| Not Ranked : 0 score
Big Turbo Oil and Coolant Line How-To I am going to use -10AN push lock hose and push lock fittings. (you'll need one straight and 1 90*) 802ms3 and njspeed3 brought these fittings to my attention (gasket-less o-ring design) EFR & Garrett GT Oil Drain Return Flange, -10AN- TREADSTONE PERFORMANCE @btstarcher; forgot to mention... that is a pretty high heat area, so you will also want to cover that line with a strong heat reflective sleeving. | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | btstarcher (11-25-2012) |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
| The Following 2 Users Say Thank You to breakfstincluded For This Useful Post: | btstarcher (11-25-2012), rfinkle2 (11-25-2012) |
(Thread Starter) | Not Ranked : 0 score LMAO! Shit I starting reading that thread but didn't read far enough....just assumed it was for the oil feed line. Thanks guys.
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress | |
The BNR is 100% plug and play. | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | breakfstincluded (11-27-2012) |
(Thread Starter) | Not Ranked : 0 score LOL 2nd reading fail of the day. He was referring to the oild feed line, not the return. It makes sense now; why the fuck would you want to restrict the return line? I'm on a roll today.
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
I have a braided SS line so I'm less concerned..but god do I love heat shielding LOL I'm just curious if you are in fact talking about the return line and secondly who's running what for heat protection.
__________________ | |
Groans: 219
| Not Ranked : 0 score Double post because Kevin touches himself.
I think that all premade return lines are SS braided so they are pretty tough. If using something rubber like the push lock, I would use something like this: Heat Shroud 010405 | Purchase DEI, CryO2, Ny-Trex, Boom Mat & SPA Turbo Products | Design Engineering, Inc. - Thermal Performance Products | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | helmetface (11-27-2012) |
Groans: 219
Thanks
| The Following User Says Thank You to helmetface For This Useful Post: | rfinkle2 (11-27-2012) |
| Not Ranked : 0 score |
![]() Join Date: Oct 2016
Rep Power: 0 ![]() Thanks: 1
Groaned at 7 Times in 3 Posts
| Not Ranked : 0 score So you guys think it will work fine with a stock ko4 and a kosmic return line ? |
| The Following User Says NO Thank You to Mazdamike2012 For This Un-useful Post: | Vansquish (11-01-2016) |
| lol sent from my Pixel XL
![]() Join Date: Nov 2010 Location: Columbus, GA
Rep Power: 4253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,493
Groans: 307
| Not Ranked : 0 score give it a shot...
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() |
| CDFP return line | 06Speed6 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 15 | 01-14-2010 12:13 PM |
| Turbo Oil Return Line | 11cruzito11 | MazdaSpeed 3/6 - Turbo Induction | 21 | 09-27-2009 09:15 PM |
