 Old 06-01-2009, 11:48 AM   #41
ATE BALLER's Avatar
Posts: 3,227   (View Stats)
MAF is in the coldpipe now. I have to take it easy to not blow a pipe off, but it runs really smooth in closed loop. My AFRs bumped up by about two points. ECU was reset ~150 miles ago though, so that might still be learning.
I got it to 15 psi last night before it blew the pipe off again, and it felt awesome! Runs fine when the pipe blows off too, just no boost. It's like driving a 6i with an exhaust and an intake, lol. I'm trying to find someplace locally I can have weld it all up for me this week. Then I'll have no worries until I 'need' a larger housing.
Funny note, iat never goes above 90, but bat still climbs to low 100s. Even though the sensors are ~12" apart, lol.
Originally Posted by StreetUnitMark View Post
I don't think I could go one day without some sort of meat in my mouth.
ATE BALLER is offline   Reply With Quote
The Following 3 Users Say Thank You to ATE BALLER For This Useful Post:
labikesrcool (06-01-2009), masskaos (06-01-2009), SpeedSixxx (01-29-2010)
 Old 06-01-2009, 02:01 PM   #42
masskaos's Avatar
Posts: 262   (View Stats)
masskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond repute
nice work man...
bat's being higher have to do with the intake manifold conducting head from the head. you have a significantly larger surface area of the intake manifold that mates to the head... and the manifold is aluminum which conducts heat well. the thin wall of piping for the MAF will not soak up as much heat.
masskaos is offline   Reply With Quote
 Old 06-01-2009, 02:10 PM   #43
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
might have to try this out on my corksport fmic setup. doesn't seem like i'll need much other than a couple couplers, maf housing, piece of straight pipe and air straightener.
 Old 06-01-2009, 02:21 PM   #44
blaggah's Avatar
Posts: 132   (View Stats)
blaggah has much to be proud ofblaggah has much to be proud ofblaggah has much to be proud ofblaggah has much to be proud ofblaggah has much to be proud ofblaggah has much to be proud ofblaggah has much to be proud ofblaggah has much to be proud ofblaggah has much to be proud ofblaggah has much to be proud of
This is exactly what I'm thinking. There is a nice length of straight pipe right before the throttle body that could be replaced witih a larger pipe and MAF housing and air straightener.
blaggah is offline   Reply With Quote
 Old 06-01-2009, 03:46 PM   #45
ATE BALLER's Avatar
Make sure to get the pipe ends bead rolled or you'll be going through what I am right now; blowing pipes apart, lol.
 Old 06-01-2009, 03:50 PM   #46
JumpingJackson's Avatar
Posts: 967   (View Stats)
Pics of your cold pipe?
 Old 06-01-2009, 03:59 PM   #47
ATE BALLER's Avatar
I'll post some up when I get home. They are ones I took right when I finished (before any safety chain, lol).
 Old 06-01-2009, 04:05 PM   #48
Someone should sell MAF blowthrough cold pipes haha!
The Following User Says Thank You to JumpingJackson For This Useful Post:
dougefresh_ (05-11-2010)
 Old 06-01-2009, 05:21 PM   #49
ATE BALLER's Avatar
Here's the pics...
The Following User Says Thank You to ATE BALLER For This Useful Post:
jayspeed3 (06-01-2009)
 Old 06-01-2009, 05:49 PM   #50
MarkyMark's Avatar
Posts: 1,624   (View Stats)
MarkyMark has disabled reputation
Groans: 62
Groaned at 156 Times in 148 Posts
so you think im safe to do it this way?
i ready to build my intake and FMIC piping.
MarkyMark is offline   Reply With Quote
The Following User Says NO Thank You to MarkyMark For This Un-useful Post:
 Old 06-01-2009, 07:09 PM   #51
ATE BALLER's Avatar
I've been driving around like this with no problem for the last couple days. Mostly in closed loop though. I'll be talking to a welder tomorrow, so if you want, you could sit tight til the weekend. This WILL be 100% opperational after saturday, one way or another. I really hope I won't be maxing out the maf at wot though, cause I still don't have a way to tune the damn thing, lol. I know I will be with the 60 trim, but I don't want to have to use a bigger maf for the stocker. That would suck, lol.
 Old 06-01-2009, 07:29 PM   #52
MarkyMark's Avatar
Groans: 62
Lol good luck. I wont be fabbing anything until this weekend at least. i was just outside and fitting in that 3.5" housing with the rest of my FMIC piping is gonna be damn near impossible.
 Old 06-01-2009, 08:10 PM   #53
i dont understand why this is blowing off? i run 23 psi and maby 5/16 pipe ends are bead rolled on my setup.
 Old 06-01-2009, 11:58 PM   #54
jayspeed3's Avatar
Posts: 356   (View Stats)
jayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond repute
Groans: 60
^^^WTF!!!
Performance Mods: Cobb AP, e48 Tune (22psi), Cobb SF w/ Amsoil Filter, RPMC TIP, Synapse Synchronic BOV, Custom FMIC w/ Godspeed Type C, CP-e DP, Custom CBE, KMD v2 CDFP Internals, Denso ITV-22, MattD OCC, Castrol Edge 5w30, XT-M5-QS Gear Oil, SU RMM, Cobb STS, Cobb Stage2 Suspension Kit, Bilstein HD, RX-8 Wheels, Toyo Proxes 4 Plus (235/40/18)
jayspeed3 is offline   Reply With Quote
 Old 06-09-2009, 11:46 AM   #55
ATE BALLER's Avatar
Here's what happens when you don't use the right things to start with...
Happens whenever I get to anxious and foot-happy. Once it's all welded together, I won't have any more worries about this though. I think I'm going to use ECUedit to scale the MAF for 3". I have a tactrix openport 2.0 en route, but I need Epifan to get back to me with some answers first. So I need to scower the atr section on msf pretty soon so I can get the flash ready to load while I'm waiting on the welder. I'll drive nice and easy for a hundred miles or so if all seems well and take it from there.
Oh, here's another shot of the maf...
 Old 06-09-2009, 08:25 PM   #56
ispypsi's Avatar
Posts: 303   (View Stats)
ispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the world
get rid of those cheapo slippery couplers that are too short! and those failures they call worm clamps.
i never had my piping on my 240 bead rolled. i should have but the baller ATP couplers at the times with T-bolt clamps held 20 something psi on a big ass t3/t4. plus i had my piping damn near butted up against each other inside the couplers, it was a tight fit setup.
i bet if you got some t-bolt clamps and some nicer couplers (try 4 or 5 ply), you would be pretty well off. that one coupler looks like the autozone spectre stuff i bought and fabbed up once. works good for an intake, not so much for pressurized piping
Dan - '08 MS3, some kinda silver
ispypsi is offline   Reply With Quote
 Old 06-09-2009, 11:48 PM   #57
ATE BALLER's Avatar
Nope, I'm not spending any more money on couplers or clamps right now. I have a 4 ply 3" coupler (now holding the two 90* pipes together so far) with t-bolts, and a 4 ply 3"-2.75" reducer (now on the bottom side of the assembly and holding) also with t-bolts. One of those will end up holding the whole thing to the tb once it's all welded. If that doesn't hold, I guess I'll have to try a hump hose. Don't want to though.
I also want to make note that my IAT has decreased from what it would read in the stock location. On a 70* day, it used to read ~95* with a gutted stock airbox with the BAT sitting between 90* and 105* depending on how fast I was moving. Now with outside temps in the 80s, I'm seeing ~85-90* on the IAT and 95-110* on the BAT. In traffic the BATs can climb to ~115* or so. I thought they would be a closer measurement since they are both being taken after the ic, but it seems that either the ecu is using the maf AND map to calculate the BAT, or there is alot of heat transfering to the map, possibly through the intake manifold.
Again, this is all in closed loop cruizing and mild-average excelleration conditions only as of right now.
 Old 06-10-2009, 12:51 AM   #58
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
what the fuck. i thought you had measured this a bunch. i didn't read either of the last two posts, but how did that happen 8?
too much hweed?
 Old 06-10-2009, 11:15 AM   #59
ATE BALLER's Avatar
It's all measured. It's just too much powah for the pos couplers I'm using, lol.
Just as I finish reading the reply from epifan, the package carrying my openport 2.0 cable lands on my desk. He says it can change everything in the ECU I inquired about and alot more, so I'm going to go ahead and buy it tonight after work.
Now all I'm waiting on is the honeycomb air straightener and I can weld everything up.
Wish me luck!
phillyb (06-10-2009)
 Old 06-10-2009, 11:21 AM   #60
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
GL again.
You sure have been demanding alot of luck lately.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 06-10-2009, 11:25 AM   #61
phillyb's Avatar
Groans: 1,940
good luck
 Old 06-10-2009, 11:28 AM   #62
Team Überfrazn
labikesrcool's Avatar
Posts: 782   (View Stats)
labikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the world
GL again.
luck is required stock on this car for it to work.
"My car won't start!"
"Well, maybe there's a killer after you."-Mitch Hedberg
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming.
- Mitch Hedberg
labikesrcool is offline   Reply With Quote
 Old 06-10-2009, 11:43 AM   #63
ATE BALLER's Avatar
^^ lol, tru dat!
 Old 06-10-2009, 08:44 PM   #64
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
nicely done man, good luck, i will be hoping for your success!
 Old 06-11-2009, 11:26 AM   #65
ATE BALLER's Avatar
Thanks guys!
I'm finding that the Standard version of ECUedit will let me download the stock configuration and edit it, but that I will need the Pro version to flash it back. I wonder if fireboy would be willing to let me borrow his flash software for a day or two to load up my map when I make it, lol. Or maybe by actually purchasing the standard version of ECUedit, they'll be more prompted to get the Pro version completed since they now have at least one customer. I think I'm going to have the welder lay a 1/8" bead around the inside of the 3" housing where the sensor sits, then when the Pro version is ready, I can just grind that out with my dremel tool and flash away. That way I could at least test blow-thru with higher boost right now.
BTW, I just got my honeycomb peice today. It's 7"x7", so I should be able to get four 3" round peices out of it. It is 3/4" thick with 3/16" cells. If it works, I'll probably sell the other three peices. Just a heads up. If the shop is opened saturday, I'll try to get up there then.
 Old 06-11-2009, 12:16 PM   #66
Captain
wtf? so i guess ECU EDIT isn't just a clever name, and all it does is edit...
Hmmmmm. Seems stupid to me if you can't get the code back in.
I'm not sure that 1/8" bead would be ideal. Seems more turbulent than anything. Maybe they could tack weld a sleeve into the housing to bring it down to 2 3/4". And then you could just grind off the tacks later on.
Or, i wonder just how far "off" it would be with a 3" pipe. I know 3 1/4 & 3 1/2 are quite a bit different, but i wonder if your LTFT's could compensate for 3" as it is. Just an idea.
www.permtuning.com
 Old 06-11-2009, 10:55 PM   #67
ATE BALLER's Avatar
The pro version can do anything, but the standard (which is the only version curently available for mazdaspeeds) can only download and change. People with evos and stis that have the standard can flash with ECUflash, another program. I'm going to try to get them to do something for us if epifan acts like he's going to take forever.
Slight progress...
The Following 6 Users Say Thank You to ATE BALLER For This Useful Post:
bioevolve (06-12-2009), dougefresh_ (05-11-2010), jayspeed3 (06-12-2009), labikesrcool (06-14-2009), SpeedSixxx (01-29-2010), xcoldricex (06-12-2009)
 Old 06-12-2009, 09:09 AM   #68
ALL-IN.
AndyMS3's Avatar
Posts: 671   (View Stats)
AndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the world
Groans: 30
Looks good man. Are you going to epoxy the honeycomb in?
AndyMS3 is offline   Reply With Quote
 Old 06-12-2009, 11:18 AM   #69
ATE BALLER's Avatar
Nope. I'm gonna have the welder put 2-3 tacks around it. The screen and the pipes are all aluminum.
 Old 06-12-2009, 11:34 AM   #70
ALL-IN.
AndyMS3's Avatar
Groans: 30
ORLY? Fk. Weld>Epoxy, the honeycomb looked like plastic in the photo.
Can't wait to see your finished results.
 Old 06-12-2009, 01:47 PM   #71
blaggah's Avatar
Looks really good. I may need to get one of those honeycomb pieces from you. Is there going to be any issues with the straightener being so close to the MAF sensor? Don't other intakes position the straightener further away?
 Old 06-12-2009, 02:22 PM   #72
ATE BALLER's Avatar
I'm not sure yet. It's not in there permanently yet, so I might decide to put it just inside the other pipe, moving it ~2" further away.
 Old 06-14-2009, 10:38 PM   #73
blaggah's Avatar
Since the MAF is located after the turbo, wouldn't this help with the cold weather cut?
 Old 06-15-2009, 05:54 AM   #74
ATE BALLER's Avatar
I don't get alot of fc as it is, but I would think it could.
 Old 07-01-2009, 11:42 PM   #75
Driverman5777's Avatar
Posts: 685   (View Stats)
Driverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the world
Groans: 76
interested in an update
Driverman5777 is offline   Reply With Quote
 Old 07-02-2009, 11:09 AM   #76
ATE BALLER's Avatar
Got the random misfire code for not being tuned for the 3" housing, so I put the stocker back on until fireboy gets me a trial version of his software. Just waiting in limbo, again.
jayspeed3 (07-02-2009)
 Old 08-16-2009, 11:36 AM   #77
KayWhy's Avatar
Posts: 752   (View Stats)
KayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the world
Groaned at 9 Times in 5 Posts
Hey its been over a month, any updates?
KayWhy is offline   Reply With Quote
 Old 08-18-2009, 10:45 AM   #78
ATE BALLER's Avatar
Still waiting on tuning.
 Old 08-18-2009, 10:50 AM   #79
stealthspeed6's Avatar
Posts: 136   (View Stats)
stealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant future
get yourself an AP, i see lots for sale.
stealthspeed6 is offline   Reply With Quote
The Following User Says Thank You to stealthspeed6 For This Useful Post:
 Old 08-18-2009, 11:10 AM   #80
ATE BALLER's Avatar
No monies.
Bought house --> $8000 (closing costs)
fixed up house --> $7000
finally moved in --> $200 (and growing)
getting married --> $12000
going on honeymoon --> $3000
Getting out of parents basement (again) --> priceless
Maybe by fall I'll be able to mod again, lol.
2008 25 Hours of Thunderhill: Overall leader has fallen, repairs underway Haltech Automotive News 0 12-07-2008 07:10 AM
GM not sending any bailout money to Brazilian operation Haltech Automotive News 0 11-22-2008 07:10 PM
Tokachi 24-hour Nissan GT-R build up underway Haltech Automotive News 0 07-01-2008 06:00 PM
Ferrari California assembly underway at Maranello Haltech Automotive News 0 06-29-2008 12:30 PM
2008 24 Hours of Le Mans is underway Haltech Automotive News 0 06-14-2008 08:41 AM
Page generated in 0.56242 seconds with 36 queries
