Like Tree3Likes
Closed Thread
 Old 07-08-2009, 10:30 AM   #1
tunersteve's Avatar
Posts: 869   (View Stats)
tunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the world
Neutral  +2 score
Default Official 'smoking turbo' response from Mazda
Hey everyone, here's the email I received from my local service manager after I stopped in to question him about the 5w-40 rumors.
SMOKE FROM TAIL PIPES AFTER PROLONGED IDLE PERIODS
Applicable Models
Model Starting S/N Ending S/N Model Spec CX7 2007-2008 000001 209008 P/D BEFORE 2/15/2008 MAZDA6 2006-2007 000001 999999 ALL MAZDASPEED6 MAZDA3 2007-2008 000001 880368 P/D BEFORE 2/6/2008 Related Category/Subcategory/Symptoms
ENGINE / MECHANICAL / WHITE SMOKE,BLUE SMOKE
ENGINE / EMISSIONS SYSTEM / EXCESSIVE OIL CONSUMPTION
ENGINE / EMISSIONS SYSTEM / WHITE SMOKE,BLUE SMOKE
ENGINE / EMISSIONS SYSTEM / BLACK SMOKE
ENGINE / MECHANICAL / EXCESSIVE OIL CONSUMPTION
MTOL - 5505 Dealer Repair Information
Symptom and Conditions
Applicable Model(s) VINS
CX-7 JM3ER ****8* 209008 Produced before 2/15/08
MAZDASPEED6 ALL ALL
MAZDASPEED3 JM1BK ****8* 880368 Produced before 2/6/08
Some customers may experience white/blue smoke from their exhaust pipes
after prolonged idle periods and/or while driving in traffic at very
slow speeds.
This condition may be the result of the turbo's oil supply not being
able to adequately drain out of the turbo during long idle periods.
Vehicles having this concern should be diagnosed using the following diagnostics procedure.
Repair Procedure
1. Confirm that the proper maintenance intervals have been performed.
2. With the engine at normal operating temperature, allow it to idle
for an extended idle period.
Caution:
Closely monitor the engine coolant to the assure the engine does not Overheat.
3. If smoke from the exhaust is present after the extended idle period,
take before pictures of the smoke, then change the oil and filter
using 5W/40 (synthetic). After the oil change, in order to burn off
the oil that remains in the exhaust system, perform the following:
start the engine, check for oil leaks, then let it idle for 10
minutes, after the 10 minute idle period, increase the RPMs to 3000
for 1 minute, repeat idle test to confirm that no smoke returns.
A: If the smoke returns, contact the Technical Assistance Hotline
(Select option #2 for Major Assembly Authorization) with the oil
change history information, to attain an authorization for a turbo
replacement.
B: If smoke DOES NOT RETURN after the repeat idle test, NO other repairs
are to be performed at this time. Explain to the customer that MAZDA
is currently working on an improved positive crankcase valve (PCV)
system to reduce the engine crankcase pressures to allow the turbo's
oil supply to drain from the turbocharger more efficiently This fix
will be available approximately within 90 days and at that time the
oil will be changed back to 5W-30 and the improved PCV system will be
installed
Sounds like something is on its way for this problem. I searched but couldn't find any info that was similar to this.
vote4chaos likes this.
2011 Mustang GT
tunersteve is offline
The Following 70 Users Say Thank You to tunersteve For This Useful Post:
2008speed3 (07-08-2009), 802MS3 (07-08-2009), Addikted To Boost (07-08-2009), AndyMS3 (07-08-2009), ASIC_BSEE (01-30-2010), ataraxia (08-19-2009), Bitner16 (09-29-2009), blackMPS (05-31-2010), Blink (08-17-2009), Boosted Beluga (07-09-2009), BoostIsBetter (07-08-2009), burntRice (05-14-2010), cookieheadjenkins (03-16-2010), D-Rick21 (07-09-2009), DaleNixon (07-08-2009), Dash08 (07-09-2009), djuosnteisn (07-08-2009), evidence (07-08-2009), Fobio (07-08-2009), FreeFlyFreak (07-08-2009), ganque (03-09-2010), Hank3 (12-23-2009), hoyta (07-24-2010), ICNSYDU (03-08-2010), ispypsi (08-13-2009), J-villa (07-16-2009), jax ms3gt (09-29-2009), JohnnyT (07-08-2009), jtspells (07-08-2009), kevdog (12-13-2009), kore2000 (07-08-2009), kramer (07-09-2009), leadf00t (07-15-2009), manofhonor24 (07-09-2009), meatball18 (09-29-2009), mexicant (09-02-2009), MicaBlackMS6 (07-08-2009), Mistersix (07-04-2014), MKTMS3 (11-18-2009), mouse0330 (08-17-2009), ms3jake (08-13-2009), Murse (07-11-2009), N118GT (03-11-2010), Nliiitend1 (07-16-2009), NoRegrets (07-09-2009), Ozark (07-10-2010), Phantom (07-09-2009), ponny135 (08-16-2009), ReD BoY (07-06-2010), roth4fun (12-07-2009), Sacrilicious (07-08-2009), SharkDiver (07-08-2009), skubidoobie (08-16-2009), smakdown61 (07-08-2009), speed3Texas (09-30-2011), Speedee3 (11-19-2009), SpeedSixxx (07-08-2009), spiker98 (07-10-2009), SRTie4k (04-03-2010), superskaterxes (07-08-2009), taf0422 (07-15-2009), Tcman2006 (08-13-2009), TheNewGuy (08-30-2009), ThEsHoCkEr (07-09-2009), triplejumper18 (07-08-2009), Varomnia (11-19-2016), wassup61 (07-22-2009), xandrake (07-09-2009), xSP33Dx3x (08-25-2009), YammerR1 (07-08-2009)
 Old 07-08-2009, 10:36 AM   #2
ALL-IN.
AndyMS3's Avatar
Posts: 671   (View Stats)
AndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the world
Groans: 30
Thanks for sharing.
Good to know in the event I start smoking.
AndyMS3 is offline
The Following User Says Thank You to AndyMS3 For This Useful Post:
 Old 07-08-2009, 10:37 AM   #3
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
interesting that they are changing the valve, i hope this stops all the cry babies who think their turbo is blown!
bova is offline
The Following User Says Thank You to bova For This Useful Post:
 Old 07-08-2009, 10:41 AM   #4
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
How much time an "extended period of time" means? 10 minutes? 30 minutes? can someone explain?
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
mituc is offline
 Old 07-08-2009, 10:46 AM   #5
ALL-IN.
AndyMS3's Avatar
Groans: 30
I think people were averaging 3-5 minute idle times before they saw smoke.
I remember reading about a few members sitting in drive-thru's waiting and smoke would start bellowing out.
Anywhere form 3-10 minutes should do it.
AndyMS3 is offline
 Old 07-08-2009, 10:50 AM   #6
tunersteve's Avatar
When my turbo was replaced, it took somewhere between 10-15 minutes. I actually recorded video of it smoking and took it with me when I took the car in.
I'm guessing they'll issue a TSB to upgrade the PCV system on our cars after the workaround has been figured out.
2011 Mustang GT
The Following User Says Thank You to tunersteve For This Useful Post:
 Old 07-08-2009, 10:51 AM   #7
SonnyBonahoe's Avatar
Posts: 241   (View Stats)
SonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond repute
sweet! i've been talking to my dealer about this for a while.... now i'm walking in with this and going to "ask nicely" again for some action by the dealership to fix/replace!
SonnyBonahoe is offline
The Following User Says Thank You to SonnyBonahoe For This Useful Post:
 Old 07-08-2009, 10:53 AM   #8
DaleNixon's Avatar
Posts: 2,079   (View Stats)
DaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the world
Groans: 91
So MS3's produced after 2/6/2009 shouldn't exhibit this problem? I'm probably going to switch to 5w40 anyway.
Gay car #1: 2001 Miata (Gay White)
Gay car #2: 2011 Mazda 2 (Gay Blue)
DaleNixon is offline
The Following User Says Thank You to DaleNixon For This Useful Post:
 Old 07-08-2009, 11:25 AM   #9
ALL-IN.
AndyMS3's Avatar
Groans: 30
2/6/2008
AndyMS3 is offline
The Following 2 Users Say Thank You to AndyMS3 For This Useful Post:
DaleNixon (07-08-2009), ICNSYDU (03-08-2010)
 Old 07-08-2009, 11:33 AM   #10
708
Erich's Avatar
Posts: 4,274   (View Stats)
Originally Posted by stratum View Post
2/6/2008
FWIW my car has a date of 02/08 and still has the same PCV system components as older cars.
Erich is offline
The Following User Says Thank You to Erich For This Useful Post:
 Old 07-08-2009, 11:26 AM   #11
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
5w40 cleared up my issue months ago
Carry on citizens....
10.7 @ 133 auto 1G DSM
Darksun280 is offline
The Following User Says Thank You to Darksun280 For This Useful Post:
 Old 07-08-2009, 11:31 AM   #12
Does this mean that the newer model speeds have the "improved" PCV system/valve already installed?
Lex is offline
FreeFlyFreak (07-08-2009), ICNSYDU (03-08-2010)
 Old 07-08-2009, 06:17 PM   #13
evidence's Avatar
Posts: 1,033   (View Stats)
I think Mazda actually redesigned the turbo (or components of it atleast) at that time. I remember some guy telling us his tech told him Mazda had changed the oil lines in the new turbo. Everyone doubted him saying they prob just switched manufacturers and that's why the model changed. It's all coming toghether..
I guess the positive news is it seems pretty harmless.. just burning off some oil.
Some things.
evidence is offline
The Following User Says Thank You to evidence For This Useful Post:
 Old 07-08-2009, 06:42 PM   #14
Maybe this isn't the whole story.
Lex is offline
 Old 07-08-2009, 11:31 AM   #15
CrazyFists
JohnnyT's Avatar
Posts: 2,341   (View Stats)
JohnnyT is the leader of the worldJohnnyT is the leader of the worldJohnnyT is the leader of the worldJohnnyT is the leader of the worldJohnnyT is the leader of the worldJohnnyT is the leader of the worldJohnnyT is the leader of the worldJohnnyT is the leader of the worldJohnnyT is the leader of the worldJohnnyT is the leader of the worldJohnnyT is the leader of the world
Hot damn. I knew my seals were fine.
I'm already on 5w40 so I guess I'll just wait for the PCV fix.
KSam08 likes this.
2002 QS Z06 | Futral custom grind cam | LG headers & GHL cat-back | FAST 92/90 | E85 | Corbeau A4s |
CCW SP500s | Mantic ER2 clutch | GM T1 bars | 422whp / 405wtq (pre-FAST) | Tuned by Carl @ CJ Tunes |
JohnnyT is offline
The Following User Says Thank You to JohnnyT For This Useful Post:
 Old 07-08-2009, 11:34 AM   #16
Trader's Avatar
Posts: 90   (View Stats)
Trader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to behold
Groaned at 5 Times in 1 Post
....Explain to the customer that MAZDA
installed.....
Does this mean that the pcv valve will be a recall item? Could I get the valve even though I have not started smoking??
Trader is offline
The Following User Says Thank You to Trader For This Useful Post:
 Old 07-09-2009, 09:36 AM   #17
tunersteve's Avatar
Here's my response from my dealer about the 'spreadsheet' that I keep for my oil changes:
Keeping it on a spreed sheet is better than nothing, but I would suggest you start writing the mileage and date on the top of the sales receipts for your oil and filter as well. But this is still no guarantee. When someone has a concern with an engine or power train component and we don't have detailed records Mazda will usually require partial tare down before they will authorize or deny a claim, such as removing a valve cover or oil pan to check for sludge or signs of lack of maintenance. We do not make the call at the dealer level. Mazda has to authorize all major claims.
Just for future reference, we certainly don't have a problem using your oil if you would like us to do your maintenance for you. I have several customers we do that for. The bill comes to about $15 for labor and filter. This way you would have records with Mazda as well.
2011 Mustang GT
 Old 07-08-2009, 11:34 AM   #18
MZRDISI4's Avatar
Posts: 1,430   (View Stats)
MZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the world
Groans: 94
Groaned at 38 Times in 19 Posts
Yay!!
I hope. I wants me a revised PCV..
It won't be a recall, it'll be a part revision that would be replaced under the powertrain warranty, only if the heavy oil does not fix the problem. Otherwise you could just buy it yourself
"We already have the Speed6 replacement" "It's just called the CX-7 now"
back at http://www.mcx7.com bitches, spam free
MZRDISI4 is offline
The Following User Says Thank You to MZRDISI4 For This Useful Post:
 Old 07-08-2009, 11:37 AM   #19
RUMBLEFISH's Avatar
Posts: 730   (View Stats)
RUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the world
Groans: 32
I did the 5-40 the first time I saw smoke and it still does. It only happens if I ride it hard then after that it will smoke at every stop real bad. If I go easy the next day and drive normal no smoke.
The problem I have is them wanting oil changes with all the documentation. I guess I should get to work on that but now sure how to proceed. Maybe I should just hold out until the fix comes then just buy it if they will not install it under recall without all the documents.
2008.5 Metro Gray Speed 3 t bone motor mount, CPE Nano, TIP,Corksport RP, HYPER box tune.
RUMBLEFISH is offline
The Following User Says Thank You to RUMBLEFISH For This Useful Post:
 Old 07-08-2009, 11:49 AM   #20
kore2000's Avatar
Posts: 448   (View Stats)
kore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the world
Groans: 90
Groaned at 69 Times in 21 Posts
I find it interesting that they put a caution statement about the engine overheating. Most normal cars don't over while idle so why the caution statement? I wonder if Mazda also realizes that this engine bays gets extremely hot and maybe they sealed it up a little too well.
kore2000 is offline
The Following User Says Thank You to kore2000 For This Useful Post:
 Old 01-22-2010, 10:17 AM   #21
Koobers's Avatar
Posts: 11   (View Stats)
Koobers is on a distinguished road
My MS6 is stock and has 43,000 miles on it and started smoking over the holidays, I noticed it first while at a drive thru but I didn't think it was coming from my car. The next day I left it to idle in the driveway and ran in the house and took about 10 mins and when I came out there was smoke all the way down the street. My uncle works for Ford's SVT division building engines and he thought it was coolant leaking into the engine and burning off.
I took it to the dealer and they said the turbo was getting clogged and that it's been a problem with the 2.3L engines so they changed the oil to 5w-40 and said that it should fix the problem and if it didn't to bring it back and they would have to swap out te turbo. They made it sound like they needed the service record but they didn't charge me, who knows mabe they're sending me a bill. It started smoking again about 3 days later and it's not as bad as before the oil change but now I'm noticing oil specks coming out the exaust.
I'm glad I read this post because the dealer made it sound like the turbo was faulty and I thought it would be stupid to take it back and have them swap out one crappy turbo for another. I was going to look into replacing it with an aftermarket turbo, but if the problem is with the PCV I'll wait it out and see if I can get them to replace it once they come up with a permanent fix. I found service records from the original owner in the glove box and I should have all my receipts from my oil changes, I'll have to see if i can make a spread sheet and gestimate the milage.
Koobers is offline
 Old 07-08-2009, 11:54 AM   #22
BoostIsBetter's Avatar
Posts: 582   (View Stats)
BoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the world
Groans: 32
Groaned at 31 Times in 18 Posts
What i'm curious about is why then my Mazda dealer told me about the switch to 5w-40 from their techs and switched it for me, when I have an 09 with a 11/08 build date. It doesn't make sense to me? Does it mean we have this pcv fix already? I'm confused, lol.
Eitherway, this sounds great for everything!
I'm not sure if I remember correctly, someone correct me if I'm wrong, but didn't DCR or someone mention something about the pcv system and a correlation with blown motors?
BoostIsBetter is offline
The Following User Says Thank You to BoostIsBetter For This Useful Post:
 Old 07-08-2009, 12:11 PM   #23
CrazyFists
JohnnyT's Avatar
PT-P brought up a new PCV fix, but it won't save your motor:
http://www.mazdaspeedforum.org/forum/foru...ng-tested.html
JohnnyT is offline
The Following 2 Users Say Thank You to JohnnyT For This Useful Post:
BoostIsBetter (07-08-2009), ICNSYDU (03-08-2010)
 Old 07-08-2009, 11:58 AM   #24
BlackMS3's Avatar
Posts: 1,078   (View Stats)
BlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the world
Mine was replaced at 23K. Took 10 minutes to start smoking and when it did, you couldn't see through the cloud.
I pulled up to the dealer after running it hard the whole way, parked it and let it sit and idle while I went in to talk to the service manager and by the time I explained everything and we walked out, the side of the building was engulfed and they were like "holy fucking shit!!!" LOL...
Best to date - 13.802@104.16 (I/MP/MM/W)
BlackMS3 is offline
The Following 3 Users Say Thank You to BlackMS3 For This Useful Post:
ICNSYDU (03-08-2010), kgb (07-08-2009), ms3jake (04-02-2010)
 Old 07-08-2009, 12:04 PM   #25
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
STICKY!
-- Mario Andretti --
Fobio is offline
The Following User Says Thank You to Fobio For This Useful Post:
 Old 07-08-2009, 12:32 PM   #26
YammerR1's Avatar
Posts: 109   (View Stats)
YammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud of
Originally Posted by Fobio View Post
STICKY!
I vote for Front Page News!
My totally stocker has started smoking too, with 5W-30. Drive it hard in boost, then let idle for about 3 mins for my smoke show. The weak turbo seals will eventually leak with the oil not draining properly from the turbo, even for cars without exhaust mods like mine.
YammerR1 is offline
The Following User Says Thank You to YammerR1 For This Useful Post:
 Old 07-08-2009, 12:51 PM   #27
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
my 09 was pouring blue smoke after about 4 minutes with just a race pipe. That was with 5w 40 and a catch can. I put in my bnoon banjo bolt and no more smoke. I will be getting this pcv fix though if i can do it without messing up my catch can setup. Thanks for the info man, i wonder if they will deny me because mine was built after 02/08?
09 MGM MS3
Addikted To Boost is offline
The Following User Says Thank You to Addikted To Boost For This Useful Post:
 Old 07-08-2009, 01:08 PM   #28
Hank3's Avatar
Posts: 516   (View Stats)
Hank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the world
Neutral  -1 score
Might be good to see how much this new PCV will cost. And the difficulty in swapping it out.
5% off Redline leather goodies HERE. Pics of them installed in my Speed3 HERE.
Hank3 is offline
The Following User Says Thank You to Hank3 For This Useful Post:
 Old 07-08-2009, 02:08 PM   #29
MOVOVR's Avatar
Posts: 200   (View Stats)
MOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond repute
I just started getting smoke at idle within the last 2 days. Problem is, I have no cats whatsoever so my guess is I'd have to take the DP off and put it back to stock before the dealer would acknowledge actually seeing any smoke.
MOVOVR is offline
The Following User Says Thank You to MOVOVR For This Useful Post:
 Old 07-08-2009, 02:10 PM   #30
BlackMS3's Avatar
And doing that would likely mask the smoke completely for some time....
BlackMS3 is offline
The Following User Says Thank You to BlackMS3 For This Useful Post:
 Old 07-08-2009, 02:12 PM   #31
Hank3's Avatar
Do modded cars have a tendency to smoke more than stock? All I have is a SRI and a TIP. I'm not planning on changing the exhaust bits or taking out any cats.
Hank3 is offline
 Old 07-08-2009, 02:41 PM   #32
BlackMS3's Avatar
The cats on the stock exhaust typically mask the issue, other mods really wouldn't have an effect. So if you get an aftermarket TBE or RP, it would make the issue more apparent.
BlackMS3 is offline
 Old 07-08-2009, 03:33 PM   #33
RUMBLEFISH's Avatar
Groans: 32
Well I just stopped at a speed dealer and got some info and for me atleast its good.
If its a recall they dont need oil change paperwork. If I go in before the recall then I would need all the oil changes "like I have them" from day one with my car at 30,000 miles. The service mgr told me she has a car in now with one and the guy or gal has no paperwork for oil changes and it looks like mazda is gonna fuck them.
Bottom line is if you dont have paperwork dont go in and wait until the recall is done. This poor person might end up getting screwed and they will just void any motor warranties in the future.
Bastards
 Old 07-08-2009, 03:41 PM   #34
MZRDISI4's Avatar
Groans: 94
Welll you should keep all the records for oil changes, the only problem I might have is that I'm missing a few from a dealer that closed down.. Thousand Oaks Mazda/Subaru. I'll just have to fab them up.
And it's going to be a recall?
MZRDISI4 is offline
 Old 07-08-2009, 04:16 PM   #35
RUMBLEFISH's Avatar
Groans: 32
I dont mean its a recall but it looks like it may turn into one. I was basing it on the first thread that something will be coming down the pipeline on the problem.
 Old 07-08-2009, 03:43 PM   #36
well PTP was right about the oil not being able to drain!!!
superskaterxes is offline
 Old 07-08-2009, 03:47 PM   #37
708
Erich's Avatar
Wonder if they are redesigning the black cover on the block.
Erich is offline
 Old 07-08-2009, 03:51 PM   #38
anyone think it can be the shitty mazda PCV valve? the Cv on the valve sucks ass and i think if we raised that significantly it would def help evacuate more pressure and less oil would back up in the turbo.
 Old 07-08-2009, 04:13 PM   #39
708
Erich's Avatar
Could be, but the current design of the cover the pcv is in needs to be redesigned. It allows oil into the upper chamber and then it won't drain back leaving it only one place to go.
Erich is offline
 Old 07-08-2009, 05:07 PM   #40
Groans: 32
I hope it's a recall, but it's almost an extremely rare case a company, especially in today's economy will do a recall unless it affects ALL stock vehicles, if not, they might make it a TSB, but I'll keep my hopes up! Thanks for the info so far.
Question though. I have all my oil reciepts, but my dealer gave me oil and a filter for free last time so I can do my own change, how do I keep a record of that, I have no receipts? Any suggestions? Do I take a picture of me doing it with that day's newspaper and a video camera showing my odometer reading!?
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/official-smoking-turbo-response-mazda-32008/
Mazda3 Totaled (ouch pics) Now a MS3 owner - Mazda3Forums.com This thread Refback 10-07-2012 09:30 AM
• View topic - MPS reputable dealer in Cape Town (long idle smoke) This thread Refback 09-17-2012 02:43 PM
MS3 Mazdaspeed 3 Smoking Turbo @ Dealership - YouTube This thread Refback 10-11-2011 08:47 AM
‪MS3 Mazdaspeed 3 Smoking Turbo @ Dealership‬‏ - YouTube This thread Refback 07-24-2011 03:58 PM
YouTube - ‪MS3 Mazdaspeed 3 Smoking Turbo @ Dealership‬‏ This thread Refback 05-18-2011 11:13 PM
Mise fire Mazdaspeed 3 2008 This thread Refback 11-24-2010 01:14 PM
YouTube - MS3 Mazdaspeed 3 Smoking Turbo @ Dealership This thread Refback 11-03-2010 11:35 AM
ANy love for the Mazdaspeed6?: Grassroots Motorsports forum: Grassroots Motorsports Magazine This thread Refback 06-15-2010 06:54 PM
NASIOC - View Single Post - The Mazdaspeed 3 Thread This thread Refback 12-29-2009 11:13 AM
The Mazdaspeed 3 Thread - Page 120 - NASIOC This thread Refback 12-21-2009 08:36 AM
Mazda6 / Atenza > mazda admits smoking problem!!!!!! This thread Refback 08-18-2009 07:54 PM
2.3disit Smoking Turbo - Club Mazda This thread Refback 07-10-2009 11:13 AM
smoke, has anyone had this? - Page 2 - COBB Forums This thread Refback 07-09-2009 08:02 PM
mazda admits smoking problem!!!!!! - Mazda6 / Atenza This thread Refback 07-08-2009 03:45 PM
Official Smoking Turbo response from Mazda - Colorado Mazda Club This thread Refback 07-08-2009 02:07 PM
Im in the smoking turbo club.:( SharkDiver MazdaSpeed 3/6 - Turbo Induction 154 09-26-2012 10:16 AM
Smoking turbo issue - Gone for me! kgb MazdaSpeed 3 - Engine, Transmission & Driveline 16 05-27-2009 03:56 PM
Causes/Solutions: Smoking turbo after DP Install kgb MazdaSpeed 3/6 - Turbo Induction 28 02-25-2009 10:58 AM
ANOTHER Smoking Turbo... div2 MazdaSpeed 3/6 - Turbo Induction 23 10-22-2008 07:27 PM
My turbo was replaced under warranty last month and it's smoking again!! BlackMS3 MazdaSpeed 3/6 - Turbo Induction 34 07-26-2008 09:34 PM
Page generated in 0.91018 seconds with 44 queries
