![]() Join Date: Aug 2014 Location: Bethlehem PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
Groaned at 5 Times in 1 Post
![]() Join Date: Mar 2013 Location: Accokeek MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 81
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score List of mods?
__________________ 2013 LSM w/tech Cobb AP V3, CBE CS Turbo tuned by PD Corksport Catted DP/HPFP Internals JBR FMIC Pipe Kit w/TR8 CP-E TIP/3.5" Intake DM OCC/TMM Forge V2 BPV Bilstein B8 w/Swift springs Wilwood 6 pot BBK EBC RedStuff rear pads Konig Hypergram 18x8.5" |
(Thread Starter) | Not Ranked : 0 score K&N cold air intake Cobb turbo inlet pipe HPFP fuel pump internals Cobb Downpipe JBR Motor Mounts |
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 501 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
| Not Ranked : 0 score Up to you on the turbo. I would not buy ko4 again if it was me
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned |
| Not Ranked : 0 score You can find used k04's on here fairly cheap. Post a WTB thread and see what others have laying around.
| The Following User Says Thank You to WetzMS3 For This Useful Post: | CWP_MS3 (01-11-2017) |
Groans: 63
| Not Ranked : 0 score Accessport? If not you'll have a really bad time when you put any bigger turbo in EDIT: Nevermind, I completely forgot it was mentioned in the post 1. IMO a k04 isn't worth the price when a bnr s3 is almost the same.
(Thread Starter) | Not Ranked : 0 score I was thinking of going with the Bnr s3 has anyone had any bad experiences with BNR turbos? |
Groans: 438
I haven't had any problems with mine post install. Everything working great. Seriously though, type in "BNR S3 Mazdaspeed" on google and start doing some reading.
__________________ All good things must come to an end... | |
| The Following User Says Thank You to g00s3y For This Useful Post: | Vansquish (03-06-2016) |
![]() Join Date: Jun 2009
| Not Ranked : 0 score Assuming OP has Accessport, simply raising idle rpm +200 may eliminate his smoking issue. If it did not smoke before the dp upgrade there is a chance this would work, and costs nothing to try.
![]() Join Date: Oct 2014 Location: Howell, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 126
| Not Ranked : 0 score Banjo bolt?
__________________ 2008.5 Metropolitan Gray : Cobb AP V2 : HTP 3" : Turbosmart Dual Port : Damond RMM : Autotech Internals : Fidanza Flywheel |
| or Rotella T6
| Not Ranked : 0 score Yes, I've been running T6 Rotella AND bumped up idle rpm for quite a few years with catless dp/rp and have never had turbo smoke. I'm at almost 120,000 miles. The original turbo did finally develop shaft wear back in the Spring. Never smoked. I replaced it with a rebuilt K04 from Works Turbo in the Birmingham, AL area for about $350, IIRC. It, like the original, has not smoked with the combo of raised rpm and the T6.
![]() Join Date: Dec 2013 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
| Not Ranked : 0 score Keep in mind bnr will need a new tip. Inlet size is larger than oem
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
(Thread Starter) | Not Ranked : 0 score I have not tried a banjo bolt but I did put 5w-40 ams oil and it fixed the issue for about 2 weeks. I got the car looked at and he said I probably have 1 or 2 months before my turbo completely goes. What about the corksport turbo will that fit the cobb turbo inlet hose? |
| Not Ranked : 0 score It will. Up the rpm to 900 at idle and problem will probably be solved. I have like 3 k04s sitting in my garage all rebuilt in case I have issues ever prior to going BT
(Thread Starter) | Not Ranked : 0 score Ok I'll try upping the idle rpm thanks. Does this put extra strain on the engine at all though? If I do get a new turbo which would give me more power corksport or bnr s3 |
If you have a stiff aftrrmarket rear motor mount or intend to add stiffer mounts, bumping up idle helps alot with that, too.
(Thread Starter) | Not Ranked : 0 score Ok well thank you for the input everyone. I think I am going to just buy a new turbo and go with the new corksport bolt on turbo! |
![]() Join Date: Dec 2013 Location: Plainfield, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,712
| Not Ranked : 0 score Keep in mind as well you will need a new tune for that turbo. The crappy Cobb ones will not work.
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor |
(Thread Starter) | Not Ranked : 0 score Yes I know. I was hoping the local shop near me CB tuning would be able to put together a good tune for me as they are the ones installing it. |
| Not Ranked : 0 score Install it yourself and save a ton of money! It's easy. I've pulled my turbo on more than one occasion. And use a tuner that actually knows what they're doing on this platform.
| The Following User Says Thank You to Djohns For This Useful Post: | speedfreak44 (10-10-2015) |
| Not Ranked : 0 score What he said... From what I have experienced our motors are a little on the "special" side and your normal honda pro tuner probably will blow your shit up. Contact one of our etuners they will set you up right and walk you through it all Or just buy one of my extra k04s :p (Shameless plug inserted here)
| The Following User Says Thank You to speedfreak44 For This Useful Post: | Djohns (10-10-2015) |
| Not Ranked : 0 score The "special side" is the nice way to word it. At least for my car. My car is constantly pissed off at the world and me for some reason. She has a pretty bad attitude problem. Moody car. With how moody these damn cars are you really do need a good tuner for this platform or your car may bite you right back and blow
![]() | | #24 | ![]() |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
| Not Ranked : 0 score @texas_wizard; upgraded his turbo because he thought it was smokey. Turns out cylinder 2 was full of oil. Just sayin', if you're smoking immediately from start up (when the oil and turbo are not hot yet) it may not be the turbo.
__________________ 3rd rebuild on the way...maybe... |
![]() | | #25 | ![]() |
| Not Ranked : 0 score That's true! I remember after I did my downpipe my pcv valve simultaneously took a shit and I was freaking that my turbo went lol. (Pcv valve would make you burn oil if bad)
![]() | | #26 | ![]() |
![]() Join Date: Feb 2015 Location: Palmer, Iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 152
| Not Ranked : 0 score +1 on CS turbo, dont get a tuner that is not experienced with our platform or they will blow it up.
__________________ 06 MS6 GT Titanium Gray II Metallic |
![]() | | #27 | ![]() |
| +2 on the CS Turbo. sent from my Nexus 6P
![]() | | #28 | ![]() |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Dont absolutely need either. I run a 3 bar but cs jus came out with a 3.5 that would be a good choice. Ebcs isnt required but helps. If you are tight on funds buy the turbo and use points they give you on the 3.5bar or call and see if they can make you a good deal.
![]() | | #30 | ![]() |
| Not Ranked : 0 score From convos with CS it is highly suggested to use an ebcs upgrade.
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score When you referenced e tuning you were referring to freektuning? Any other good e tuners, any recommendations would be great? |
![]() | | #32 | ![]() |
| Not Ranked : 0 score Freektune Stratified Hypnotic Etc Etc There are quite a few on here, some have their own vendor subforums. Look around on the main forum page.
| The Following User Says Thank You to speedfreak44 For This Useful Post: | pastry00 (10-11-2015) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score I called and talked to a few different tuners before i chose to go with Purple Drank. Just call and feel them out.
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score I am going to go with purple drank for the tune has anyone had a bad experience from them? |
![]() | | #35 | ![]() |
| Not Ranked : 0 score Will and Ryan are good guys, you wont be disappointed.
![]() | | #36 | ![]() |
(Thread Starter) | Not Ranked : 0 score I just wanted to add that my experience with Purple Drank was great! Great tune and great company! |
![]() | | #37 | ![]() |
![]() Join Date: Dec 2015 Location: Snohomish, WA
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score I know, pulling up a dead thread, but I wanted to ask pastry00 - how do you like the CS Turbo? I'm thinking of going that route myself. |
![]() | | #38 | ![]() |
Groans: 111
| Not Ranked : 0 score It's a decent turbo.
![]() | | #39 | ![]() |
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
| The Following User Says Thank You to CWP_MS3 For This Useful Post: | WetzMS3 (01-11-2017) |
![]() | | #40 | ![]() |
| Los Angeles: 2014 Porsche Panamera Turbo S is a 911 Turbo for the family man | Haltech | Automotive News | 0 | 11-21-2013 10:20 AM |
| Official: 2014 Porsche 911 Turbo and Turbo S debut [w/video] | Haltech | Automotive News | 0 | 05-03-2013 07:50 AM |
