 Old 06-29-2009, 11:54 PM   #1
06speed's Avatar
Posts: 96   (View Stats)
06speed will become famous soon enough
Groaned at 25 Times in 7 Posts
Default no boost
i have a 06 speed6 withe a corksport fmic. just awhile ago i was racing a SRT6 crossfire. i got out on him by 1 1/2 to 2 cars. and my shift linkage broke on me. temp. fix for that. and i also found out that my car was not boosting. the turbo spools the bov goes off. and from the pipes i could see i there wasn't any loose pipes. so what are your opinions on what the problem is.i know i have to check the rest of the pipes but what else should i be looking for. Please help my out
06speed is offline   Reply With Quote
 Old 06-30-2009, 02:36 PM   #2
wassup61's Avatar
Posts: 1,232   (View Stats)
Is it the stock bypass valve? You might need a replacement if its the stock valve. You should be pushing at least wastegate pressure which is around 10-12 psi
All wagon, No traction
 Old 06-30-2009, 03:58 PM   #3
sleeperstang1994's Avatar
Posts: 569   (View Stats)
Groaned at 7 Times in 5 Posts
check to see if you blew a tube off of your front mount(im good at this) or possible boost leak. if you BPV is venting when you hit vacuum the leak should be somewhere after the valve, i think.....someone correct me if im wrong. on the same train though if you have a massively large leak you shouldn't hear the BPV at all
Boost gauge vs. AP boost reading.. which is correct? Unoriginalusername MazdaSpeed 3/6 - Turbo Induction 13 05-23-2011 05:41 PM
boost JmkC MazdaSpeed 3/6 - Turbo Induction 1 03-25-2009 09:30 AM
over boost oncogene1 MazdaSpeed 3/6 - Turbo Induction 12 03-19-2009 12:10 PM
fixed boost psi vs boost table settings? johnac08 MazdaSpeed 3/6 - ECU Computer Tuning 8 02-03-2009 04:05 PM
Page generated in 0.24108 seconds with 22 queries
