 Old 11-10-2013, 06:13 AM   #1
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Default PCV versus vacuum pump
Did anyone look into replacing the crappy PCV system with the other system with a vacuum pump?
The newer Skyactiv-G engines have it, they're also DISI and mazda decided it's time for their engines to run cleaner. Ford is using it as well with the newer EcoBoost engines.
So what does it take to replace the PCV with a vacuum pump based system (say, we're tired of using an OCC)? Because this + the EGR delete (or a system that would let them open in closed look ONLY when the engine is indeed cold) would save these engines from death by suffocation.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
ABolewski (11-10-2013)
 Old 11-10-2013, 09:09 AM   #2
btstarcher's Avatar
Posts: 4,852   (View Stats)
I'd be interested to hear some input from the smarter fellas on this topic as well.
SnailTune in progress
MS5 Versus....a Cop? Stealth01 Street Racing Stories ( Bench Racing ) 4 02-08-2012 12:50 PM
What's your IAT versus BT while cruising? MS3 Ventura MazdaSpeed 3/6 - Turbo Induction 21 08-02-2010 03:06 AM
Me Versus Just Brakes Stealth01 MazdaSpeed 3/6 - Suspension & Brakes 2 06-12-2010 08:11 PM
Ford Mustang Cobra electric PCV vacuum pump bnoon MazdaSpeed 3 - Engine, Transmission & Driveline 5 02-03-2010 06:32 AM
FRP Versus Fiberglass? marcusdigi MazdaSpeed 3/6 - Appearance 12 07-06-2009 10:23 AM
Page generated in 0.23023 seconds with 21 queries
