 Old 06-20-2016, 08:24 AM   #1
G3nwonMazdaratti's Avatar
Posts: 12   (View Stats)
G3nwonMazdaratti is an unknown quantity at this point
Default P0234 Overboost and low compression
Hey all. I'm from the Minnesota, north metro area. Back in November I purchased a full built and bolted speed3. Forged internals and all that good stuff. Parts list includes,
bnr s3,
Grimmspeed ebcs,
88mm Wiseco pistons,
k1 rods,
3.5" HTP intake,
3" catless dp cbe,
Autotech HPFP internals,
Cx-racing fmic,
Damond TB spacer,
jbr Im spacer,
Kozmic egr delete,
Go fast Bitz blows off valve recirculated,
occ set to vta under boost,
c-pe safe seals,
light weight fidanza flywheel, banjo bolt,
sure short shift plate, streetunit rmm,
ngk 6510 spark plugs,
3 bar map sensor,
IM flap runner delete,
jbr bsd oil baffle..
The car had roughly 33k miles on the reman build. It was freek tuned by Justin through the accessport on e33 making 400whp.
Just recently I did a compression test. And I have low compression in all cylinders, (roughly 140 across the board). The issue started when I hit over boost one time a month or so back. I have a slow turbo spoil and have already diagnosed that there is no shaft play on the turbo. I replaced the ebcs, my bov, all my intercooler couplings and clamps. Multiple boost leak tests on hot and cold side. So I have no idea what could be causing the low compression or spool delay. I have yet to try a new tune and plan to do that next.. Any suggestions or other routes I should take..? Thanks.
Andy
G3nwonMazdaratti is offline   Reply With Quote
P0234 Engine Overboost Condition after BNR S3 install MD1032 2010 MS3 - Troubleshoot/Diagnostics 24 12-18-2015 09:02 PM
AP Stage1+MSCAI2 91 v108 - CEL P0234 Engine Overboost Z3roFlaw MazdaSpeed 3/6 - ECU Computer Tuning 19 02-04-2015 03:01 PM
p0300 and p0234 after exhaust? cocoleveo7686 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 11-24-2014 01:28 PM
P0234 advice? Swinger13 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 10-21-2012 09:25 PM
P0234 Overboost nybe0010 2010 MS3 - Troubleshoot/Diagnostics 5 10-10-2012 09:00 AM
Page generated in 0.22499 seconds with 21 queries
