![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 546
(Thread Starter) | Not Ranked : 0 score Inlet: Came boxed nicely, only thing missing was some vacuum line for the boost solenoid, but that wasnt a big deal since i just took some from work. I did wipe out the insides to remove any dust and dirt. PG even through in a set of mazda valve caps which was cool and unexpected. Product quality was great Fitment: Didnt fit 100% EXACTLY like the OE piece, but was good enough that it didnt run into any install issues with it not lining up with anything. Install tips: definitely install the coupler on the turbo first before you put the inlet on. Bolt the inlet onto the mount and slide it into the coupler and it will just fall into place. For removing the vacuum line for the solenoid: take your time. Dont yank or pull on the line. use a small flathead and work the hose off. I found it easiest to maximize your room was to remove it off the inlet first and than the solenoid. that way you dont have the hose in the way. Use the flathead on the bottom of the hose and break the "seal" so you can slowly push the hose off. By seal I mean that once the hose starts moving, it comes off pretty easy. Impressions: The turbo is definitely much louder. The spool is audible at even slight throttle, and it definitely spools up much faster. At speed it seems to recover boost much quicker as well. When the HKS valve is run in recirc it makes a notable flutter sound. With the PG inlet, that flutter turns into a hoot (but with a flutter). Its much louder than the stock inlet. The sound also deepens and sounds more hollow (as a result of the metal pipe) For the price its a bargain. Great fitment, easy install, and great results.
__________________ 2008 Cosmic Blue Mazdaspeed3 1986 Mazda RX7 2002.5 Sunlightsilver Protege5 (sold 12/26/09) Hey you should read this: http://www.mazdaspeedforum.org/forum/foru...ler-you-58361/ |
| The Following User Says Thank You to NCZ13 For This Useful Post: | Hectik1 (06-03-2010) |
| Banned ![]() Join Date: Apr 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score Thanks for the review im glad to see you enjoy your product all the way around! Keep us posted! |
![]() Join Date: Dec 2009 Location: Fontucky, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
Groans: 1,364
Groaned at 589 Times in 386 Posts
| Not Ranked : 0 score Nice stuff man, I have the CP-E Inlet |
![]() Join Date: Mar 2010 Location: fort stewart ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 119
| Not Ranked : 0 score i got pg inlet i like it but i wanted cobb it just looks better!!!
__________________ [SIGPIC][/SIGPIC]07 MS3 GT Cpe cai, Corksport turbo back, Hks bov, Trz dog bone, Cobb ap, Cobb knob, Stage 2 JB ssp ![]() |
| Banned ![]() Join Date: Mar 2010 Location: Chicago, Lombard
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
Groaned at 19 Times in 12 Posts
| Not Ranked : 0 score I have it with the hks and i love the way is sounds. install was good too. great for the price |
![]() Join Date: Aug 2009 Location: Trevose, PA
Rep Power: 7488 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,940
Groans: 224
| Not Ranked : 0 score This is def an excellent product for a great price, I'm very happy with mine. Nice write up on your review too.
__________________ MS3 has been retired to daily duty Project 1G; 1991 Eagle Talon TSi. 63MM Borg Warner Powered, Corn-Fed, 2.4L Long Rod Monster Under Construction Stock Turbo-Stock Engine Grand Champion of the World! 501WHP & 569WTQ (PERM Tuned, 93 OCTANE PUMP GAS K04 W/N2O!!) NATOR PA |
![]() Join Date: Jan 2009 Location: New Brunswick, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,314
Groaned at 43 Times in 28 Posts
| Not Ranked : 0 score i just recently bought the pg inlet at protegegarage and i was very very satisfied with the service..I've bought a few things from them last year and the service was pretty bad...there was a lot of miscommunication but this time around, the service was very fast. I received a confirmation the very next day, and a tracking number...it took about 3 days to receive it..The website has changed for the better also and it's so easy to order. Im going to be ordering a few things from them soon... I am also very satisfied with their inlet...it's nice and solid and i had no fitment issues with it...keep up the good job Protege Garage!
__________________ 06 MS6, Cobb AP, -TUNED on corn mix, KMD v2 fp internals, NGK Iridium IX sp, Cp-e Xcel NANO, PG tip, SU bpv, AWR rear MM, Jbarone shifter plate and bushings, ATP catted dp, Corksport catback, Altered Custom fmic, H&R springs...R.I.P. 08.5 MS3, Cobb Ap, KMD v2 fp internals, Denso ITV22 sp, Cobb Sri, TurboXS bpv, SU rear mm, SU shifter bushings, ETS TMIC, SU boost tubes, Cp-e catted dp, Enkei EKM3. |
![]() Join Date: Jun 2009 Location: Seattle Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
| Not Ranked : 0 score if i have CAI and I get the inlet, will this require a Tune? or an Access Port? What engine/ exhaust mod's can I get by without a tune or an AP? I really don't know too much about internals and can;t afford to mess anything up. Tho I do intend to autocross soon! CAI + Turbo inlet + Exhaust (sound only) ... down pipe???
__________________ -Low Beam/ Fog HIDS - Lamin-X Yellow Tint on Fog Lights - TSW Mallory Wheels - Thule Bike Rack with 598 Criterium Bike Mount - GX-65 with Blendmount - Corksport RMM - Corksport Mudflaps - Corksport SRI - Corksport Rear Sway Bar - GX-65 radar laser detector - TRS Angel Eyes - Rear bumper LED Light - H&R Springs - Koni Yellow Struts - JBR Camber Arms - AP v2 -Autotech internals - Tork Motorsports Tuned - Halos - Strips - D2 Xenon Lights - SST brake lines - Stoptech Sport brake and rotors w/ sst Brake lines [/I][/SIZE][/FONT] |
| Not Ranked : 0 score that's was my set up before i got a tune.yes it will be OK but i started to hit fuel cut winding out 4th and 5th gear . that's why i got a tune. but with those mods you should be OK. |
Groans: 224
__________________ MS3 has been retired to daily duty Project 1G; 1991 Eagle Talon TSi. 63MM Borg Warner Powered, Corn-Fed, 2.4L Long Rod Monster Under Construction Stock Turbo-Stock Engine Grand Champion of the World! 501WHP & 569WTQ (PERM Tuned, 93 OCTANE PUMP GAS K04 W/N2O!!) NATOR PA | |
![]() Join Date: Jun 2009 Location: toledo, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 243
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score ive had this sitting around for a while in the box and have not gotten around to install. how long does it take. it is great seeing a guy from pg on here because when i ordered the inlet the service was TERRIBLE and thats an understatment. no communication AT ALL. on here, phone, email, anything. but good to see some posts from a pg rep new. product seems great though. |
Groans: 224
| Not Ranked : 0 score Easy to install. Pull out your battery box, take off your intake, remove the old inlet and reverse the order for install. Just put the coupler onto the turbo with the clamps then put on the inlet it'll make your life alot simpler.
![]() Join Date: Oct 2009 Location: Gilberts, IL
Rep Power: 0 ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score Installed mine yesterday. Install was pretty easy but as most in a small engine compartments its a pain to move around. I have a CPE xcel and the sound seems to be different, don't know if it's louder but has a different tone. I like it so far...maybe still some break in time |
you can do UP TO, fmic, inlet, intake, bov, and exhaust, when you get passed this route fuel cut is an issue, if your not looking for huge power the list i just gave you will give you plenty to have fun with....not on the street of course ![]()
awesome to hear, sorry for the bad taste in your mouth, i like to make my customers happy so let me know in the future what i can do to get you taken care of better.
that would be your turbo spooling up over your intake, its very normal, and sounds uber good | |||
![]() Join Date: Dec 2008 Location: VA Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 930
| Not Ranked : 0 score I installed my inlet yesterday, but I think I got a defective one. I could not get the bracket lined up at all. I had to remove a bracket that was on the top of the tranny for it to fit, or else it would not get into place. Mine did not come with a vacuum line either. It took some persuasion to get line up with my CAI. On the other hand... Driveability was nice. Love the sound. |
believe it or not i ALWAYS have some trouble installing these on speed 6's, on the speed 3's they never give me issues but you 6'ers love to give me trouble, its not defective, and im kinda confused on the bracket from tranny, pic? | |
| Not Ranked : 0 score Ok, thanks. I will try to get a pic. |
![]() Join Date: Jun 2010
| Not Ranked : 0 score Hi I've heard some great things about the PG turbo inlet pipe, great performance for a great price, I was wondering if anyone is using these on the gen 2 Mazdaspeed 3 and how it is on them fitment and performance wise. I got a K&N Typhoon intake to go on too, will the PG TIP fit nicely with the K&N intake? thanks. |
it should fit perfectly fine! | |
![]() Join Date: Sep 2009 Location: Austin, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 289
Groans: 40
| Not Ranked : 0 score On the install on the 6 you have to play with it before it goes in, Yeah it will give you hell but it will fit |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1904 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp | |
| The Following 2 Users Say Thank You to driver311 For This Useful Post: | JoshProtegeGarage (07-16-2010), madvillain (07-16-2010) |
thanks for the compliments! | |
| Not Ranked : 0 score Great review |
![]() | | #24 | ![]() |
![]() Join Date: May 2011
Rep Power: 0 ![]() ![]() ![]() Thanks: 17
| Not Ranked : 0 score sorry to bring up an old thread but anyone know where I can get an alloy turbo inlet? I prefer it over the silicon as I like the sound it gives. Thanks. |
![]() | | #25 | ![]() |
Groans: 136
__________________ |
| The Following User Says Thank You to silvapain For This Useful Post: | matto (06-14-2011) |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score I totally forgot I made this thread. More than 1 year later this inlet has held up just fine.
| The Following User Says Thank You to NCZ13 For This Useful Post: | MS3-a(sore)ASS-rex (06-14-2011) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score | |
![]() | | #28 | ![]() |
| Not Ranked : 0 score I know they come for sale used here a lot. Donate $10 for VIP access. It is pretty easy to ship international. |
![]() | | #29 | ![]() |
Groans: 136
| Not Ranked : 0 score If I could find a Cp-e or Cobb one used for a decent price, I'd sell you my CorkSport one.
![]() | | #30 | ![]() |
Groans: 224
| Not Ranked : 0 score I actually pulled mine off just last week. It held up just fine for over a year and a half. Only thing I want to warn about is that since it's metal it's gets pretty hot after a while.y Cobb SRI was actually melted to it where the two pieces met
![]() | | #31 | ![]() |
| Not Ranked : 0 score I have had mine for right at 2 years. Still working great. Does PG even still make them?
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
| PTP's Turbo Manifold Impressions | Alpha | Mazdaspeed3/6 General Discussion | 52 | 07-02-2010 04:31 PM |
| PTP Kicker Mount review and impressions | bnoon | MazdaSpeed 3 - Engine, Transmission & Driveline | 18 | 05-15-2010 12:15 PM |
| CPe Nano review and impressions... | Smokehouse | MazdaSpeed 3 - Engine, Transmission & Driveline | 26 | 03-06-2010 11:40 AM |
| TRZ Transmission Mount/ Mazda3online turbo inlet installed and review! | Raider | Mazdaspeed Forums User Reviews | 0 | 06-29-2009 06:40 AM |
