  • 1 Post By Agent_Orange
 Old 02-21-2015, 06:42 PM   #1
Caldazar's Avatar
Posts: 293   (View Stats)
Caldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond repute
Default over boosting heavily... :(
mods as in sig, plus Grimspeed 3 port solenoid and gutted second cat.
started hitting fuel cut, so drove nice for a while, finally got time to look at things. Boost is reading at 22.7 scary psi when heavy footed. Maps are set to 16.5 with some correction built into the tables. also fuel cut is set to 18.5?
lowered my WGDC to mid 30's(%). Was at around mid-high 40's. Same psi as before.
I am pretty sure I have the solenoid hooked up correctly as I haven't changed it and I was at 16-18 psi before, depending on gear, temp etc. I can hear the solenoid rattling away at lower rpm/throttle.
I have a boost tuning type map(box checked) based on boost tune maps with the load ramping sharply up. First thing I checked was that I didn't accidentally uncheck that, and the car is trying to hit 3.0-5.0 load...
please? and thank you.
06 Speed6, camber balljoints and alignment, HankookV12 Evos, Konigs, Corksport full intake system, PTP pump internals, Cobb Ap, Forge BPV. Daily driver
91 Talon TSi, 5spd AWD, GT3076R, fmic, 3" exhaust, Jackal EMS, methanol injection, JIC C/O and more. Looking at 10's
Caldazar is offline   Reply With Quote
 Old 02-21-2015, 07:46 PM   #2
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
you're pegging the sensor. Make sure your ebcs is hooked up correctly, if it's not you'll overboost like that. I pegged my 3 bar when I first installed the 3071 because of this.
Blue Pu.
Caldazar (02-23-2015)
 Old 02-21-2015, 09:49 PM   #3
Caldazar's Avatar
yea, I figured it might be. Thing is, it solenoid has been in it for a while now, and only lately is it overboosting like this. lines are all hooked up, solenoid is plugged in.
 Old 02-21-2015, 10:00 PM   #4
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
ASHMS3 likes this.
The Following 8 Users Say Thank You to Agent_Orange For This Useful Post:
ASHMS3 (02-22-2015), chaser27 (02-23-2015), Code Monkey (02-22-2015), CWP_MS3 (02-24-2015), MD1032 (02-25-2015), snailD (02-22-2015), taf0422 (02-22-2015), WetzMS3 (02-24-2015)
 Old 02-22-2015, 06:02 PM   #5
sheston's Avatar
Posts: 1,847   (View Stats)
You need to really fix this. My stock boost sensor read somewhere around 22-23 psi and when I got my 3 bar, it told me I was really boosting over 25 psi.
Need to check all your vacuum lines and wastegate linkage. Also, the tip from the intake breaks off a lot of times.....
 Old 02-22-2015, 09:04 PM   #6
Caldazar's Avatar
yea, Im going to dive into it tomorrow. I am going to try a much earlier revision map, one that I know was making less bost than I wanted. I have had a quick look at the vacuum lines off the Grimmspeed controller and it all seemed ok. I can hear it cycling at lower rpm anyway, so I know its at least moving. I will test to see if it is opening and closing, not just flopping back and forth. I will also try to find out if the wastegate is stuck or something.
I wonder if there is anything that the map that I have frigged up inadvertently? I have been adding authority to the wastegate dynamics, error compensation.
 Old 02-23-2015, 03:09 AM   #7
Groans: 665
I'm wiling to bet you entered a wrong value or multiplier somewhere.
Hence why you need to post logs and/or the map.
The Following 2 Users Say Thank You to Agent_Orange For This Useful Post:
ASHMS3 (02-23-2015), Caldazar (02-23-2015)
 Old 02-23-2015, 11:46 AM   #8
Caldazar's Avatar
I had to take one of the pets to the vet this morning and I flashed an old map, one of my first that I was using the Grimmspeed controller. I remember distinctly that this map was making too little, only around 13 psi as I was being conservative with the WGDC numbers. On the trip to the vets, I watched the boost numbers on the Cobb screen. Still hitting boost cut and showing 20 psi. Not full throttle and I let off as soon as I saw the big numbers. I don't think its in the map, unfortunately. I can post a map or two if anyone would like to go thru it? I'd appreciate the critique anyway. I am not a pro tuner by any means.
tried to add a map, not sure how to add a file? I can see how to add links or pics, but not files?
 Old 02-23-2015, 11:53 AM   #9
CFI2008's Avatar
Posts: 259   (View Stats)
CFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the world
I have no input on overboost cause but I would highly recommend a guardian angel from stratified so when things like this happen you won't blow your motor.....
CFI2008 is offline   Reply With Quote
The Following 2 Users Say Thank You to CFI2008 For This Useful Post:
Caldazar (02-23-2015), SpeedRebirth (02-24-2015)
 Old 02-23-2015, 12:06 PM   #10
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
Check all the vacuum lines from your boost source to your WGA. If one of them is cracked or something you won't be able to open your waste gate.
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
The Following 4 Users Say Thank You to chaser27 For This Useful Post:
Agent_Orange (02-23-2015), Caldazar (02-23-2015), Vansquish (02-23-2015), WetzMS3 (02-24-2015)
 Old 02-23-2015, 12:23 PM   #11
Police - Grammarhead
Vansquish's Avatar
^^ This.
To me, it sounds like the line from your boost reference to your wastegate actuator isn't hooked up properly, or is cracked. If it was, the diaphragm in the WGA wouldn't ever get pushed in the right direction to open the wastegate itself. You might also want to double-check that the wastegate arm isn't stuck itself.
Post some logs of the problem.
The Following 3 Users Say Thank You to Vansquish For This Useful Post:
Agent_Orange (02-23-2015), Caldazar (02-23-2015), chaser27 (02-24-2015)
 Old 02-23-2015, 01:24 PM   #12
Caldazar's Avatar
yep, going to check the wastegate for function, and all the lines a little more closely. Pretty sure its not hooked up incorrectly as it has been good for several months, and I haven't changed any routing. I will check for any cracks or loose fittings.
 Old 02-23-2015, 07:37 PM   #13
Caldazar's Avatar
ok, solved. closer inspection shows that the little wee cap on the bottom wastegate actuator nipple was cracked. leaking out all the boost that is supposed to open the wastegate. its was pretty rotten to be honest. Not been on there that long either.
put a new one on there and its now boosting 16.4psi and I have the map set for 16.5. Happy happy. time to turn up the boost a bit.
The Following 2 Users Say Thank You to Caldazar For This Useful Post:
chaser27 (02-24-2015), Vansquish (02-24-2015)
 Old 02-23-2015, 08:11 PM   #14
08cosmic3's Avatar
Posts: 2,920   (View Stats)
Get a proffesional tune before you blow your shit up. You'll have piece of mind and your car will haul ass.
 Old 02-24-2015, 06:34 AM   #15
shamie's Avatar
Posts: 952   (View Stats)
A professional tune wouldn't have helped this at all.
The Following 3 Users Say Thank You to shamie For This Useful Post:
Caldazar (02-24-2015), MD1032 (02-25-2015), Vansquish (02-24-2015)
 Old 02-24-2015, 06:39 AM   #16
MSP6's Avatar
Posts: 1,246   (View Stats)
Bah I wish I had seen this originally. I had a grimmspeed 3 port on my speed 6 and that cap rotted away on me as well in <6 months. I actually contacted them and they said they were going to look into it. This was in.....2012-2013? I guess they didn't replace the oens they were sending out. I grabbed a bag of little silicon caps from the local parts shop and it was fine after that.
 Old 02-24-2015, 07:18 AM   #17
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
On the WG nipple I would use a hose, clamp and bolt rather than those silicone caps; they fail all the time.
@MSP6; for the EBCS, unthread the nipple from the EBCS and find a plug to screw in there instead.
 Old 02-24-2015, 07:34 AM   #18
snailD's Avatar
Posts: 3,039   (View Stats)
agreed, happened to me several times when i was in the mbc world long ago
 Old 02-24-2015, 08:54 AM   #19
MSP6's Avatar
Well that was on my speed 6 which is unfortunately gone. Still on stock bcs for the speed 3 for now. Will do if/when I eventually replace it. thanks for the tip!
 Old 02-24-2015, 09:37 AM   #20
Well, if you eventually do, keep in mind that our EBCS comes with the required plug
 Old 02-24-2015, 10:28 AM   #21
MSP6's Avatar
Heh, will do. Pretty sure GS was the only one at the market back when I got it? I think...
Stratified EBCS on the list for when I do upgrade!
 Old 02-24-2015, 10:58 PM   #22
Caldazar's Avatar
thanx, yea the tune was clearly not at fault here.
I did use a piece of overly strong fuel line, capped off with a threaded bolt. its way stronger than the old one.
Heavily updated 2015 Toyota Camry to bow in New York Haltech Automotive News 0 03-27-2014 02:40 PM
Hesitation at WOT when heavily loaded tclegg 2010 MS3 - Troubleshoot/Diagnostics 2 12-27-2013 05:44 PM
heavily modded MS6 VD Mfinlay04 MazdaSpeed 3/6 - Dyno Sheets/Discussions 12 09-03-2013 06:05 AM
Report: Iran invests heavily in natural gas cars Haltech Automotive News 0 01-11-2013 08:00 AM
Page generated in 0.42728 seconds with 31 queries
