![]() | | #561 | ![]() |
![]() Join Date: Apr 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score
__________________ 00 DPW Honda Prelude 5spd.~ (Husbands) 08.5 CPW Mazdaspeed 3 GT 6spd. ~~(Wifes) | |
![]() | | #562 | ![]() |
![]() Join Date: May 2009 Location: Browns Mills/NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 739
| Not Ranked : 0 score sry this isnt any other turbo car. When you get a catless dp your almost guarenteed to smoke. The best chance you will have is get the ptp pill, an occ, and change to 5w40.
__________________ A Kabar is just a paper weight until it's in the hand of a Marine. If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground. COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS NATOR PA |
![]() | | #563 | ![]() |
| Not Ranked : 0 score ^ comment back FAIL! you are putting down our car..it has a big flaw. haha. i kno thx!
![]() | | #564 | ![]() |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() Thanks: 40
| Not Ranked : 0 score I have an 06 MS6 white pearl, (that was smoking) 22K miles, Saiko OCC installed per COBB, PTP pill, shell 5w 40, and still smoking. Finally about 4 weeks ago I replaced,installed an oil restrictor, for one with less oil flow bolt into the Ko4, surprise, surprise no smoking for a few weeks; Yesterday morning there was heavy traffic on I 10 east Houston and guest what? Smok#$@! It quit soon after. Oh well, the solution alternatives are just too many to list them at this point. Happy trails!! |
![]() | | #565 | ![]() |
__________________ A Kabar is just a paper weight until it's in the hand of a Marine. If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground. COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS NATOR PA | |
![]() | | #566 | ![]() |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
Groans: 105
| Not Ranked : 0 score |
![]() | | #567 | ![]() |
| Not Ranked : 0 score is he still making those, i need to pick one up
![]() | | #568 | ![]() |
![]() Join Date: Jan 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score i'm telling you guys the krank vents solve the problem. people don't realize we have a regular pcv valve that doesn't react fast enough to a change in pressure. when the intake mani goes from vacuum to positive pressure, pressure will be pushed into the crank case due to the pcv valve not closing until .5 to 1 psi, that's more than enough to cause the oil to not drain from the turbo and the pressure from the oil inlet to push the seals out enough to leak. it did this on my big turbo as well, i put the krank vents on and i have been driving for thousands of miles, i'm even about to take a 3000 mile round trip and will be making 100% sure things are sound. So far though i'm quite satisfied when i pull my dip stick out of the hole while the car is running and HEAR the vacuum. Vacuum that should be there, not pressure. The great thing about the krank vents is that they close BEFORE it even reaches 0 or equal pressure. The vent is made to close when the crankcase side is lower pressure than the intake manifold, vacuum or not. i have researched this and have found logic in this, which causes maximum vacuum for the crankcase yet closes to maintain that vacuum while under boost. If anyone wants a technical on how these work and why just let me know and I can explain the mechanics to it.
__________________ Mod list is in the link, too much to place in here ![]() http://www.mazdaspeedforum.org/forum/foru...28/#post413665 |
![]() | | #569 | ![]() |
Groans: 105
| Not Ranked : 0 score yeah i still have to get those krankvents. i was the one who suggested them on these boards |
![]() | | #570 | ![]() |
| Not Ranked : 0 score lol, well quite a suggestion my friend. The operation makes sense unlike some of these other attempts.
![]() | | #571 | ![]() |
![]() Join Date: Nov 2008 Location: Europe
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,476
I might give the krankvents a go. Oil has been seeping through the valve cover vent into and out of the turbo inlet and I'm hoping that installing krankvents might resolve that. Anyway if you feel like it, you might want to post it in the thread on the CrankCase Evacuation System Thanks | |
![]() | | #572 | ![]() |
Groans: 105
| Not Ranked : 0 score smoke is back |
| The Following User Says Thank You to xcoldricex For This Useful Post: | SofaKingAwesome (08-28-2012) |
![]() | | #573 | ![]() |
__________________ Mod list is in the link, too much to place in here ![]() http://www.mazdaspeedforum.org/forum/foru...28/#post413665 | |
![]() | | #574 | ![]() |
| Not Ranked : 0 score Not directly but oil has been leaking over the transmission housing (see pic) and bottom plate. I'm suspecting it leaks past the worm clamp on the inlet of the turbo via the VC breather. After the last three dealer oil changes my oil level was way above max when I checked it at home. Dealer claims they did't overfill but couldn't explain why the level was obviously to high. My theory for the oily mess was that under boost the PCV valve wouldn't shut decently and the crankcase would get pressurized. That pressure would be evacuated through the VC breather. As the car had to much oil I would expect the air flow through the VC to be saturated with an oil aerosol. Funny thing is my car doesn't smoke at all, not even after long periods of idling. I'm planning on disassembling the intake, TIP , I/C and cold pipe to verify and probably clean. Maybe I should put a CC on the VC to make sure the oil comes from there and not from the turbo b/f I go krankvent. /jack |
![]() | | #575 | ![]() |
![]() Join Date: May 2008 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 179
Groans: 46
Don't fret it. | |
![]() | | #576 | ![]() |
| Not Ranked : 0 score The weird thing is I have seen them fill it up. They put in 5 liters (with a digital readout on the fill hose) and check the dipstick which reads low. They put in another .2 liters and it's still between low and max. They put another .2 liter in and it's right below the max sign. The EU manual states 5.7 liters but the 5.4 liters they put in already puts it at max. Then after some driving the dipstick reads way above the max, I mean up to the serpentine thingy in the dipstick... Its like the oil changes density after the first heat cycle I just can't explain it otherwise. |
![]() | | #577 | ![]() |
![]() Join Date: Jun 2008 Location: Long Beach, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
And personally, I wouldn't take an overfill lightly. My last car needed a new valve cover gasket---and I suspect it was my habitual oil overfilling that damaged it. Too much oil --> Too much oil pressure --> Leaks | |
![]() | | #578 | ![]() |
![]() Join Date: May 2009 Location: Little Neck, NY
Rep Power: 3771 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,108
Groans: 326
| Not Ranked : 0 score i go to a local shop since i can get receipts for all my oil changes immediately (they keep all electronically) and they overfilled me once. the amount of blue smoke coming out my tailpipe was incredible. first and easiest route for the excess pressure is your turbo seals. |
![]() | | #579 | ![]() |
![]() Join Date: Sep 2008 Location: Phoenix, AZ
Rep Power: 1352 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 813
| Not Ranked : 0 score Yea I have free oil changes for the life of the car with my dealer, so to cover my ass I just bring my PP to them and have em do the swap. If I bring 6 qts they ALWAYS overfill and I wind up having to drain and still waste time i was trying to avoid.. I now dump half of one of the bottles elsewhere and bring them 5.5. Scary that even dealers don't seem to care about overfilling, unless they know something we don't and the dipstick reads low or somethin like mentioned, but I'd like to hear this confirmed as its much safer to be running a bit under full.
__________________ Some things. |
![]() | | #580 | ![]() |
| Not Ranked : 0 score Think with your dipstick, evidence. It sounds like you already do. Dealership mechanics get paid by the job, not by the hour. They have little incentive to take care and do the job the right way. You've found a way to make it impossible for them to overfill. Stick with it, especially if their labor is "free" to you. I tried a couple times to communicate with the mechanics, but to no avail. Since then I've just been DIY. But I like your idea... |
![]() | | #581 | ![]() |
Groans: 326
| Not Ranked : 0 score well since my fuckup, I have them put 5 quarts in, wait 10 minutes then check the stick and add as necessary. once full, i then have them start the car, let it idle for a minute. turn it off, wait another few minutes and top off as necessary... still comes out over the full line the next time i check it lol |
![]() | | #582 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score Also note this if you push too much boost for the efficiency of most any turbo, excess heat build up can cause seal failure or shaft issues: K04 TURBO REPORT FROM NEUSPEED 2. OPERATION The K04 is designed to provide reliable, long-term service as long as its performance parameters are not exceeded. Driving the car at engine speeds above 5800 rpm with 15spi or greater boost significantly increases the exhaust temperature measured inside the K04 turbine housing. This signals that the maximum efficiency of the turbocharger has been exceeded, and that the energy produced by the turbine housing is now converting to heat rather than accelerating the compressor wheel faster. Unless a careful and extended idle-down is performed at the end of every hard driving session, the rapid heat build-up from high boost/high rpm operation causes the turbine shaft to soften, and allows the inconel turbine head to droop. The result is an imbalance that ultimately leads to a shaft failure.
__________________ Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and torque is how far you make it through the wall. |
![]() | | #583 | ![]() |
Groans: 326
| Not Ranked : 0 score ![]() Thats from a 1.8 VW. not a 2.3 MZR apples to oranges we have it worse off than the VW |
![]() | | #584 | ![]() |
| aspiring turbo guru ![]() Join Date: Dec 2008 Location: Minnesota
Rep Power: 241 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 245
![]() | | #585 | ![]() |
![]() Join Date: Jul 2009 Location: Denton TX
Rep Power: 0 ![]() Thanks: 15
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score GOOD LORD!!!! I believe the 90 day period for deploying the PCV fix has expired. Has Mazda decided otherwise? ![]() Seems very strange that they would make an official announcement of the issue and then never follow up?? Has anyone heard anything or should we all start calling Mother MAZDA?? |
| The Following User Says NO Thank You to morgan2112 For This Un-useful Post: |
![]() | | #586 | ![]() |
Groans: 326
| Not Ranked : 0 score you do that and let us know how it turns out |
| The Following User Says NO Thank You to 8.5MS3 For This Un-useful Post: |
![]() | | #587 | ![]() |
![]() | | #588 | ![]() |
Groans: 326
| Not Ranked : 0 score your about a year too late there tex ![]() Disclaimer: Above pic is not to generalize all texans, just the brownie above |
![]() | | #589 | ![]() |
| Not Ranked : 0 score Don't know about you but I am still under warranty for a few months, and was hoping to get my PCV system fixed for free. Thanks for all your wise tutelage.. |
![]() | | #590 | ![]() |
Groans: 326
| Not Ranked : 0 score enjoy your free oil change, cuz thats all you're getting |
![]() | | #591 | ![]() |
![]() Join Date: May 2011 Location: San Diego
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 64
| Not Ranked : 0 score you know if an after market turbo will end up smoking |
| The Following User Says NO Thank You to ms3destroyer For This Un-useful Post: | Raider (12-09-2011) |
![]() | | #592 | ![]() |
Groans: 326
| Not Ranked : 0 score Last edited by 8.5MS3; 12-09-2011 at 06:28 AM. |
![]() | | #593 | ![]() |
Rep Power: 3168 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| The Following User Says Thank You to 802MS3 For This Useful Post: | Raider (12-09-2011) |
| Im in the smoking turbo club.:( | SharkDiver | MazdaSpeed 3/6 - Turbo Induction | 154 | 09-26-2012 10:16 AM |
| Smoking turbo issue - Gone for me! | kgb | MazdaSpeed 3 - Engine, Transmission & Driveline | 16 | 05-27-2009 03:56 PM |
| Causes/Solutions: Smoking turbo after DP Install | kgb | MazdaSpeed 3/6 - Turbo Induction | 28 | 02-25-2009 10:58 AM |
| ANOTHER Smoking Turbo... | div2 | MazdaSpeed 3/6 - Turbo Induction | 23 | 10-22-2008 07:27 PM |
| My turbo was replaced under warranty last month and it's smoking again!! | BlackMS3 | MazdaSpeed 3/6 - Turbo Induction | 34 | 07-26-2008 09:34 PM |
