![]() Join Date: Nov 2008
(Thread Starter) | Not Ranked : 0 score Is it possible to install a PG Reworked Turbo without removing stock manifold? |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score i really don't think so, i dont know how you plan on getting the turbo past the manifold. although i could be wrong. |
![]() Join Date: May 2008 Location: Dallas, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 78
| Not Ranked : 0 score I dont have the exact answer either, but if it's not possible, you might as well go ahead and install an aftermarket Mani while you are installing reworked Turbo... Kill 2 birds..
__________________ [SIGPIC][/SIGPIC] CPE-SRI - HKS-SSQV - CPE-MM - TWM SB - Cobb AP Cobb FMIC - Cobb CBE - DP 18x8 +48 HP Design 235/40/18 BFG Riken, H&R Springs |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
Groans: 105
| Not Ranked : 0 score yes it is possible, i didn't remove my manifold installing a SST - take it out from the bottom (if you have all that stock DP shit out) |
![]() Join Date: Mar 2008 Location: Canada
| Not Ranked : 0 score OT, but how are you liking the SST?
__________________ 2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual. |
![]() Join Date: Sep 2008 Location: CT/NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,375
Groans: 35
| Not Ranked : 0 score |
![]() Join Date: Jan 2009 Location: Fort Worth, TX
Rep Power: 793 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 771
| Not Ranked : 0 score Yeah! Might as well slap an aftermarket mani on there. That's my plan.
__________________ Meet a giant fish. Fuck his brains out. |
![]() Join Date: Dec 2008 Location: atlanta, ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 206
Groaned at 37 Times in 27 Posts
| Not Ranked : 0 score 3
__________________ know your roll |
![]() Join Date: Jun 2008 Location: NW Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 361
| Not Ranked : 0 score Yes but you have to remove the DP instead.I would get a new DP since you will have it off already.It looked easier to remove the Dp then it did the mani but either way to do it I would suggest getting a upgraded mani or dp to save you alot of time in the future.
__________________ Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more http://videos.streetfire.net/profile/SharkDiver.htm http://www.youtube.com/user/sharkdiverjohn |
| Not Ranked : 0 score What AP map are you running with the reworked K04? Have you got a PTP, MPI, or PG K04?
| Not Ranked : 0 score I have the PG.I running stage 2 V103j 93 FMIC beta map.It runs pretty good with this map.I dont get much knock retard and my afrs are safe in the 11s.I do spike to about 21-23psi sometimes but it drops to about 18-20 and holds pretty good there.I was told I will be fine with the reworked turbo and running the default boost psi settings in the ots maps.I kinda wish I was running at about 18-19psi tho just to be safe.
| The Following User Says Thank You to SharkDiver For This Useful Post: | wassup61 (03-02-2009) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 145
| Not Ranked : 0 score PG K04 CAN be installed without pulling the manifold. However, would I do that? Not if i didn't have to, talk about a PITA. -Jeff at PG
__________________ All wagon, No traction |
| 103 maps with PG Reworked Turbo | subparpunk03 | Cobb Access Port/Maps | 11 | 11-13-2008 10:28 PM |
| PTP reworked turbo 330 and 342 tq | andre0121 | MazdaSpeed 3/6 - Turbo Induction | 63 | 10-15-2008 04:59 PM |
| K04 Reworked Turbo Owners, Please Chime In... | AutoXRacer | MazdaSpeed 3/6 - Turbo Induction | 73 | 09-04-2008 06:21 PM |
| reworked turbo - to be safe i should... | xcoldricex | MazdaSpeed 3/6 - ECU Computer Tuning | 3 | 08-23-2008 09:17 PM |
| Reworked turbo... | subparpunk03 | Mazdaspeed3/6 General Discussion | 3 | 07-17-2008 01:26 PM |
