 Old 03-09-2015, 08:01 AM   #1
Turbojocky13's Avatar
Posts: 96   (View Stats)
Turbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant future
Groaned at 32 Times in 13 Posts
Default Over boosting and hard cut out
Ok so I finished putting my motor back together and now there is a massive engine cut out when I give it any kind of hard gas (above half throttle) I can go into boost but I noticed with the accessport it's hitting 22.93 when it cuts. And it cuts hard. So it's deffinitly over boosting some how. Here is my mod list.
Forged eagle rods
Wiseco pistons
CDFP
TIH
CAI
TBE
Accessport stage 2
Stiffy Torque Damper
FTG ko422-582 upgradedTurbo
Balance shaft delete
Any help would be appreciated
Turbojocky13 is offline   Reply With Quote
 Old 03-09-2015, 08:11 AM   #2
Scare Dem's Avatar
Posts: 1,505   (View Stats)
Were you logging when this happened?
Post some logs.
2008 Mazdaspeed3 GT
GTX2867r
Vansquish (03-09-2015)
 Old 03-09-2015, 08:13 AM   #3
btstarcher's Avatar
Posts: 4,852   (View Stats)
So, you have a turbo from a CX7? And upgraded it? I'd post a log, see what WGDC is doing. Also see if the WG actuator is moving.
SnailTune in progress
 Old 03-09-2015, 08:21 AM   #4
Yea I will post some logs, but it was doing the exact same thing when it blew up about a month ago with 140,000 miles on it. It surged really hard and bent a rod, really don't want to do that again. I'll check the waste gate again, but yea I agree I kind messed up on the turbo when I bought it, it's a bigger inducer/exducers but the exhaust side is a tad smaller. Didn't do my research hard enough (like an idiot) and accidentally bought a 582 and not an 881 . Maybe waste gate solinoid?
The Following 2 Users Say Thank You to Turbojocky13 For This Useful Post:
btstarcher (03-09-2015), Vansquish (03-09-2015)
 Old 03-09-2015, 08:40 AM   #5
btstarcher's Avatar
Make sure the EBCS is connected properly. If it is, and you're still spiking, it wouldn't hurt to get another one and try it out, just to be safe.
 Old 03-09-2015, 09:05 AM   #6
Police - Grammarhead
Vansquish's Avatar
Post some logs. It's all rather hard to diagnose without quantifiable data to look at.
 Old 03-09-2015, 09:10 AM   #7
ANITIX87's Avatar
Posts: 1,394   (View Stats)
ANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the world
Groans: 93
Groaned at 27 Times in 16 Posts
What tune are you running, what are your boost and load targets? We need more information.
TIS
TOTS
2012 Mazdaspeed3, CWP, Tech Package. COBB AccessPort V3, AUTOTECH HPFP Internals, JBR 3" Wide-path SRI+TIP, CP-E TMIC, UR 3" Test Pipe, CP-E Triton CBE, FORGE V2 BPV, DENSO ITV22 Plugs, JBR RMM 88a, JBR OCC, JBR RSB Kit, JBR Solid Shifter Bushings, CP-E Tow Plate, CorkSport ECU Relocation, TSW Nurburgring Bronze 18x7.5
alphasaur: "Fuck I just beat it to surprise tranny porn. Saw the dick right when I came fml"
ANITIX87 is offline   Reply With Quote
 Old 03-09-2015, 09:26 AM   #8
I'll post some logs at lunch, but I would really rather not hit the cut again. It's fairly violent, I'm on Cobb stage 2 tune and I know for a fact that the boost targets are not 22.93 psi lol
 Old 03-09-2015, 10:00 AM   #9
ANITIX87's Avatar
Groans: 93
Could be as simple as WGDC being high and the cold temps. Tuning in winter, especially boost-based, is tough.
Now that it's considerable warmer today, you may not hit the cut.
TIS
TOTS
 Old 03-09-2015, 09:39 AM   #10
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
Check wastegate/EBCS connections, check for damaged or cracked hoses.
Stock or aftermarket EBCS?
2018 Audi RS3
2007 Acura TSX 6MT
 Old 03-09-2015, 11:20 AM   #11
Stock
Lol I'm in Florida it's always hot
Last edited by Turbojocky13; 03-09-2015 at 11:20 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-09-2015, 10:32 AM   #12
btstarcher's Avatar
If boost was that high though, I'm leaning toward hardware failure.
Scare Dem (03-09-2015)
 Old 03-09-2015, 12:56 PM   #13
Scare Dem's Avatar
It's 80 degrees out right now here in FL. If you're spiking to 22+ then hardware as mentioned above.
Did you see the spike on your AP?
2008 Mazdaspeed3 GT
GTX2867r
 Old 03-09-2015, 01:12 PM   #14
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
Stock MAP sensor? Probably going higher than 22 and not being able to read it.
EBCS is probably cracked or hooked up wrong.
 Old 03-09-2015, 07:00 PM   #15
Found the issue, broken nipple on the solenoid. Can't believe I missed it, I looked at it like 10 times
The Following 4 Users Say Thank You to Turbojocky13 For This Useful Post:
btstarcher (03-09-2015), neganox (03-09-2015), Scare Dem (03-10-2015), TiGraySpeed6 (03-10-2015)
 Old 03-09-2015, 08:14 PM   #16
Feline Führer
neganox's Avatar
Good find. Easy fix.
 Old 03-09-2015, 08:24 PM   #17
Vansquish's Avatar
Also, if you're running an upgraded turbo, you probably can't (safely) run any OTS map.
 Old 03-09-2015, 11:17 PM   #18
True, thanks for the info!! ^ also just for some of the readers.... I guarantee this was broken and what caused my motor to blow up last month, thank god that this time I had forged internals. And for the love of God get a boost gauge so you can see this happening. If I would have had one my motor would not have blown. But I guess it's kinda a good thing because I'm built now mechanics life for me. #teamstaydirty
 Old 03-10-2015, 12:05 AM   #19
Jadcock's Avatar
Posts: 134   (View Stats)
Jadcock has much to be proud ofJadcock has much to be proud ofJadcock has much to be proud ofJadcock has much to be proud ofJadcock has much to be proud ofJadcock has much to be proud ofJadcock has much to be proud ofJadcock has much to be proud ofJadcock has much to be proud of
This is the shit that makes me want to get Stratifieds Guardian Angel asap. Check it out. You dial in a boost level and if it ever sees that level it allows the bpv to open and let go of the boost before anything booms.
Jadcock is offline   Reply With Quote
The Following User Says Thank You to Jadcock For This Useful Post:
Mike@Stratified (03-10-2015)
 Old 03-10-2015, 08:59 PM   #20
Posts: 2,826   (View Stats)
+1 on having a boost gauge all the time. Shit can happen when you are not monitoring.
Not boosting enough on stage 2 mroedan 2010 MS3 - ECU Computer Tuning 27 06-30-2014 08:51 AM
Over boosting? travis9935 MazdaSpeed 3/6 - Turbo Induction 55 01-02-2012 12:35 PM
Movie Review: The Goods: Live Hard, Sell Hard *Warning: Spoiler Alert* [w/POLL] Haltech Automotive News 0 08-18-2009 02:10 PM
only boosting 10 psi triple_threat MazdaSpeed 3 - Engine, Transmission & Driveline 11 08-11-2009 09:08 AM
Brake boosting? Sloane Mazdaspeed3/6 General Discussion 14 12-24-2008 01:13 PM
Page generated in 0.38872 seconds with 28 queries
