 Old 06-04-2009, 10:16 PM   #1
manofhonor24's Avatar
Posts: 187   (View Stats)
manofhonor24 is a splendid one to beholdmanofhonor24 is a splendid one to beholdmanofhonor24 is a splendid one to beholdmanofhonor24 is a splendid one to beholdmanofhonor24 is a splendid one to beholdmanofhonor24 is a splendid one to beholdmanofhonor24 is a splendid one to behold
Default OBX Turbos
Anyone have any thoughts? THey are hella cheap and look identical to the Garret turbos. They have a GT2871 clone for $550.
Any feedback? I am scared to do this, but it is gonna cost me the same to rebuild my stock turbo.
manofhonor24 is offline   Reply With Quote
 Old 06-04-2009, 10:58 PM   #2
JumpingJackson's Avatar
Posts: 967   (View Stats)
call me when it blows
 Old 06-06-2009, 08:50 AM   #3
mexicant's Avatar
Posts: 867   (View Stats)
mexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the world
Groans: 147
Groaned at 34 Times in 29 Posts
i wouldnt waste my money on a gt28 or the knock off
"08, I hate to break it to you, but if it gives kevin a boner, its porn"
NATOR PERFORMANCE
Nylon washer sponsered
mexicant is offline   Reply With Quote
 Old 06-06-2009, 09:22 AM   #4
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
isn't obx crap?
 Old 06-06-2009, 02:36 PM   #5
tmtbiker's Avatar
Posts: 287   (View Stats)
tmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the world
come on man, 30K car and you're buying knock off parts? good luck, i wouldn't do it.
tmtbiker is offline   Reply With Quote
 Old 06-06-2009, 03:02 PM   #6
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groaned at 86 Times in 65 Posts
if you really want to cut corners on this kinda thing look at master power. i personally wouldnt run obx or master power but 1000s of people do.
-JEWBERT
jhershorin is offline   Reply With Quote
 Old 06-06-2009, 03:26 PM   #7
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
on the sr20-forums people using them had the compressor blades fly into throttle bodys if that helps.
 Old 06-06-2009, 03:51 PM   #8
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
I just bought 2x rebuild KKK K16 turbos for my other project on ebay a few weeks ago for $120 bucks each. The K16's have titanium compressor wheels and plain bearings. I think the k16 is smaller than the Mazdaspeed K04 however. Next size up is a K24 which might work. You can find these for less than $400 used/rebuilt.
Also check out this site:
Bullseye Power Turbos
The S258 turbo is great from what I hear. Very wide compressor map and high peak efficiencies. Not too expensive either.
Garrett and turbonetics turbos are great but the prices are just ridiculous.
You can also try mitsu or IHI turbos. They are not bad either.
Definitely would NOT go with that OBX crap. Better off with a used or rebuilt turbo if you are on a budget. Unless the turbine or compressor wheel is chiped, or the casings are in bad shape, its just the same as new. IMO at least...
 Old 06-07-2009, 12:16 PM   #9
all4bspinnin's Avatar
Posts: 188   (View Stats)
all4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant future
i know some guys that buy these turbo's for dirt cheap, send them to our local turbo rebuild shop and i have the tech there go through them and balance everything, he'll also replace any garbage parts with quality ones... he does this for about $400... so for $800-900 you have a 100% quality 35R, etc....
when you know someone like this, its a good buy actually
all4bspinnin is offline   Reply With Quote
Turbos, a begginers guide. Demi MazdaSpeed 3/6 - Turbo Induction 89 01-07-2015 10:38 AM
Stock smoking turbos? TheDoc MazdaSpeed 3/6 - Turbo Induction 82 10-26-2009 08:33 PM
for the guys with bigger turbos? johnac08 MazdaSpeed 3/6 - Turbo Induction 5 09-01-2009 09:45 PM
Custom reworked turbos? CraigHJr Mazdaspeed3/6 General Discussion 22 09-29-2008 09:11 PM
Page generated in 0.30121 seconds with 28 queries
