 Old 01-03-2010, 02:35 PM   #1
batman's Avatar
Posts: 10   (View Stats)
batman is a splendid one to beholdbatman is a splendid one to beholdbatman is a splendid one to beholdbatman is a splendid one to beholdbatman is a splendid one to beholdbatman is a splendid one to behold
Angry PCV PTP Fix for Turbo Burning Oil
I am a recent victim of an 07 MS3 burning oil in the turbo. This presented itself as occasional white exhaust both while idling and at high RPMs.
Mazda in their infinite wisdom replaced the Mobil 1 5w-30 I've put in since I've owned the car with 5w-40 synthetic and called it a day. Sure enough a week later the smoke returned while idling at a red light.
I'm furious with how Mazda has handled this but scouring the webs I keep hearing people refer to this cheap "PCV PTP" fix. I'm an avid do it yourself'er but I'm not familiar at all with what this fix is or how to go about doing it.
If anyone can provide info or tutorials on this fix, the parts involved, and how to get started, I would be infinitely appreciative.
Also I just came across this forum (I had previously been using mazda3forums.com). This seems like a very rich welcoming community and i apologize I've violated any rules with this post.
batman is offline   Reply With Quote
 Old 01-03-2010, 03:40 PM   #2
nytmar3's Avatar
Posts: 389   (View Stats)
nytmar3 has a reputation beyond reputenytmar3 has a reputation beyond reputenytmar3 has a reputation beyond reputenytmar3 has a reputation beyond reputenytmar3 has a reputation beyond reputenytmar3 has a reputation beyond reputenytmar3 has a reputation beyond reputenytmar3 has a reputation beyond reputenytmar3 has a reputation beyond reputenytmar3 has a reputation beyond reputenytmar3 has a reputation beyond repute
Neutral  :  -2 score
http://www.pt-performance.com/showPr...&cID=4&pID=260 order the pcv pill. It's like $30. Pull the tube that goes from your valve cover to your air intake, pop the pill in the metal tube on your valve cover, put the tube back, hope your smoking issue goes away.
Smoking Car FTL =(
nytmar3 is offline   Reply With Quote
 Old 02-28-2010, 07:22 PM   #3
uoftguy's Avatar
Posts: 63   (View Stats)
uoftguy has much to be proud ofuoftguy has much to be proud ofuoftguy has much to be proud ofuoftguy has much to be proud ofuoftguy has much to be proud ofuoftguy has much to be proud ofuoftguy has much to be proud ofuoftguy has much to be proud ofuoftguy has much to be proud of
Originally Posted by nytmar3 View Post
PT-Performance.com order the pcv pill. It's like $30. Pull the tube that goes from your valve cover to your air intake, pop the pill in the metal tube on your valve cover, put the tube back, hope your smoking issue goes away.
Not to sound like a complete idiot...but how does this hose detach? I don't wanna break anything cuz mazda will no doubt charge me a fortune for a plastic elbow. The plastic elbow fitting that attaches to the valve cover nipple has two green tabs. I'm guessing that you don't just pull it off right?
I ordered a "PCV fix" from PT-P today...just trying to figure things out before it comes. Do the instructions with the product explain how to remove this fitting?
uoftguy is offline   Reply With Quote
 Old 01-03-2010, 08:11 PM   #4
RGV_MS3's Avatar
Posts: 893   (View Stats)
RGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the world
Groaned at 12 Times in 5 Posts
I recently switched to 5-40 and it decreaded my smoking issue. still smoke but I would think it's condensation more than the oil, 45 deg temps outside. I'm gonna order the pt-p pill as soon as I get paid just to be on the safe side.
Originally Posted by alien_sporez View Post
Some say that when he exhales he makes a "PSHHH" sound... and that when women see him they immediately go into the kitchen and make him a sandwich... all we know is he's called FORZDA, the MSF Stig
2009 Rally Yellow Cobalt SS/TC
K&N Intake, Badmab Catless Downpipe, ZZP FMIC Kit, Forge BPV, Mpx Exhaust, Dual Aeroforce Gauges, R1 Concept Drilled and Slotted Rotors, E85 Tune
310 WHP 330 WTQ 93 Octane
347 WHP 386 WTQ E85
RGV_MS3 is offline   Reply With Quote
 Old 01-04-2010, 11:19 AM   #5
batman's Avatar
Does anyone have instructions or a tutorial online on how to install this thing? Also does it void your warranty?
 Old 01-04-2010, 01:55 PM   #6
nytmar3's Avatar
You can remove it before a dealer visit. AND I'm pretty sure I just told you three posts up how to install it......
Originally Posted by 240mazspd3 View Post
havent most people taken out their PCV pills b/c they arent effective or caused probs? and look into changing weight and brand of oil. i smoked with Mobile and amsoil 5w30 here and there. switched to PP full syn 10w30 and i havent smoked since. no OCC on my car either
OP, get a oil catch can and try PP 10w30. worked for me.
also, being that you have a 07 and if you havent had your turbo replaced, your turbo could be going bad
What does it matter that it's an 07? Also people are STILL ordering PCV fixes and having luck with them....I don't know why people would be removing them when they've helped so many people....
Smoking Car FTL =(
Last edited by nytmar3; 01-04-2010 at 01:56 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-04-2010, 04:51 PM   #7
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
everyone i know with a PCV pill, removed it b/c it was causing probs. secondly, it matters that he has a 07 b/c his turbo could be going bad and thats where the smoke could be coming from.
so he needs to make sure the dealer checks the turbo
2015 Mazda 6
 Old 01-04-2010, 05:06 PM   #8
nytmar3's Avatar
Is it not the same turbo on the 08's and 08.5s though?
The PCV didn't cure the smoking for me, but it deffinitely thinned it out. I got a bnoon bolt and my smoking went away. I didn't remove the PCV pill though because I figured it was part of what helped my smoking....I haven't had any issues with it.
Originally Posted by Monster J View Post
just out of curiosity, are you guys running cat-less? i know a guy who runs cat-less on his ms3 and having horrible smoking problem, then he installed a hi-flow cat and cure the smoking issue.
Cats just cover up the smoking....the problem is still there. There's no reason a car should smoke just because you free up the exhaust flow....
Smoking Car FTL =(
Last edited by nytmar3; 01-04-2010 at 05:07 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-04-2010, 05:15 PM   #9
IshiKage's Avatar
Groans: 278
no. 07's and 08's had the first version of turbos and i cant remember what year they change them. i think they may have started during the 08 models but the 07's def had the first versions that were going bad.
what weight and brand oil are you using? im still running stock DP but as said, i was getting smoke here and there with 5w30 mobil 1 and amsoil. switched to PP 10w30 and no more smoke
2015 Mazda 6
 Old 01-04-2010, 11:22 AM   #10
IshiKage's Avatar
Groans: 278
2015 Mazda 6
 Old 01-04-2010, 02:03 PM   #11
Spoolme's Avatar
Posts: 1,041   (View Stats)
Spoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the world
Groans: 54
Yeah I have it installed with an OCC and still smokes a little. Just switched to 5w40 Rotella and ordered the bnoon bolt.
Parting out!
http://www.mazdaspeedforum.org/forum/forum/f229/spoolme-parting-out-76016/
Spoolme is offline   Reply With Quote
 Old 01-04-2010, 02:04 PM   #12
Monster J's Avatar
Posts: 5   (View Stats)
Monster J is an unknown quantity at this point
Monster J is offline   Reply With Quote
 Old 01-04-2010, 02:46 PM   #13
felt's Avatar
Posts: 1,504   (View Stats)
felt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the world
Groans: 1,364
Groaned at 589 Times in 386 Posts
Trust me, he didn't cure anything with that high-flow cat.
felt is offline   Reply With Quote
The Following 3 Users Say Thank You to felt For This Useful Post:
jmustang68 (05-13-2010), nutsac76 (03-16-2010), nytmar3 (01-04-2010)
The Following User Says NO Thank You to felt For This Un-useful Post:
 Old 01-04-2010, 02:48 PM   #14
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
he probably didnt cure anything, rather, the cat is now buring the remaining oil in the cat instead of sending it out your exhaust pipe.
OP:
Take it back to the dealer and they will most likely replace your turbo-im assuming your still under warr. I would only get the ptp fix if your warr was up.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline   Reply With Quote
 Old 01-04-2010, 03:26 PM   #15
YammerR1's Avatar
Posts: 109   (View Stats)
YammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud of
I have a stock exhaust and can cure the smoking issue temporarily just by changing my oil with the same 5W30 I always use. My smoking would start about 2000 miles after every oil change, obviously due to the oil thinning out after a while allowing it to squeeze past the turbo seal and burning off in the exhaust.
If I drive the car like a granny it will not smoke. It only smokes after going WOT and letting it idle for a couple mins. I'm sceptical about the restricor pill curing smoking after WOT runs because the breather line connected to the intake tube is how the crankcase evacuates pressure when in boost as the PCV valve is closed. That's why you see oil film in the intake tube and intercooler, and why I'm considering a Dual OCC setup from Matt.
In my opinion the pill will be effective when the intake manifold is in vacuum, but will cause more pressure buildup in the crankcase while running in boost. The excess pressure in the crankcase is what is keeping the oil in the turbo from draining back to the sump at the proper rate, thus causing it to leak past the seal.
Common Mazda, where's the damn PCV system fix?
Edit: Is PTP still testing their PCV system relocate?
YammerR1 is offline   Reply With Quote
 Old 01-04-2010, 09:56 PM   #16
ATAZ's Avatar
Posts: 314   (View Stats)
ATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond repute
what type of problems were caused by the PTP fix?
ATAZ is offline   Reply With Quote
 Old 01-05-2010, 01:40 PM   #17
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
+1 on what problems you've seen?
I have been running the pill for a few thousand miles with no problems... Car still smokes unfortunately, but I haven't taken the pill out because I haven't had any other problems with it in...
The Following User Says NO Thank You to hnda etr For This Un-useful Post:
 Old 01-05-2010, 02:37 PM   #18
IshiKage's Avatar
Groans: 278
with the pill, car still smokes, people have seen more KR or people have gotten KR when they hadnt seen any before
2015 Mazda 6
 Old 01-05-2010, 02:53 PM   #19
nytmar3's Avatar
That's the car cleaning out carbon buildups, which has been discussed and it normal.
Smoking Car FTL =(
 Old 01-05-2010, 03:10 PM   #20
08speed's Avatar
Posts: 147   (View Stats)
08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of
ive only seen my 2008.5 smoking twice. once was before i put the pt pill in, the second time was about two months after putting my corksport intake on, i didnt put the pill back in though when i intalled the intake. i havent seen any smoke in the few months that i installed the pt pill.
08speed is offline   Reply With Quote
 Old 01-05-2010, 03:09 PM   #21
IshiKage's Avatar
Groans: 278
must not have been worth it being that the people i know, took the pill out and trashed it
2015 Mazda 6
 Old 01-05-2010, 07:51 PM   #22
flyrevs2's Avatar
Posts: 1,235   (View Stats)
flyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the world
PTP pvc pill works, no smoke and no KR since it's been installed.
Had a little KR at first, but this is normal until the crap gets sucked out, now no KR and happy motor.
If the PTP pill doesn't fix all the smoke get the bnoon bolt and you are golden.
There are some PTP haters who don't want to admit that PTP has fixed the problem for a lot of folks.
2013 Mazdaspeed3 Gen2
Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount
flyrevs2 is offline   Reply With Quote
 Old 02-28-2010, 07:33 PM   #23
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
gotta push in the green clips and pull off the hose.
The Following User Says Thank You to bova For This Useful Post:
uoftguy (02-28-2010)
 Old 02-28-2010, 07:37 PM   #24
uoftguy's Avatar
Thanks for the reply. I'll give it a try when the part comes.
I would of thought the opposite...as in, i would of first tried prying the green tabs outward away to clear the rim on the metal nipple but i guess thats wrong.
 Old 02-28-2010, 10:27 PM   #25
Ponypetro's Avatar
Posts: 59   (View Stats)
Ponypetro is a splendid one to beholdPonypetro is a splendid one to beholdPonypetro is a splendid one to beholdPonypetro is a splendid one to beholdPonypetro is a splendid one to beholdPonypetro is a splendid one to beholdPonypetro is a splendid one to behold
Groaned at 3 Times in 1 Post
what means "kr" my mates?
- 3" TURBOBACK - 3.25" ETS TMIC - 3" CP-E TURBO INLET & CAI - CP-E HPFP - GFB BPV - CP-E RMM - DENSO ITV22 - GRIMSPEED EBCS -
- MAZDAEDIT ECU REFLASH - JBR SHORT SHIFT KIT - PROSPORT BOOST GAUGE - MSD DASHHAWK -
Ponypetro is offline   Reply With Quote
 Old 03-01-2010, 12:11 AM   #26
hnda etr's Avatar
Groans: 90
Default Re: PCV PTP Fix for Turbo Burning Oil
Knock Retard
 Old 03-16-2010, 11:38 AM   #27
shpankey's Avatar
Posts: 496   (View Stats)
I had the pill installed for awhile. Back then I didn't actually have a smoking turbo. But this last week it started to smoke all of a sudden.
I took the pill out one day when I went to inspect it and realized the damn thing fell way back into the PCV line itself and had lodged itself sideways. I was NOT impressed.
09 Speed 3 GT
shpankey is offline   Reply With Quote
 Old 03-16-2010, 11:45 AM   #28
nutsac76's Avatar
Posts: 694   (View Stats)
nutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the world
Groans: 100
Groaned at 39 Times in 26 Posts
put an oil restrictor pill on your oil feed line and the smoke at idle will disappear. i guarantee it. the smoke at WOT is another thing. the only way to get rid of that is to trade your car in for an N/A whatever.
Whats wrong with a cloned turbo?
nutsac76 is offline   Reply With Quote
 Old 03-18-2010, 01:43 PM   #29
bnoon's Avatar
Posts: 1,770   (View Stats)
Nobody else makes oil feed restrictors for our banjo bolt style feed lines do they? That's why I still sell my restrictor banjo bolts... :phillyb:
My bolt is the only thing that works for me 100% as with only my PTP pill installed I get smoke on decel in gear and can still smell it at idle even though the visible smoke is reduced. I still run the PTP pill since it does increase crankcase vacuum, which is still a very good thing.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
 Old 04-27-2010, 06:16 PM   #30
Jessed87's Avatar
Posts: 149   (View Stats)
Jessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to behold
I have had a catch can, 5w-40 oil, the valve cover breather fix and the bnoon banjo bolt at the same time, and I still burn oil and smoke like hell at gas stations and stop lights lol. The only thing that seems to help at all was the bnoon banjo bolt, and only temporarily. Big turbo seems to be the only for sure fix.
Jessed87 is offline   Reply With Quote
 Old 03-16-2010, 06:39 PM   #31
Panda's Avatar
Posts: 41   (View Stats)
Panda is a splendid one to beholdPanda is a splendid one to beholdPanda is a splendid one to beholdPanda is a splendid one to beholdPanda is a splendid one to beholdPanda is a splendid one to beholdPanda is a splendid one to behold
Groaned at 8 Times in 4 Posts
Worked for me. Once i was on a steep hill and smoked for a second or two. But nowhere near as bad as with out it.
Panda is offline   Reply With Quote
 Old 03-16-2010, 08:33 PM   #32
uoftguy's Avatar
Do you have the very first version with fitment issues or the second revised version that is suppose to fit tighter? I just bought the second version (still on the way to me) so I hope the second one is ok.
What worked for you? PCV fix or oil restricter?
 Old 03-16-2010, 08:35 PM   #33
Panda's Avatar
sorry, resticter pill.
 Old 03-16-2010, 08:41 PM   #34
uoftguy's Avatar
ah cool, thanks. I don't have any issues but for $30 i figure, why not.
 Old 03-16-2010, 11:27 PM   #35
MattJackson86's Avatar
Posts: 1,407   (View Stats)
MattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the world
I just installed mine today (purchased last week). I presume mine is the 2nd revision which fits tighter, but wow was it tight. I had to actually file it down a bunch (kept it circular don't worry) and make it smaller as there was no way it would fit in my valve cover.
O yea, and it still smokes like no other. So either it didn't work or it takes a while.
GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP
Bitwise Motorsports http://www.bitwise-motorsports.com -
Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!)
MattJackson86 is offline   Reply With Quote
 Old 03-17-2010, 08:23 AM   #36
shpankey's Avatar
Supposedly it does take a bit. Something about burning off the excess that's already accumulated. So don't give up hope yet.
09 Speed 3 GT
 Old 03-18-2010, 02:17 PM   #37
shpankey's Avatar
bnoon, what does your bolt do exactly? I'm interested in buying one. Do you have a webpage that goes into detail about the bolt and how it works, and also sells it?
Thanks.
09 Speed 3 GT
 Old 03-19-2010, 09:15 AM   #38
bnoon's Avatar
Thanks.
My restrictor bolt is nothing special, it works just like every other oil feed restrictors on the market except that it's built for our banjo bolt oil feed line. The others are all NPT style threads or pill inserts that will not work with our oil feed system.
My bolts are sold through paypal. brad@bnmotorsports.com is the payment address. I have a post in the speed 3 "how to" section on this site with install pics and even how to make your own if you have the tools and knowledge to do so.
2002 BMW M3 - Sold!
 Old 03-19-2010, 11:32 AM   #39
hnda etr's Avatar
Groans: 90
hey brad, my bolt looks like it's got a hole on one side, and a partial hole on the other.... any problem with this?
 Old 04-26-2010, 03:15 PM   #40
fooqr's Avatar
Posts: 559   (View Stats)
fooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the world
Thanks, Brad. I think I'll give your bolt a try.
fooqr is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/pcv-ptp-fix-turbo-burning-oil-45679/
Restriktor wie von ptp - Seite 2 This thread Refback 04-03-2013 07:28 AM
Kurbelgehäuseentlüftung am L3 Turbomotor - Seite 3 This thread Refback 12-17-2012 02:08 AM
Kurbelgehuseentlftung am L3 Turbomotor - Seite 3 This thread Refback 06-11-2012 03:48 PM
Kurbelgehuseentlftung am L3 Turbomotor This thread Refback 01-31-2011 11:40 AM
Oil burning fix, we have one... ptperformance Mazdaspeed3/6 General Discussion 125 10-01-2009 06:21 AM
Potential oil burning fix ptperformance MazdaSpeed 3 - Engine, Transmission & Driveline 8 08-21-2009 04:07 PM
Burning oil STi Slayer MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 04-19-2009 10:13 PM
Help!!! Car losing/burning oil aaronc7 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 34 10-19-2008 08:35 AM
Page generated in 0.62006 seconds with 43 queries
