![]() Join Date: Nov 2009 Location: Collinsville, IL (St Louis metro)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 10
(Thread Starter) | Not Ranked : 0 score I recently replaced the test pipe due to a catless downpipe and upgraded the with new HPFP internals. New spark plugs while I was in there too (NGK's 1 range colder). I have been trying several Stage2 maps and currently running Stage2+SF+TIH+IC 91 and still getting frequent fuel cuts. AP shows the fuel pressure is over 1600 all the way through RPM ranges. BAT is 110 degrees. Boost spikes to 20psi and settles at 18psi. Not showing any knock either. Yet it fuel cuts.
__________________ 06 MazdaSpeed 6 Downpipe, full intake, Forge BPV, TPMIC, HPFP internals, Barone short shifter, and AP tuner |
![]() Join Date: Feb 2012 Location: so cal
Rep Power: 1301 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 649
| Not Ranked : 0 score Worthless with out logs.. Post the map also if you want quick answers.
__________________ Sold: 2010 MS3 siLver. E85(25%) - Stratified DynoJet - 307//357 Suspension: H&R springs//Sensen Mazda5 struts; TB Performance TractionBar//Trunk Brace Brakes: CorkSport Pads; Centric Blanks Other: UltraGaugeEM; JBR 88D Rmm; JBR SSP//Bushings; EGR unplug;CF 3m vinal on trim in side car Official 60-100mph Times Official Video battles Official Youtube Channels
:-( 2014 - Dodge Dart.. (Blue Turtle) | |
| The Following User Says Thank You to ms3rick For This Useful Post: | kritz (09-25-2013) |
(Thread Starter) | Not Ranked : 0 score Fair enough, I wasn't thinking clearly. I will log some driving tomorrow and share my joy.
![]() Join Date: Jun 2009
| Not Ranked : 0 score While awaiting the logs, I'll ask a simple question about plug gap. What is it? Check. The NGK 6510 (one step colder iridium), plugs are an excellent choice, but they do not come pre gapped. The out-of-the box gap is huge, .045" or more. Make sure you gapped them down to .028" or even .026". If the gap is too big, you will get spark plug boost induced blow out with high boost, high load situations, typically at 4,000-5,000 rpm when WOT in higher gears. It acts like fuel cut.
| The Following 2 Users Say Thank You to MSMS3 For This Useful Post: | roth4fun (09-25-2013) |
![]() Join Date: Aug 2012 Location: Mundelein, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 322
| Not Ranked : 0 score You can mess with wgdc or raise your fuel cut by 1 psi if you go into atr. There is a fuel cut boost limit table.
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! |
| Not Ranked : 0 score One more thought. Are you logging throttle body position? If your fuel pressure stays steady but the car surges, it may be throttle close/cut. Ots maps go to throttle close first before they go to fuel cut.
Oddly enough my drive home from work I could not get it to cut out. Pulled hard in all gears, which was fun. Also I left my USB cable at the office. Will have to attempt again with the morning commute and upload datalogs if it occurs tomorrow.
__________________ 06 MazdaSpeed 6 Downpipe, full intake, Forge BPV, TPMIC, HPFP internals, Barone short shifter, and AP tuner | |
| Not Ranked : 0 score No need to be embarrassed. It happens to many guys that make the switch. And it will eventually happen again when your plugs open up from wear. Now that you know that the plugs were not regapped, you should know that if you are running over 15psi boost you WILL experience spark blowout under high flow, high load conditions. That problem needs correcting before chasing anything else on your logs.
| The Following User Says Thank You to MSMS3 For This Useful Post: | rfinkle2 (09-26-2013) |
![]() Join Date: Nov 2010 Location: Lido Beach,NY
Rep Power: 8624 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,845
Groans: 95
| Not Ranked : 0 score Get a custom tune,OTS is worthless!
__________________ Nator is what it does. |
(Thread Starter) | Not Ranked : 0 score Attached is a log from this morning. Between the times 13-14 seconds and 33-33.5 is when you can see the cut out was occurring. Throttle Pos is showing ~75 for these, Boost is dropping, Wastegate didn't change, and Fuel pressure was good. Sounds like the spark blow-out was the likely issue. @kritz, I am confused, OTS as in off the shelf? Are you saying the Cobb AP tuned maps are worthless? I think they are a great step in the right direction even if not to the level a custom tune would be.
Try gap those plugs tighter. .028 should do the trick. Then get us another log from 3k - redline with throttle pedal position in the log. If you have not downloaded access tuner from cobb, make sure you do that too. Your ots map could use a little work I am sure.
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! | |
| Not Ranked : 0 score You are hitting a boost / fuel cut. If you donate to the site, post your map and tag me I'll create a drive-able map for you until you can have one of our e-tuners work with you. |
| The Following 5 Users Say Thank You to rfinkle2 For This Useful Post: | cshunter (09-26-2013), ms3rick (09-26-2013), MSMS3 (09-26-2013), Raider (09-26-2013), white'swhiteMPS (09-26-2013) |
| Not Ranked : 0 score Also, what brand of HPFP Internals are installed? |
![]() Join Date: Feb 2012 Location: Anaheim, Orange County
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,921
Groans: 32
| Not Ranked : 0 score I had fuel cut on my tune. Lowered the wgdc and bam! Gone (: now im getting a better tune. Yes I said it...better. ... sent from my peepee
__________________ 2007 Mazdaspeed 3 GT 18x8.75 XXR 527 225/40/18r COBB AP// Finkles hypnotic sexyness 50/50 e85// HTP 3.5 Whale Penis// HTP 51R battery box// JBR Adjustable SSP//JBR 88 RMM// Grimspeed 3 port EBCS// CX Racing FMIC// CNT Racing catless DP// AT internals// Lamin-x Fog light inserts// Stiffy Ingals Mtourque Mount// Asian tower brace(lol)// CNT Racing Catback// Turbo XS RFL BOV VTA FTMFW!!// Upgrated clutch// Drilled and sloted rotors (font and back)// UNDER THE KNIFE New fucken miata build: 1993 Red Na6 Some suspension modz yo 1994 Caste White MX5 Miata - sold 1991 Smurf Blue miata - sooooooold Coilovers// Other shit |
| The Following User Says Thank You to Koke382 For This Useful Post: | rfinkle2 (09-26-2013) |
Unfortunately, some of the ots maps just don't work well with a particular situation (read: yours). | |
(Thread Starter) | Not Ranked : 0 score Yeah, looks like I'm a brownie again as my last donation must have expired and reset my status.
(Thread Starter) | Not Ranked : 0 score I had to drive back home from Chicago before I could get to the tools to fix all this. So I regapped my NGK's to .028, tightened up the downpipe fittings, and did a run. I am still hitting an issue. I said fuel-cut before as that is my interpretation based on what my previous car (92 AWD Turbo Laser) used to do. You can see at 5.12 in time on this log that is where fuel is cut back and then everything kicks back in. |
![]() Join Date: Nov 2010 Location: Manchester, England
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,709
| Not Ranked : 0 score :krys: WTF!!!
__________________ Tuned with by ![]() K1 Rods//Wiseco Pistons//CX Racing FMIC//JBR Widepath Intake//Custom 3" TBE//Grimmspeed EBCS//Forge BPV//JBR SSP//JBR RSB//JBR Side Mounts//ISC-N! coilovers//JBR BSD and Baffle//Sure TIG Set//Sure R3 RMM//KMD Internals//XS Power Exhaust Manifold//P&P Intake Manifold//Fidanza Flywheel//EM Organic Compound Clutch//GTX3071//DVC30 Meth Kit//3 Gauge Pod.....415WHP....so far!! |
| Not Ranked : 0 score Not relevant in the slightest. Glad you got your problem solved though.
| what would you do in this situation | ktms3 | Gen2 MS3 General Discussion | 19 | 07-30-2012 09:11 AM |
| Fuel pump internals installes with mods | tinboi479 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 41 | 05-18-2012 04:27 PM |
| Interesting Fuel Pump Situation | Payne Racing 67 | 2010 MS3 - Fuel, Nitrous & Water Injection | 23 | 01-11-2012 09:49 AM |
| Weird situation after mods today!! CEL and other | 2010 MS3 | 2010 MS3 - Engine, Transmission & Driveline | 6 | 11-22-2009 09:59 PM |
