 Old 11-25-2012, 02:57 PM   #1
btstarcher's Avatar
Posts: 4,852   (View Stats)
Default Oil return line options?
When my number 3 rod exited my block, it happened to take out my oil return line. Should I just replace with OEM, or should I go a different route? Also I plan on upgrading to a beaner next spring, if that even matters...
SnailTune in progress
 Old 11-25-2012, 04:48 PM   #2
I think most of the info you are looking for is here:
Big Turbo Oil and Coolant Line How-To
I am going to use -10AN push lock hose and push lock fittings.
(you'll need one straight and 1 90*)
802ms3 and njspeed3 brought these fittings to my attention (gasket-less o-ring design)
EFR & Garrett GT Oil Drain Return Flange, -10AN- TREADSTONE PERFORMANCE
@btstarcher; forgot to mention... that is a pretty high heat area, so you will also want to cover that line with a strong heat reflective sleeving.
btstarcher (11-25-2012)
 Old 11-25-2012, 04:53 PM   #3
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
SSP Oil Return Line Kit MS3
this would be a very expensive option then hmmm
The Following 2 Users Say Thank You to breakfstincluded For This Useful Post:
btstarcher (11-25-2012), rfinkle2 (11-25-2012)
 Old 11-25-2012, 05:54 PM   #4
btstarcher's Avatar
LMAO! Shit I starting reading that thread but didn't read far enough....just assumed it was for the oil feed line. Thanks guys.
 Old 11-27-2012, 12:14 PM   #5
btstarcher's Avatar
After re-reading the thread on my computer, does the information hold true for the stock turbo? I saw somewhere that the OEM oil return line had a restrictor built-in; should I just go with an OEM line? I'm so confused....
 Old 11-27-2012, 12:17 PM   #6
The drain / return line doesn't need a restrictor etc. and for the BNR's bearing system, will not need a restrictor (on the feed line).
The BNR is 100% plug and play.
breakfstincluded (11-27-2012)
 Old 11-27-2012, 12:23 PM   #7
btstarcher's Avatar
LOL 2nd reading fail of the day. He was referring to the oild feed line, not the return. It makes sense now; why the fuck would you want to restrict the return line? I'm on a roll today.
The Following 2 Users Say Thank You to btstarcher For This Useful Post:
06Speed6 (11-27-2012), rfinkle2 (11-27-2012)
 Old 11-27-2012, 12:24 PM   #8
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Iforgot to mention... that is a pretty high heat area, so you will also want to cover that line with a strong heat reflective sleeving.
Are you talking about the return line? I was just talking to someone about this the other day and they had said they had never seen anyone do it.
I have a braided SS line so I'm less concerned..but god do I love heat shielding LOL
I'm just curious if you are in fact talking about the return line and secondly who's running what for heat protection.
 Old 11-27-2012, 12:29 PM   #9
helmetface's Avatar
Groans: 219
Double post because Kevin touches himself.
 Old 11-27-2012, 12:30 PM   #10
We are 100% on the same page (return line).
I think that all premade return lines are SS braided so they are pretty tough.
If using something rubber like the push lock, I would use something like this:
Heat Shroud 010405 | Purchase DEI, CryO2, Ny-Trex, Boom Mat & SPA Turbo Products | Design Engineering, Inc. - Thermal Performance Products
helmetface (11-27-2012)
 Old 11-27-2012, 12:33 PM   #11
helmetface's Avatar
Groans: 219
That's some nice stuff, I'll have to bookmark it for future projects.
Thanks
 Old 11-27-2012, 02:25 PM   #12
It happens man.
I fuck some threads up royally sometimes.
 Old 10-31-2016, 07:07 PM   #13
Mazdamike2012's Avatar
Posts: 4   (View Stats)
Mazdamike2012 can only hope to improve
Groaned at 7 Times in 3 Posts
So you guys think it will work fine with a stock ko4 and a kosmic return line ?
Mazdamike2012 is offline   Reply With Quote
The Following User Says NO Thank You to Mazdamike2012 For This Un-useful Post:
Vansquish (11-01-2016)
 Old 10-31-2016, 08:11 PM   #14
 Old 10-31-2016, 08:25 PM   #15
lol
sent from my Pixel XL
 Old 10-31-2016, 08:52 PM   #16
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
give it a shot...
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
CDFP return line 06Speed6 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 15 01-14-2010 12:13 PM
Turbo Oil Return Line 11cruzito11 MazdaSpeed 3/6 - Turbo Induction 21 09-27-2009 09:15 PM
Page generated in 0.36194 seconds with 27 queries
