![]() | | #121 | ![]() |
![]() Join Date: Sep 2009 Location: CREVE COUER, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 263
Groans: 75
| Not Ranked : 0 score |
![]() | | #122 | ![]() |
Groans: 60
| Not Ranked : 0 score You get essentially the same effect as going to a larger MAF housing(with the same tuning required to compensate for the different airflow readings), and you can safely VTA your blow off valve..
![]() | | #123 | ![]() |
Groans: 75
| Not Ranked : 0 score Oh Ic what are the other options...where can I find a larger maf? |
![]() | | #124 | ![]() |
| Banned ![]() Join Date: Jun 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 283
Groans: 213
Groaned at 274 Times in 187 Posts
| Not Ranked : 0 score cpe has a 3inch maf |
![]() | | #125 | ![]() |
Groans: 75
| Not Ranked : 0 score couldnt find it on their website... |
![]() | | #126 | ![]() |
Groans: 213
| Not Ranked : 0 score i think u have to ask bout it |
![]() | | #127 | ![]() |
![]() Join Date: Mar 2008 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,984
(Thread Starter) | Not Ranked : 0 score You have to call them and ask for it specifically. Or you can peice one together using an ebay maf housing for a subaru, a filter, some clamps, and a coupler for about half the $$$. I think the housing itself is like $90, then the filter, coupler, and clamps are cheap. |
![]() | | #128 | ![]() |
Groans: 75
| Not Ranked : 0 score OHH yah im going to do that... the have a 3.25" can i use this with the AP and just recalibrate the MAF?? |
![]() | | #129 | ![]() |
Groans: 213
| Not Ranked : 0 score dont know, maybe.. u should be able to, the ap has that table right? |
![]() | | #130 | ![]() |
| Not Ranked : 0 score yes u can recal with the AP
| The Following User Says Thank You to superskaterxes For This Useful Post: | dougefresh_ (05-11-2010) |
![]() | | #131 | ![]() |
![]() Join Date: Apr 2009 Location: Bethpage, New York
Rep Power: 4481 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,850
Groans: 778
| Not Ranked : 0 score ate, tell me please.. ur throwing ptp mani and what turbo on your stock block? and more importantly how many miles u have on the car?
__________________ 2003 SilverStone Grey Honduh S2000 ![]() ![]() |
![]() | | #132 | ![]() |
(Thread Starter) | Not Ranked : 0 score Darksun's old T60-1 ~61,000 For now anyway. |
| The Following User Says Thank You to ATE BALLER For This Useful Post: | SpeedSixxx (01-29-2010) |
![]() | | #133 | ![]() |
Groans: 778
| Not Ranked : 0 score well ty very much! 55,000 miles and a GT35R with Medievil mani. good luck to you and good luck to me!
| The Following User Says Thank You to SpeedSixxx For This Useful Post: | ATE BALLER (01-29-2010) |
![]() | | #134 | ![]() |
![]() Join Date: Feb 2009 Location: Atlanta Ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,123
| Not Ranked : 0 score wire crimpers ftw lol i know its ghetto but is it really worth the paper other wise? |
![]() | | #135 | ![]() |
Groans: 778
| Not Ranked : 0 score super excited!!! throwing my shit on car so0o0on
![]() | | #136 | ![]() |
| Miembro ![]() Join Date: Jun 2008 Location: Puerto Rico
Rep Power: 420 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,095
Groans: 27
| Not Ranked : 0 score any updates on this?
__________________ 2008.5 MS3 Metro Gray...slow |
![]() | | #137 | ![]() |
(Thread Starter) | Not Ranked : 0 score Had to replace my alternator, so I took the oportunity to replace my turbo and manifold at the same time. Blow-thru runs awesome with a tune though. Smooth as an ice-sculpted titty. |
| The Following User Says Thank You to ATE BALLER For This Useful Post: | xcoldricex (03-29-2010) |
![]() | | #138 | ![]() |
| Fux Wit It ![]() ![]() Join Date: Mar 2008 Location: Li
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,795
Groans: 175
| Not Ranked : 0 score good job Im gonna move the maf to my cold pipe on my nissan.
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous |
![]() | | #139 | ![]() |
(Thread Starter) | Not Ranked : 0 score You won't regret it. Slapping a filter right on the turbo w/o any piping is going to be a big improvement imo. Yeah, it's hotter air, but the spool-up should take no time at all. My ic can deffinately handle the higher temps as well. I think it's probly still the best one on any of these motors. My only flow restrictions left are the IM, TB, and the head. I'll have to get my fuel system finished before I touch either of those though. Then I can really see if the stock block can handle ~400hp. |
| The Following User Says Thank You to ATE BALLER For This Useful Post: | SpeedSixxx (03-29-2010) |
![]() | | #140 | ![]() |
Groans: 175
| Not Ranked : 0 score your playing with fire boy lol. Well if you blow before the 16th i wanna buy back my turbo lol.
| The Following User Says Thank You to Darksun280 For This Useful Post: | SpeedSixxx (03-29-2010) |
![]() | | #141 | ![]() |
(Thread Starter) | Not Ranked : 0 score lol, if I blow, I'll be building a motor and going with a retarded turbo anyway, so ok. |
![]() | | #142 | ![]() |
Groans: 778
| Not Ranked : 0 score 400 AWHP on stock block... lets see who does this first.
![]() | | #143 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score Any updates on this? Will you make a "How To" on this topic? |
![]() | | #144 | ![]() |
Groans: 75
| Not Ranked : 0 score ATE, your car running yet? If so you should com to the boeing meet this sunday. Last edited by Fagwagon; 05-11-2010 at 08:55 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #145 | ![]() |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
| Not Ranked : 0 score Nice work on relocating the MAF. I saw you don't have an AP, which is too bad. Do you log with a DH then? I look forward to seeing some WOT logs, and how well your ECU hits your target WOT afrs. Good luck with finishing it up. I was thinking it may be a problem with the AP if the output voltages were higher. That is, if the aftermarket MAF went from 0-6 or 7 volts instead of 0-5. That might screw you. If it went from 0-4 volts, you could just scale it. I think they're the same though, right? Do all MAFs go from 0-5v?
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] Last edited by dougefresh_; 05-11-2010 at 10:44 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #146 | ![]() |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
![]() | | #147 | ![]() |
| Not Ranked : 0 score I thought he was using a Subbie one or something that is the similar to our stocker? Is it identical to our stock MAF with longer wires, or did he cut it open, and just extend them? I don't see the stock one reaching over that far, but then again I never tried. Do you know if all MAF's run voltages from 0-5?
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] |
![]() | | #148 | ![]() |
Groans: 60
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
| The Following User Says Thank You to SSinstaller For This Useful Post: | dougefresh_ (05-11-2010) |
![]() | | #149 | ![]() |
| Not Ranked : 0 score Thanks man, I had no clue... first car I've ever tuned. Good to know.
![]() | | #150 | ![]() |
Groans: 45
| Not Ranked : 0 score the stock one can reach quite far actually, just have to unclip some things, no cutting wires necessary. he is using a subie maf housing. |
| The Following User Says Thank You to bova For This Useful Post: | dougefresh_ (05-11-2010) |
| 2008 25 Hours of Thunderhill: Overall leader has fallen, repairs underway | Haltech | Automotive News | 0 | 12-07-2008 07:10 AM |
| GM not sending any bailout money to Brazilian operation | Haltech | Automotive News | 0 | 11-22-2008 07:10 PM |
| Tokachi 24-hour Nissan GT-R build up underway | Haltech | Automotive News | 0 | 07-01-2008 06:00 PM |
| Ferrari California assembly underway at Maranello | Haltech | Automotive News | 0 | 06-29-2008 12:30 PM |
| 2008 24 Hours of Le Mans is underway | Haltech | Automotive News | 0 | 06-14-2008 08:41 AM |
