 Old 08-08-2014, 07:19 PM   #1
kylejenson's Avatar
Posts: 140   (View Stats)
kylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant future
Default Not sure what I broke..
I'm pretty damn green with working on cars, can someone tell me what I broke? Lol
I think it's the waste gate solenoid vacuum line that I was taking off when I repositioned my hand and busted it..
kylejenson is offline   Reply With Quote
 Old 08-08-2014, 07:24 PM   #2
Plastic nipple on the stock EBCS, buy an aftermarket 3-port and be done with it.
The Following 5 Users Say Thank You to Code Monkey For This Useful Post:
Easter Bunny (08-08-2014), Hargarbl (08-08-2014), kylejenson (08-08-2014), Spec (08-08-2014), stevenlapensee (08-08-2014)
 Old 08-08-2014, 07:31 PM   #3
kylejenson's Avatar
Better than I thought. I planned on getting one, just not so soon. Thanks
 Old 08-08-2014, 08:34 PM   #4
Do not drive the car without that connected.
Code Monkey (08-08-2014), Spec (08-08-2014)
 Old 08-08-2014, 08:45 PM   #5
Spec's Avatar
Posts: 4,472   (View Stats)
Some people have had success sticking it back together and using a 2 part epoxy on the outside but...... An aftermarket ebcs is cheap and makes your life easier later when you mod in the future not having to fuck with it.
 Old 08-08-2014, 08:49 PM   #6
Yatta's Avatar
Posts: 1,862   (View Stats)
if you can find some rigid nylon or copper tubing to fit inside that plastic nipple that you broke off, you can glue it together using that, but as EB said, I would not drive it that way, should be able to bypass and run your waste gate off of spring pressure but I don't know for certain and don't have the shop manual in front of me.
 Old 08-08-2014, 10:43 PM   #7
BPASPEED's Avatar
Posts: 1,891   (View Stats)
Groans: 60
You're not the first and definitely not the last person to break that fucker. Listen to these guys and get an aftermarket one, or if you're lucky like I was, someone near you who already upgraded will just give you their old oem one.
BPASPEED is offline   Reply With Quote
This broke mazdaspeeding Mazdaspeed3/6 General Discussion 10 01-04-2013 05:47 PM
Think I broke it Zai_MS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 30 08-25-2011 12:44 AM
So I think I broke something OMGWTFHAX MazdaSpeed 3 - Engine, Transmission & Driveline 2 02-28-2010 04:23 PM
HELP! i broke it TheNewGuy MazdaSpeed 6 - Engine, Transmission & Driveline 1 02-26-2010 06:49 PM
Page generated in 0.28011 seconds with 26 queries
