- You should also know exactly what intake you're running. SURE Motorsports is a pariah on MSF, as they've produced some parts that are potentially very deadly (I mean this with deadly sincerity), and some that have simply fallen apart with normal use. That said, they have several different intakes on offer, and some of them have larger-than-stock MAF housings. Such an intake with a larger MAF requires customized MAF calibrations in order for the car to run normally and safely.
Alright, hold on.
Ok, so here's an update I am currently downloading the Cobb AccessTuner Race (ATR) (deleted "racer tuner"). I forgot to do it earlier today, so I'll have it up tomorrow.
Ahh, I did not know this, this is all new (deleted, "knew")
You need to learn your homophones. "New" and "knew" do not mean the same thing.
I believe this is the file. I have many logs on here, so (deleted "that") I am not sure (deleted "of") which one is which. I am learning how this works as of right now, so bear (deleted "bare") with me.
Thanks.
Again, you need to learn your homophones. "Bear" is the thing that eats you in the woods while you're "bare" naked.
cnote308, WetzMS3 and 1cms1 like this.
The Following 8 Users Say Thank You to Vansquish For This Useful Post:
Addikted To Boost (08-05-2014), CWP_MS3 (08-05-2014), Easter Bunny (08-04-2014), Gorky_Park (08-02-2015), magicka (08-05-2014), Scare Dem (08-05-2014), someguy (08-04-2014), WetzMS3 (08-04-2014)
 Old 08-04-2014, 09:33 PM   #12
scottlnt57's Avatar
I hate to do this to a fellow Michigander, but I just can't let this all slide. 1. You need to read literally everything in your welcome PM and the associated links. 2. You need to read more about the platform before just throwing parts at your car. You've added something that can result in ZZB if not properly tuned-for (the BOV). 3. Your communication skills could use a significant improvement. First, a note about your grammar and spelling: - You should aim for consistency in the way you list things. If it's "a ___, a ___, and ____" the sentence doesn't work as well as when it's "a _____, a _____, and a____." Second: - You should not be running a BOV without a custom tune designed to compensate for it. The stock system uses a bypass valve (BPV) that recirculates air back into the intake tract. The air it circulates is metered, so the ECU is expecting to see it. By running a BOV in VTA mode, you're letting that metered air escape from what should be a "closed" intake system. - You should also know exactly what intake you're running. SURE Motorsports is a pariah on MSF, as they've produced some parts that are potentially very deadly (I mean this with deadly sincerity), and some that have simply fallen apart with normal use. That said, they have several different intakes on offer, and some of them have larger-than-stock MAF housings. Such an intake with a larger MAF requires customized MAF calibrations in order for the car to run normally and safely. You need to learn your homophones. "New" and "knew" do not mean the same thing. Again, you need to learn your homophones. "Bear" is the thing that eats you in the woods while you're "bare" naked.
I will be quite honest I am not that good at spelling and it is something I am trying to work on. Thank you for looking over my log. This is embarrassing that you went through and picked out the flaws in my spelling but non the less I appreciate it.
To further help me with a custom tune, any good shops that tune/Dyno in Easter part of Michigan?
2007 MazdaSpeed 3
I am A NOOB!! CHILL
The Following User Says Thank You to scottlnt57 For This Useful Post:
 Old 08-04-2014, 09:35 PM   #13
Stop posting and read everything in your welcome pm. You are on the short road to a blown motor and you are quickly going to run out of helpful people.
Vansquish (08-04-2014), WetzMS3 (08-05-2014)
 Old 08-04-2014, 09:36 PM   #14
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
that ticket kinda got punched when you posted.
Mods: stock
The Following 3 Users Say Thank You to faeker For This Useful Post:
Easter Bunny (08-05-2014), Vansquish (08-04-2014), WetzMS3 (08-05-2014)
 Old 08-04-2014, 09:39 PM   #15
Vansquish's Avatar
I will be quite honest, I am not that good at spelling and it is something I am trying to work on. Thank you for looking over my log. This is embarrassing that you went through and picked out the flaws in my spelling, but nonethe(deleted space)less I appreciate it.
To further help me with a custom tune, are there any good shops that tune/Dyno in Eastern part of Michigan?
I would strongly recommend that you read what's in your welcome PM, read what's in the links therein, and then (or maybe before then) get in touch with one of the e-tuners on here. I wouldn't trust a shop to tune one of these cars. Most shops have no idea what the hell they're doing when it comes to this motor/platform.
(As for the spelling, having gone through the rigors of law school, I've become something of a spelling/grammar Nazi. I don't do it so much out of spite, as out of the will to "issue spot" and make communications easier for everyone in the long run. On that note, you're clearly quite capable of communicating quite well, and when you do, it'll get much more positive responses from pretty much anyone with whom you communicate.)
The Following 3 Users Say Thank You to Vansquish For This Useful Post:
Easter Bunny (08-05-2014), someguy (08-04-2014), WetzMS3 (08-05-2014)
 Old 08-04-2014, 09:56 PM   #16
scottlnt57's Avatar
i would like to say thank you to the nice and helpful people on this thread that have given me good guidance. For the rest i understand that you are upset and i apologize. I use this forum for tools to help me to further my knowledge on this wonderful platform.
There will always be haters and people who say mean things but, i don't take it personally because i know the rude and mean remarks are only their to help me in the long run.
Thank you
Scooter
2007 MazdaSpeed 3
I am A NOOB!! CHILL
The Following 4 Users Say Thank You to scottlnt57 For This Useful Post:
CWP_MS3 (08-05-2014), Easter Bunny (08-05-2014), kolosok17 (08-05-2014), Vansquish (08-04-2014)
 Old 08-05-2014, 04:46 AM   #17
What? I'm always helpful I just don't sugar coat it.
Besides now you are here and with tokay being too busy thats like 2/2 of the troll patrol.
faeker (08-05-2014)
 Old 08-05-2014, 07:16 AM   #18
6Y MAZDA's Avatar
Posts: 1,775   (View Stats)
Long story short....Put your stock BPV on...problem solved. How many times/ways do you have to hear it to understand?
1996 Miata
 Old 08-05-2014, 09:09 AM   #19
scottlnt57's Avatar
wait so I'm supposed to re-install my BPV? I'm sorry that was mean Hahaha. Really tho i am going to try to acquire a custom tune to keep my happy speshhhhhhhh noise.
2007 MazdaSpeed 3
I am A NOOB!! CHILL
 Old 08-05-2014, 09:28 AM   #20
Jester2552's Avatar
Posts: 126   (View Stats)
Jester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the world
Cool sound or a shitty running car....seems pretty simple to me.
2007 Black MS3
CorkSport Turbocharger, HTP 3" Intake, CorkSport Catless Downpipe, CorkSport Catless Testpipe, CorkSport Catback, Tial 38mm EWG, GrimmSpeed EBCS, Bosch 3 Bar MAP Sensor, Forge V1 BPV, Cobb AcessPort, CP-e Stage 2 RMM, JBR Rear Sway, Moog Endlinks, ETS TMIC, AT Internals, JBR IM/TB TIG, Bilstein B8s, Cobb Springs, Rays Gram Lights 57C6 18X8.5 ET45, 235/40 Ventus RS-3,
Tuned by Nishan
USAF 2W1 "Warheads on Foreheads"
Jester2552 is offline   Reply With Quote
 Old 08-05-2014, 09:30 AM   #21
scottlnt57's Avatar
hahaha I know guys.
2007 MazdaSpeed 3
I am A NOOB!! CHILL
 Old 08-05-2014, 09:50 AM   #22
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
I'll say it again, I've been running my HKS VTA for 2 years with no specific tuning for it and I have no issues. If the valve is designed to run VTA then it will seal under all non-operational conditions and the only indication that you're running differently is a slightly rich just-off-throttle/clutch-in condition.
The log you posted shows no particular issue that I can see, you go rich when the throttle drops substantially but I don't see anything other than that. That's to be expected with a bov. You do go quite rich admittedly but that could be a MAF cal problem.
If your valve is malfunctioning that's a different issue. But in a properly working VTA setup there should be no drivability issues and definitely not whatever is supposedly happening at WOT for you
Blue Pu.
 Old 08-05-2014, 10:07 AM   #23
dan7225's Avatar
Posts: 511   (View Stats)
How To: Stratified Tune
 Old 08-05-2014, 12:05 PM   #24
scottlnt57's Avatar
The knock sensor reading hits .7 to 1.0 sometimes. Would this be a sign of things to come? Am I ok with that number since I have you here.
2007 MazdaSpeed 3
I am A NOOB!! CHILL
 Old 08-05-2014, 12:44 PM   #25
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
There is no set "number"... there are MANY variables involved.
 Old 08-05-2014, 12:45 PM   #26
scottlnt57's Avatar
Ok, well that is good to know. Thank you
2007 MazdaSpeed 3
I am A NOOB!! CHILL
Corksport HPFP or Autotech HPFP? El Beaner Gen2 MS3 General Discussion 76 05-25-2017 07:55 PM
Autotech HPFP Back in stock!!! @ CTS Turbo! CTS Turbo 2010 MS3 - Turbo Induction 18 04-24-2012 07:06 PM
Autotech HPFP internals $349.96 SHIPPED @ CTS TURBO! CTS Turbo 2010 MS3 - Fuel, Nitrous & Water Injection 8 04-24-2012 07:06 PM
Page generated in 0.45890 seconds with 32 queries
