Like Tree3Likes
Closed Thread
 Old 07-08-2009, 07:26 PM   #41
DaleNixon's Avatar
Posts: 2,079   (View Stats)
DaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the world
Groans: 91
^ I was thinking the same thing. Can anyone explain?
Gay car #1: 2001 Miata (Gay White)
Gay car #2: 2011 Mazda 2 (Gay Blue)
DaleNixon is offline
The Following User Says Thank You to DaleNixon For This Useful Post:
ICNSYDU (03-08-2010)
 Old 07-08-2009, 07:32 PM   #42
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Probably not drain better, but just leak thru the seals worse.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
djuosnteisn is offline
 Old 07-08-2009, 07:34 PM   #43
DaleNixon's Avatar
Groans: 91
Wouldn't that just worsen things if our PCV system is faulty?
 Old 07-08-2009, 07:39 PM   #44
GoSpeed3Go's Avatar
Posts: 493   (View Stats)
GoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the world
Groaned at 27 Times in 8 Posts
thicker oil = more pressure? i guess im on the waiting list for the new pcv. i have 27000 and no issues for now but recall or not, if mazda feels they need to revise a part to help the car last longer i will haz it.
GoSpeed3Go is offline
The Following User Says Thank You to GoSpeed3Go For This Useful Post:
 Old 07-08-2009, 07:43 PM   #45
Captain
I think the pcv is gonna be faulty regardless what weight oil you use, so the thicker one will just result in less seal leakage.
In other news, mazda announced their fix, All speed owners get to choose a new turbo of their choice!
www.permtuning.com
 Old 07-08-2009, 07:53 PM   #46
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
Originally Posted by GoSpeed3Go View Post
i dont understand how using a thicker weight oil can help it drain better.
don't believe it helps it drain better, just slows the rate at which the oil enters the turbo allowing what oil is in there to drain adequately.
bova is offline
The Following User Says Thank You to bova For This Useful Post:
 Old 07-08-2009, 08:14 PM   #47
jtspells's Avatar
Posts: 634   (View Stats)
jtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the world
I would personally say our best bet of a recall would be if the CX-7 owners pipe up, If we say anything the problem will allways be "it is because we are modding" or the MS6/MS3 croud are saitanic devils but if the CX-7 owners pipe up well than we might just have a recall on our hands......
jtspells is offline
The Following User Says Thank You to jtspells For This Useful Post:
 Old 07-08-2009, 08:23 PM   #48
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
I've already had a turbo from Mazda and since then I added my dp/rp and now I'm spitting oil out the tail pipe at startups and smoking at idle again - I"m wondering the garrett turbos have a nice fat stainless line that drains and hooks right up to where it goes back into the pan - Has anyone not come up with a better drain line to what I've got picd here - I know the oem one has these little steps down to the line - maybe they slow the oil down
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
cpolly69 is offline
The Following User Says Thank You to cpolly69 For This Useful Post:
 Old 07-08-2009, 11:30 PM   #49
MZRDISI4's Avatar
Posts: 1,430   (View Stats)
MZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the world
Groans: 94
Groaned at 38 Times in 19 Posts
Mazda issuing a recall = Safety or Emissions related.
"We already have the Speed6 replacement" "It's just called the CX-7 now"
back at http://www.mcx7.com bitches, spam free
MZRDISI4 is offline
The Following User Says Thank You to MZRDISI4 For This Useful Post:
 Old 07-09-2009, 07:29 AM   #50
bnoon's Avatar
Posts: 1,770   (View Stats)
You can bet burning oil can clog cats and will throw emissions sniffers for a loop during testing.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
bnoon is offline
The Following User Says Thank You to bnoon For This Useful Post:
 Old 07-09-2009, 08:05 AM   #51
The reason the oil does not drain well enough is because the crankcase pressure is too high for the drain requirements from the turbo. This is an indication that the PCV system does not relieve crankcase pressure adequately for this particular turbo to work with the existing drain hardware. So this is their approach. Another approach is to increase exhaust back pressure (this is why removing the cats makes things worse), and another approach is to reduce the volume of oil entering the turbo (Bnoons bolt). There's more than 1 way to skin a cat.
Lex is offline
 Old 07-09-2009, 08:05 AM   #52
ToledoSpeed3's Avatar
Posts: 244   (View Stats)
ToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the world
It doesn't, this is being done to treat the symptom, not the actual problem. Thicker oil is known to reduce burn off. The new PCV system they are working on is being done to address the actual problem.
ToledoSpeed3
09 MazdaSpeed3 GT, True Red
ToledoSpeed3 is offline
The Following User Says Thank You to ToledoSpeed3 For This Useful Post:
 Old 07-09-2009, 08:41 AM   #53
Trader's Avatar
Posts: 90   (View Stats)
Trader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to behold
Groaned at 5 Times in 1 Post
Originally Posted by tunersteve View Post
.....This fix will be available approximately within 90 days and at that time the oil will be changed back to 5W-30 and the improved PCV system will be installed....
So the fix should be available 90 days after the email was issued. Any idea when this email was issued? Just trying to estimate when this will be available.
Trader is offline
The Following User Says Thank You to Trader For This Useful Post:
 Old 07-09-2009, 09:08 AM   #54
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
My dealer was supposedly able to pull up this notice on the Mazda dealer web site. Perhaps I can get them to call and find out?
triplejumper18 is offline
The Following User Says Thank You to triplejumper18 For This Useful Post:
 Old 07-09-2009, 09:36 AM   #55
tunersteve's Avatar
Posts: 869   (View Stats)
tunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the world
Here's my response from my dealer about the 'spreadsheet' that I keep for my oil changes:
Keeping it on a spreed sheet is better than nothing, but I would suggest you start writing the mileage and date on the top of the sales receipts for your oil and filter as well. But this is still no guarantee. When someone has a concern with an engine or power train component and we don't have detailed records Mazda will usually require partial tare down before they will authorize or deny a claim, such as removing a valve cover or oil pan to check for sludge or signs of lack of maintenance. We do not make the call at the dealer level. Mazda has to authorize all major claims.
Just for future reference, we certainly don't have a problem using your oil if you would like us to do your maintenance for you. I have several customers we do that for. The bill comes to about $15 for labor and filter. This way you would have records with Mazda as well.
2011 Mustang GT
tunersteve is offline
The Following User Says Thank You to tunersteve For This Useful Post:
 Old 07-09-2009, 11:09 AM   #56
MOVOVR's Avatar
Posts: 200   (View Stats)
MOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond reputeMOVOVR has a reputation beyond repute
Hey everyone, here's the email I received from my local service manager after I stopped in to question him about the 5w-40 rumors.
SMOKE FROM TAIL PIPES AFTER PROLONGED IDLE PERIODS
Applicable Models
Model Starting S/N Ending S/N Model Spec CX7 2007-2008 000001 209008 P/D BEFORE 2/15/2008 MAZDA6 2006-2007 000001 999999 ALL MAZDASPEED6 MAZDA3 2007-2008 000001 880368 P/D BEFORE 2/6/2008 Related Category/Subcategory/Symptoms
ENGINE / MECHANICAL / WHITE SMOKE,BLUE SMOKE
ENGINE / EMISSIONS SYSTEM / EXCESSIVE OIL CONSUMPTION
ENGINE / EMISSIONS SYSTEM / WHITE SMOKE,BLUE SMOKE
ENGINE / EMISSIONS SYSTEM / BLACK SMOKE
ENGINE / MECHANICAL / EXCESSIVE OIL CONSUMPTION
MTOL - 5505 Dealer Repair Information
Symptom and Conditions
Applicable Model(s) VINS
CX-7 JM3ER ****8* 209008 Produced before 2/15/08
MAZDASPEED6 ALL ALL
MAZDASPEED3 JM1BK ****8* 880368 Produced before 2/6/08
Some customers may experience white/blue smoke from their exhaust pipes
after prolonged idle periods and/or while driving in traffic at very
slow speeds.
This condition may be the result of the turbo's oil supply not being
able to adequately drain out of the turbo during long idle periods.
Vehicles having this concern should be diagnosed using the following diagnostics procedure.
Repair Procedure
1. Confirm that the proper maintenance intervals have been performed.
2. With the engine at normal operating temperature, allow it to idle
for an extended idle period.
Caution:
Closely monitor the engine coolant to the assure the engine does not Overheat.
3. If smoke from the exhaust is present after the extended idle period,
take before pictures of the smoke, then change the oil and filter
using 5W/40 (synthetic). After the oil change, in order to burn off
the oil that remains in the exhaust system, perform the following:
start the engine, check for oil leaks, then let it idle for 10
minutes, after the 10 minute idle period, increase the RPMs to 3000
for 1 minute, repeat idle test to confirm that no smoke returns.
A: If the smoke returns, contact the Technical Assistance Hotline
(Select option #2 for Major Assembly Authorization) with the oil
change history information, to attain an authorization for a turbo
replacement.
B: If smoke DOES NOT RETURN after the repeat idle test, NO other repairs
are to be performed at this time. Explain to the customer that MAZDA
is currently working on an improved positive crankcase valve (PCV)
system to reduce the engine crankcase pressures to allow the turbo's
oil supply to drain from the turbocharger more efficiently This fix
installed
Sounds like something is on its way for this problem. I searched but couldn't find any info that was similar to this.
No offense to the OP but can anyone verify this came from Mazda? What dealership/local service manager did it come from and how did he/she obtain it?
MOVOVR is offline
The Following User Says Thank You to MOVOVR For This Useful Post:
 Old 07-09-2009, 11:11 AM   #57
Groans: 196
My dealer was supposedly able to pull it up on the Mazda dealer website as well.
 Old 07-09-2009, 12:00 PM   #58
xandrake's Avatar
Posts: 575   (View Stats)
xandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the world
So when you go in do you need to go back to stock even when they know there is an issue with OE parts?
xandrake is offline
The Following User Says Thank You to xandrake For This Useful Post:
 Old 07-09-2009, 12:26 PM   #59
BoostIsBetter's Avatar
Posts: 582   (View Stats)
BoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the world
Groans: 32
Groaned at 31 Times in 18 Posts
My best guess would be that if it's a recall, then NO, but if it's a service bulletin, then yes, any other inputs guys?
BoostIsBetter is offline
The Following User Says Thank You to BoostIsBetter For This Useful Post:
 Old 07-09-2009, 01:01 PM   #60
tunersteve's Avatar
I don't think I'd take a chance with modded parts at a dealer no matter what reason you take it in.
And, as far as the validity of it, I'm merely re-posting what was sent to me. The Mazda info #s are there, so you should be able to take this to a dealer and have it reproduced in some form. I currently have someone at another local dealer trying to get confirmation of this. i too was a skeptic with all the rumors flying, until I read this.
2011 Mustang GT
 Old 07-09-2009, 01:25 PM   #61
smakdown61's Avatar
Posts: 1,069   (View Stats)
Remember guys, if its just a TSB from Mazda they won't do anything for you unless you are showing the symptoms stated in the bulletin. Simply walking in there and demanding the new pcv even though your turbo isn't smoking will result in a "fuck off" face by your dealer.
I hope the part itself isn't too expensive if we want to do it ourselves.
smakdown61 is offline
The Following 2 Users Say Thank You to smakdown61 For This Useful Post:
ICNSYDU (03-08-2010), steven88 (07-10-2009)
 Old 07-09-2009, 05:29 PM   #62
6SpeedTA95's Avatar
Posts: 384   (View Stats)
6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world
Groaned at 7 Times in 5 Posts
I was glad to see this come from Mazda but I'm still concerned about the 2.3 turbo motors in these cars. I plan(ned) on purchasing a 2009 or 2010 speed3, but after reading all the blown motor threads its kinda got me bummed as this car fit my agenda perfectly. But I've not given up yet, I'm hoping we get something from mazda shortly that addresses the cause of the problem...
6SpeedTA95 is offline
 Old 07-09-2009, 08:13 PM   #63
smakdown61's Avatar
Hate to break it to you, but you'll see engine blow stories on any forum for any car like this. It's the nature of a forum. People don't post up thing like "my engine runs great!".
The Following 3 Users Say Thank You to smakdown61 For This Useful Post:
ICNSYDU (03-08-2010), leadf00t (07-15-2009), ms686 (07-13-2009)
 Old 07-09-2009, 09:31 PM   #64
Captain
I'd be too scared of jinxing myself.
www.permtuning.com
 Old 07-09-2009, 10:57 PM   #65
steven88's Avatar
Posts: 773   (View Stats)
Groaned at 9 Times in 5 Posts
very very true...
i work at a dealership and we get calls all the time from people who say "yeah i read it on the internet, so i'm coming in to get it done"....it does not work like that...
steven88 is offline
The Following 3 Users Say Thank You to steven88 For This Useful Post:
DaleNixon (07-10-2009), ICNSYDU (03-08-2010), tunersteve (07-11-2009)
 Old 07-10-2009, 02:07 PM   #66
6SpeedTA95's Avatar
That sir is an excellent point, but the number of blown motor threads and threads where mazda is denying warranty work seems abnormally high when compared with other vehicles like the VW turbo stuff...
But having said that I recall reading numerous oil burn/MAF/wheel bearing threads on the maxima forums before and after I purchased my 02. I have none of those issues, only issue I've had was a bad gas cap (twice). Other than the car has been great, burns zero oil, runs like a champ. But you read the forums and you'd swear half the cars burn a quart of oil every 1500 miles...thats just not the case.
I called my local mazda service dept and asked them how many blown 2.3's they've seen regardless of model, the service manager told me he's seen one on a pretty heavily modded speed3. I called a couple others in neighboring cities both service managers/asst managers said they ahd seen none.
The Following User Says Thank You to 6SpeedTA95 For This Useful Post:
 Old 07-13-2009, 10:57 PM   #67
ms686's Avatar
Posts: 11   (View Stats)
ms686 will become famous soon enough
so very very very true. people with problems are far more likely to post on the internet than people that are doing great. I mean its not like 50% of us have blown engines although reading these forums you might think so.
if you worked at a dealership you would think that the brand of cars your are servicing are shitty. but in reality you are standing at the short end of the funnel. kinda like standing at the genius bar at an apple store, you would probably never buy an apple product ever; but the reality is that for every one person with a problem there are probably 50 that are doing fantastic. plus everyone drives/uses their ish differently and most seem to beat on it pretty hard. me... I dont like going WOT unless I'm trying to log or beat some punk in a riced out G35 or something
ms686 is offline
The Following User Says Thank You to ms686 For This Useful Post:
 Old 07-14-2009, 09:13 AM   #68
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
I asked my service rep at mazda when i had my car looked at for something different. He said that they only do this if the customer notices exhaust smoke and comes in, they arent just replacing then depending on vins. If you have a problem they fix it. Also, in the past i asked the master tech at mazda about dps, he said as long as they did the install work he would keep my warranty and replace/fix anything problems that came along with the dp swap.
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline
The Following User Says Thank You to clos561 For This Useful Post:
 Old 07-15-2009, 01:28 AM   #69
AlpineLakes's Avatar
Posts: 14   (View Stats)
AlpineLakes is a jewel in the roughAlpineLakes is a jewel in the roughAlpineLakes is a jewel in the rough
Thanks for the great info. I recently installed Corksport RP/DP on my 8.5 MS3 and have been put on some spectacular shows in traffic leaving work recently. It's just a matter of time before I smoke an officer right out of his cruiser and get a ticket for the exhaust modifications >:/
What's the best course of action? Switch to 5W/40 synthetic and wait for Mazda?
AlpineLakes is offline
The Following User Says Thank You to AlpineLakes For This Useful Post:
 Old 07-15-2009, 05:27 AM   #70
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
u need to buy a bnoon bolt asap. http://www.mazdaspeedforum.org/forum/foru...nce-all-4.html
Do it now
09 MGM MS3
Addikted To Boost is offline
The Following User Says Thank You to Addikted To Boost For This Useful Post:
 Old 07-15-2009, 05:28 AM   #71
RUMBLEFISH's Avatar
Posts: 730   (View Stats)
RUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the world
Groans: 32
My dealer said the car better be factory stock and have all oil change paperwork or get the fuck out of my shop.
So I left.
2008.5 Metro Gray Speed 3 t bone motor mount, CPE Nano, TIP,Corksport RP, HYPER box tune.
RUMBLEFISH is offline
The Following User Says Thank You to RUMBLEFISH For This Useful Post:
 Old 07-15-2009, 09:32 AM   #72
Poohster's Avatar
Posts: 353   (View Stats)
Poohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the world
I have a catted DP on MS6 with a MPI upgraded K04. I get smoke every now and then. MPI stated that the upgraded K04 may still smoke. I do use 5W40 and may try 5W50. The 5W40 did stop my OE k04 from smoking but just like you the DP push me over the edge.
I say give the 5W40 a try. I find the bnoon banjo bolt intriguing but fearful of starving a wet seal of oil. bnoon has done his homework and feels there is an adequate supply of oil. I am going to wait for Mazda's improved positive PCV system and get the parts to install myself or have MPI do it or possibly investigate alternatives. Good luck.
06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP
RPM: Sport Springs, Shark Fin, LED side markers
CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount
Poohster is offline
The Following User Says Thank You to Poohster For This Useful Post:
 Old 07-15-2009, 12:29 PM   #73
bnoon's Avatar
Just FYI, my info comes from G-Pop Shop, one of the few reputable rebuilders/modifiers of KKK turbos. They gave me the recommended restrictor size and believe enough in my idea that they are sending any restrictor inquiries for the K04 my direction!!!
2002 BMW M3 - Sold!
bnoon is offline
The Following 3 Users Say Thank You to bnoon For This Useful Post:
ICNSYDU (03-08-2010), nytmar3 (01-23-2010), Poohster (07-16-2009)
 Old 07-15-2009, 02:44 PM   #74
Thanks. Sure you MSP gets in the left lane and gets us the updated valve like yesterday!
 Old 07-16-2009, 12:26 AM   #75
Could this problem be exacerbated by an incorrectly adjusted BPV? I note my BPV is venting even under low boost conditions and wonder if change might be a factor?
I'm learning up here so forgive a likely dumb question. Thanks.
 Old 07-22-2009, 12:57 AM   #76
Dino V's Avatar
Posts: 134   (View Stats)
Dino V is a splendid one to beholdDino V is a splendid one to beholdDino V is a splendid one to beholdDino V is a splendid one to beholdDino V is a splendid one to beholdDino V is a splendid one to beholdDino V is a splendid one to beholdDino V is a splendid one to behold
nice write-up! thanks for sharing!
Dino V is offline
The Following User Says Thank You to Dino V For This Useful Post:
 Old 08-06-2009, 09:43 PM   #77
GoSpeed3Go's Avatar
anyone hear if mazdas put out the new pcv yet? i wonder if the 2010 ms3 already has it equipped.
 Old 08-06-2009, 09:59 PM   #78
Babyface's Avatar
Posts: 320   (View Stats)
Babyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the world
subbing for info
Babyface is offline
The Following User Says Thank You to Babyface For This Useful Post:
The Following User Says NO Thank You to Babyface For This Un-useful Post:
 Old 08-07-2009, 06:38 AM   #79
DaleNixon's Avatar
Groans: 91
Not to sound like a dick, dude, but you should use the thread tools->subscribe to thread feature instead of posting "subbing". It'll save you from public ridicule.
The Following 3 Users Say Thank You to DaleNixon For This Useful Post:
Babyface (08-08-2009), FreeFlyFreak (08-09-2009), ICNSYDU (03-08-2010)
 Old 08-07-2009, 09:02 AM   #80
tunersteve's Avatar
Haven't heard anything on updates yet. I figure I'll wait for another month or two before I try to get it fixed.
2011 Mustang GT
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/official-smoking-turbo-response-mazda-32008/
Mazda3 Totaled (ouch pics) Now a MS3 owner - Mazda3Forums.com This thread Refback 10-07-2012 09:30 AM
• View topic - MPS reputable dealer in Cape Town (long idle smoke) This thread Refback 09-17-2012 02:43 PM
MS3 Mazdaspeed 3 Smoking Turbo @ Dealership - YouTube This thread Refback 10-11-2011 08:47 AM
‪MS3 Mazdaspeed 3 Smoking Turbo @ Dealership‬‏ - YouTube This thread Refback 07-24-2011 03:58 PM
YouTube - ‪MS3 Mazdaspeed 3 Smoking Turbo @ Dealership‬‏ This thread Refback 05-18-2011 11:13 PM
Mise fire Mazdaspeed 3 2008 This thread Refback 11-24-2010 01:14 PM
YouTube - MS3 Mazdaspeed 3 Smoking Turbo @ Dealership This thread Refback 11-03-2010 11:35 AM
ANy love for the Mazdaspeed6?: Grassroots Motorsports forum: Grassroots Motorsports Magazine This thread Refback 06-15-2010 06:54 PM
NASIOC - View Single Post - The Mazdaspeed 3 Thread This thread Refback 12-29-2009 11:13 AM
The Mazdaspeed 3 Thread - Page 120 - NASIOC This thread Refback 12-21-2009 08:36 AM
Mazda6 / Atenza > mazda admits smoking problem!!!!!! This thread Refback 08-18-2009 07:54 PM
2.3disit Smoking Turbo - Club Mazda This thread Refback 07-10-2009 11:13 AM
smoke, has anyone had this? - Page 2 - COBB Forums This thread Refback 07-09-2009 08:02 PM
mazda admits smoking problem!!!!!! - Mazda6 / Atenza This thread Refback 07-08-2009 03:45 PM
Official Smoking Turbo response from Mazda - Colorado Mazda Club This thread Refback 07-08-2009 02:07 PM
Im in the smoking turbo club.:( SharkDiver MazdaSpeed 3/6 - Turbo Induction 154 09-26-2012 10:16 AM
Smoking turbo issue - Gone for me! kgb MazdaSpeed 3 - Engine, Transmission & Driveline 16 05-27-2009 03:56 PM
Causes/Solutions: Smoking turbo after DP Install kgb MazdaSpeed 3/6 - Turbo Induction 28 02-25-2009 10:58 AM
ANOTHER Smoking Turbo... div2 MazdaSpeed 3/6 - Turbo Induction 23 10-22-2008 07:27 PM
My turbo was replaced under warranty last month and it's smoking again!! BlackMS3 MazdaSpeed 3/6 - Turbo Induction 34 07-26-2008 09:34 PM
Page generated in 0.65063 seconds with 47 queries
