(Thread Starter) | Not Ranked : 0 score All told, I have about $50 in this project, and have an excellent 3 port EBCS. This can also be run in 2 port mode as a direct replacement for the stock controller It's been widely argued that both the Cobb and the GrimnSpeed controllers are just a relabeled MAC solenoid. Spending just a few minutes in Google provides a MAC part number and many many refernces to effective solutions and names or sources like Denso, Grainger and Ingersol Rand & GM appear often. Below I've outlined the parts I used, some of the reference materials I drew from, and some random thoughts to help put the pieces together should you choose to go this route. There are other solenoids out there that perform the same function, some perhaps better than this design. This is just the route I took, feel free to explore alternatives! Please note- while this is less expensive in terms of dollars spent, it is more expensive in terms of time and effort. One of the best things you get when you spend full price for a Cobb/GrimmSpeed/Perrin is the support and engineering that they put into their product. Nice touched like being able to plug into the connector rather than hard wiring. Sure this post will cost less money, but trust me, you will pay for it in other ways, some people more perhaps than others. If you aren't comfortable planning this kind of a project out, and handling the extra steps involved, then save yourself the torture and just get the retail part! This is at your own risk! And, as always, with a 3 Port, you must make corrections to your tune! If you're not scared off yet, then let's get to it! Reading Material- Stratified EBCS Connections Cobb EBCS Grimspeed EBCS Parts- MAC solenoid Model# 35A-AAA-DDBA-1BA --> Cost can range from ~$17 directly from a MAC distributor to ~$30-35 from ebay & various others Vac Line fittings (various depending on install) --> Fancy 90* nickle plated like Cobb uses: ------> Pneumadyne Inc. Part# ELB30-1/8-5 If you compare specs, these things have a great flow rating, much better than the basic brass fittings from your local hardware store. They can be purchased individually from a variety of sources by searching the part number, here's one- $5.44 each - Male 90 Elbow by PNEUMADYNE INC - Brass Pipe Fittings by Zoro Tools Industrial Supplies They can be had for much less, but in bulk only, from Pneumadyne directly $44.25 for pack of 25 ($1.77 ea) 1/8 NPT Thread to Barb Elbow Fittings - Pneumadyne, Inc. You can upgrade to 1/4" fittings from the 1/8" fittingg for more airflow. This is the same fitting Cobb offers with their upgrade kit. Part number is ELB60-1/8 Individually, $5.44 each - Male 90 Elbow by PNEUMADYNE INC - Brass Pipe Fittings by Zoro Tools Industrial Supplies Feel free to source the basic brass 90* fittings from the local parts store, but you won't be nearly as cool.... Mounting Bracket- - You can mount this thing however you want, I happen to think the factory mount is a great spot. 1.5 inch of 1x1 aluminum angle, or anything similar stock lengths available from local hardware store, typically for under $5. I just used what was in my garage already. Since you only need a very short piece you could very likely have it as scrap already in your garage, or even a trash piece from the local machine shop. - - - When I switched to a BNR S3 the stock mounting location went away. There are many different ways to mount this thing, the location I used on the Speed6 was the stock TIP mount by the HPFP and battery. I've got a pic in a post further down, and it works perfect with the bracket described here. Nuts & bolts for mounting- 2 small diameter 1" screws, washers & lock nuts to mount solenoid to bracket 1 bolt, washer & lock nut to mount bracket to turbo housing replacing stock EBCS. Stainless is suggested but not required As with the mounting bracket, I just used what was in my garage already, but these can be sourced from the local hardware store for under $5 **You really want to use lock nuts for this application, or blue locktite. You don't want this getting loose... Connection- I was simply unable to source the correct plug to mate with the factory plug. I'm sure they're out there, but for a one-off it just wasn't worth the amount of time I was dedicating to the cause. I considered using Deutsch connectors, which are great, but in the end I just hardwired it. I encourage soldering and using heat shrink. Don't be a dweeb here, you want a seriously good connection. --> UPDATE ON THE CONNECTOR!! This can be a truly plug and play alternative! A most excellent find and, at only $8.00, downright cheap as well! Home » Shop » Connectors / Harnesses » Tyco / AMP » 2 - Way Receptacle Connector Pigtail OEM ECBS Pigtail (CONN-85730) Soldering this to the MAC EBCS wires will allow you to keep the stock plug on the factory wiring harness. No worries about polarity, just be sure they are well connected and use heat shrink- you want a good connection, and well protected! Also- I followed the install that Cobb endorses- I pulled the boost source from the IM line which feeds the BPV. Since I had already tapped that line once for my mechanical boost gauge I took this opportunity to clean things up and installed a vacuum distribution block. This allowed dedicated lines for everything and cleaned things up nicely. -->UPDATE #2- I have since moved the boost source closer to the turbo. Initially it was moved using an ATP Boost Tap to the silicone pipe off the turbo, and now that I've gone BNR S3 it's using the tap on the turbo itself. I moved it because having the boost gauge and the EBCS on the same circuit was making the gauge needle bounce at high boost levels. Just separating them corrected the issue. While I was at it, this was a good time to replace a bunch of the old vac lines. You might want to pick up several feet of new line, silicone is the nice stuff. Install prep work- - Drill the three holes on the mounting bracket, 2 small holes to mount solenoid to the bracket & 1 large hole for attaching the bracket to the turbo. - Mount the vac fittings to the solenoid. Be sure to use either teflon tape or sufficient quantity of blue locktite to seal things up properly. Be sure to end up with the 90* fittings pointing up. - Mount the solenoid on the bracket. - plan your vacuum hose routing in advance. Plan it again. Do you need/want a distribution block? Here we go! - Much of this process is outlined in the pdf files linked above - Remove battery, intake and TIH so you have plenty of room to work - Disconnect EGR connection for extra room ( I also elected to leave mine disconnected, it's blocked off anyway) - Disconnect OEM EBCS wiring connector - Remove hoses from OEM EBCS- I was replacing all these vac lines so I just cut them to make life easy. - Remove OEM EBCS from turbo mount and set aside. - Complete removal of vac lines from TIH and from lower port of wastegate to turbo. - Cap the lower wastegate & turbo fittings - Mount the new MAC EBCS to the turbo - Measure & cut vac lines - Intall vac lines - Cut OEM EBCS plug from factory wires (do not cut if using proper connector on the EBCS!!!) - Trim MAC solenoid wires to appropriate length, place heat shrink on wires then solder to oem leads & shrink wrap. No polarity to worry about. Remember to load your map with the tweaked WGDC, then go for a test drive. Remember you've just made a pretty major change to your boost control system, so it might take a few revisions to get your WGDC just right. As always, start conservative and walk it back up to target.
__________________ Was a Mazdaspeed6 GT #3476 TiGray slicktop Now in a BMW 135i - double the turbos, double the fun! E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD / xHP 340hp / 371tq Last edited by TiGraySpeed6; 08-26-2013 at 11:17 AM. |
| The Following 33 Users Say Thank You to TiGraySpeed6 For This Useful Post: | 802MS3 (09-03-2012), Amnesiac (01-06-2013), atvfreek (09-02-2012), AZSPEED3 (09-03-2012), BigjohnB20 (09-02-2012), BlueStreak (09-03-2012), Boost_creep (09-02-2012), Cevaes_64 (07-26-2013), Drive By Fire (01-23-2015), DSIT995 (01-29-2013), eks666 (11-07-2014), eljefe62 (01-07-2013), El_Diablo (10-12-2013), Fatguy729 (09-02-2012), forcedinduktion (09-03-2012), jack_hammer (01-29-2013), Jap11g (10-29-2014), kritz (09-02-2012), Lex (09-02-2012), magicka (09-04-2012), mazdafreak (04-23-2013), MD1032 (04-04-2015), Menace1 (02-10-2013), Mistersix (10-12-2013), Mizzle (09-02-2012), ms3blackmica (04-01-2013), phate (01-29-2013), rob ms6gt (09-11-2012), Roonster (09-10-2012), SLOWHATCH (09-03-2012), smoogs12 (09-03-2012), Yatta (04-08-2015), [R]usty (08-19-2014) |
![]() Join Date: Dec 2010 Location: Muncie, Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,066
Groans: 82
| Not Ranked : 0 score Nice! Would be cool if we could find the factory harness
__________________ ... TRADED : 07 MS3 GT Silver... fully bolted w/K04 CURRENT : 06 MS6 GT Silver.... KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6 |
| The Following User Says Thank You to Fatguy729 For This Useful Post: | nattun (09-03-2012) |
| Not Ranked : 0 score Can you do a quick check for me and check the resistance of the solenoid with a multimeter? How close is it to the spec of 27 ohms?
(Thread Starter) | Not Ranked : 0 score @Lex - I'll see if I can get the number tomorrow, Monday. If it helps, I was very surprised at how small the changes to my wgdc ended up, +/-15 %
![]() Join Date: Nov 2010 Location: Lido Beach,NY
Rep Power: 8624 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,845
Groans: 95
| Not Ranked : 0 score I have one of these and also sent one to Fink, I will be installing it on Monday. I'll let you know my results, the Humphrey solenoid I have has a resistance of 37.3 ohms.
__________________ Nator is what it does. Last edited by kritz; 09-02-2012 at 05:22 PM. |
| The Following 2 Users Say Thank You to kritz For This Useful Post: | Boost_creep (09-03-2012), Lex (09-03-2012) |
(Thread Starter) | Not Ranked : 0 score BTW, @Lex - thanks for the motivation to get the leads soldered permanent, getting rid of my temporary, "test to be sure it really worked" connections. I'd already let that go a week longer than intended.... So, disconnected so I was taking the reading from the solenoid only, not whatever else is on that path. Resistance starts at 27 even, settles to 26.8 within 10 seconds and stays there. Hope that helps! .
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score Nice write up dude!
__________________ [01:31 PM] SoAgg159: my dick is called "quarter mile" it's about 1/4" long and i can give about 14secs of pleasure [07:06 PM] DarkHeartMS6: yeah. I actually hope i catch my wife with another dude. gives me an excuse to open the emergency door and bail. LOL [09:13 PM] Pu Manchu: i like to take my gf through the drive thru so i can prove that i can pleasure a woman |
| The Following User Says Thank You to forcedinduktion For This Useful Post: | TiGraySpeed6 (09-03-2012) |
Groans: 95
| Not Ranked : 0 score Have you tried them out, if so what were your results?
__________________ Nator is what it does. |
(Thread Starter) | Not Ranked : 0 score FWIW, my stocker reads 25
(Thread Starter) | Not Ranked : 0 score some additional pics- the screws to attach the solenoid to the mounting bracket, 1" 6/32 thick head phillips head,washer & lock nut, and the mount bracket showing the 1" screws in action
(Thread Starter) | Not Ranked : 0 score Two worthwhile updates to this- First, @DSIT995; has located the plug so this can be a truly plug and play alternative! A most excellent find and, at only $8.00, downright cheap as well! The OP has been updated to include this new information! Home » Shop » Connectors / Harnesses » Tyco / AMP » 2 - Way Receptacle Connector Pigtail OEM ECBS Pigtail (CONN-85730) Soldering this to the MAC EBCS wires will allow you to keep the stock plug on the factory wiring harness. No worries about polarity, just be sure they are well connected and use heat shrink- you want a good connection, and well protected! Second update is on mounting location. I recently swapped over to a BNR Stage3, so I had to relocate the MAC 3 Port. I found that the stock TIP Mount by the HPFP was a great location and worked perfect with the same mount I was using on the stock location.
| The Following 6 Users Say Thank You to TiGraySpeed6 For This Useful Post: | beachshoer (01-29-2013), BigjohnB20 (01-29-2013), DSIT995 (01-29-2013), jack_hammer (01-29-2013), jracer (01-29-2013), redboat (02-10-2013) |
![]() Join Date: Nov 2010 Location: South Haven, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,824
Groans: 75
| Not Ranked : 0 score This is awesome. I have all the hose and connectors free from work, so I might just have to do this. Thanks!
__________________ Franken Turbo, built motor, meth. DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more. "Your signature should just say, I'm the shit." -LynzeC |
![]() Join Date: Nov 2009 Location: Pensacola FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 659
| Not Ranked : 0 score So what your saying is, I'm running one of these with your sticker on it? ![]() No worries buddy. I don't mind paying a few extra bucks to make it plug and play. And the stickers nice.
__________________ 2010 BM MS3 BNR S3 HTP 3" Intake(Granny Smith Green PC) CS RP Ebay DP Res Delete JBR shift kit Fully JBR mounted Turbosmart BPV DDM 6K Lows 3K fogs H&R Springs CS RSB CXRacing FMIC AT Internals DIY PnP IM w/ VTCS delete. CS OCC Stratified 3port EBCS HTP Batt Tray Bosch 3bar MAP SS brake lines Works emotions cr-kai 18x7.5 ventus v12s for the street TRM C3s 17x9 Hankook RS3s for track days ![]() STRATIFIED TUNED Other Mazdas in my stable 2010 VR MS3 Wifes Ride ETS TMIC JBR RSB JBR SSP JBR knob AT internals 1999 Miata gtx2867 1.9L VVT built like a brick shithouse 2001 Miata LS RB FSB Hawk HP+ pads Dunlop ZII |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score i did not see this thread when you first posted it. regardless, very nicely done!
__________________ it's fun to do bad things |
Groans: 95
| Not Ranked : 0 score I think he was referring to my post "Humphrey solenoid" BTW mine works quite nicely too.
(Thread Starter) | Not Ranked : 0 score lolz ![]() IIRC, @Lex; isn't using a MAC solenoid either, he's got a spiffy one with the ports on the sides, 2 on one side and 1 on the other. A layout I particularly like, FWIW.... Also, seriously worth noting that if you spend the money, you get the support!!
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | Lex (01-29-2013) |
The supports been great and totally worth it.
__________________ 2010 BM MS3 BNR S3 HTP 3" Intake(Granny Smith Green PC) CS RP Ebay DP Res Delete JBR shift kit Fully JBR mounted Turbosmart BPV DDM 6K Lows 3K fogs H&R Springs CS RSB CXRacing FMIC AT Internals DIY PnP IM w/ VTCS delete. CS OCC Stratified 3port EBCS HTP Batt Tray Bosch 3bar MAP SS brake lines Works emotions cr-kai 18x7.5 ventus v12s for the street TRM C3s 17x9 Hankook RS3s for track days ![]() STRATIFIED TUNED Other Mazdas in my stable 2010 VR MS3 Wifes Ride ETS TMIC JBR RSB JBR SSP JBR knob AT internals 1999 Miata gtx2867 1.9L VVT built like a brick shithouse 2001 Miata LS RB FSB Hawk HP+ pads Dunlop ZII | ||
| The Following User Says Thank You to beachshoer For This Useful Post: | Lex (01-29-2013) |
| Not Ranked : 0 score I wasn't a fan of the MAC solenoids although a lot of the other companies run them. Also consider barbs that are larger rather than smaller - the COBB and GS use tiny barbs and most WG barbs are significantly larger.
| The Following 2 Users Say Thank You to Lex For This Useful Post: | superskaterxes (10-10-2013), TiGraySpeed6 (01-29-2013) |
| Not Ranked : 0 score 1st thing I did was replace all the barbs on my GS...disaster waiting to happen with the baby barbs. I have a lifetime supply of 4mm barbs I got from McMaster for like $10...lol
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 |
| The Following User Says Thank You to Dano For This Useful Post: | TiGraySpeed6 (01-29-2013) |
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,870
| Not Ranked : 0 score Thanks for adding the link of the pigtail to you How-To TiGraySpeed6... A pic of the pigtail next to the grimmspeed pigtail:
__________________ 08.5 MS3 GT - COBB AP : HPFP : DM CatchCanBack to almost stock! 99 Miata NB - Stock for now Building a EFR 6258 Kit w/ Megasquirt 2 enhanced, COPs, Methanol, 750cc Injectors |
| The Following 4 Users Say Thank You to DSIT995 For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Yeah, larger fittings are better. Even cobb sells an "upgrade" kit with the larger nickel plated units. I'm going to upgrade mine with the larger Pneumadyne ones sometime this spring.
| Not Ranked : 0 score Have you not been outside? Its spring down here. You've already done the turbo, what's a couple fittings?
| The Following User Says Thank You to beachshoer For This Useful Post: | TiGraySpeed6 (01-29-2013) |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score lolz- not weather, rather more of a time line thing... so many projects, so little time
![]() | | #25 | ![]() |
| Not Ranked : 0 score Installed my MAC 3-Port(stock location) a couple days ago and finally got a chance to do some testing and so far @ PT Im overboosting.. hitting 5-6lpsi at 30% throttle. Working now on getting some logs and lowering WGDC & Error Comps now.. Car feels a little "off", running a lil rough in boost and sounds different(air induction doesnt sound as smooth) as well.. Going to pull the battery and double check connections before I start tuning around a leak as well..
![]() | | #26 | ![]() |
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 2281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,142
Groans: 324
| Not Ranked : 0 score |
![]() | | #27 | ![]() |
| The Following User Says Thank You to Lex For This Useful Post: | DSIT995 (02-10-2013) |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score Do be sure to make reductions in WGDC when switching from stock 2 port bleed to 3 port interrupt! 3 Port will definitely overboost on wgdc settings used for 2 port That other kit is a nice Ingersol Rand solenoid, but only comes with the parts needed to run in two port mode. Lots of folks are starting to play with two port again, so not necessarily a bad thing, just pointing it out.
![]() | | #29 | ![]() |
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score lolz- don't I know it ![]() Gott be honest, if I was to do this all over again, I'd just get yours Lex, and combine it with your boost dial and call it a day. Just easier all around.
![]() | | #31 | ![]() |
| Not Ranked : 0 score 3 port.. My initial map was using about 40% of the original values I had in the tables.. I wasnt using the same table from the oem EBCS.. lol I prolly would have hit 25psi @ 3000rpms.. I still think my lower RPM values are a little high and Im also not use to how much faster the boost comes on Vs oem setup.. need to make some more tweaks for sure..
![]() | | #32 | ![]() |
![]() Join Date: Jun 2009 Location: Riverside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,560
Groans: 50
| Not Ranked : 0 score What do I want to change on the fittings in the op? Pipe size or tube size? I have the grimmspeed ebcs. Thank you
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score AFAIK the grimmspeed, heck, all of em, have 1/8 inch NPT fittings. Why you changing the fittings on your GS?
![]() | | #34 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
| Not Ranked : 0 score I was wondering why The Humphrey solenoids were not more popular for this application since they have a lower dwell time, use less energy than the mac solenoids, and are capable of 40+ CPS on a paintball marker.
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress Last edited by himurax13; 02-10-2013 at 07:38 PM. |
| The Following User Says Thank You to himurax13 For This Useful Post: | rfinkle2 (02-06-2014) |
![]() | | #35 | ![]() |
Groans: 95
| Not Ranked : 0 score Love the solenoid, responds great it is great for this application. I have had mine in for a few weeks now works nicely with a tune from Mr. @rfinkle2;
| The Following User Says Thank You to kritz For This Useful Post: | rfinkle2 (02-10-2013) |
![]() | | #36 | ![]() |
Groans: 50
| Not Ranked : 0 score To bigger ones
| The Following User Says Thank You to Boosted Beluga For This Useful Post: | phate (02-10-2013) |
![]() | | #37 | ![]() |
| The Following 2 Users Say Thank You to TiGraySpeed6 For This Useful Post: | Boosted Beluga (02-10-2013), rfinkle2 (02-10-2013) |
![]() | | #38 | ![]() |
My EBCV comes with 1/4" barbs - not sure why those guys all went with such small barbs. Also not to toot my own horn here but zap straps are kinda lame for clamping hoses and are prone to causing boost hoses to come off at the wrong time. Better get clamps like I offer or worm clamps
![]() | | #39 | ![]() |
Groans: 95
| Not Ranked : 0 score Smaller diameter tubing will actually decrease the response time to actuate the IWG.
![]() | | #40 | ![]() |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | kritz (02-10-2013) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/poor-man-s-3-port-ebcs-123490/ | ||||
| ????????, ??????-?????????, 3 ????? | This thread | Refback | 04-06-2015 05:57 PM | |
| Will RX8 EGR Vacuum Switch work as MS6 Boost Control Solenoid? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 04-26-2013 06:44 AM | |
| Whats New/General Speed 6 Discussion - Page 170 | This thread | Refback | 12-31-2012 05:03 PM | |
| Grimmspeed EBCS in 2-port mode | TEASE | MazdaSpeed 3/6 - Big Turbo Builds | 10 | 04-09-2013 04:57 PM |
| Grimmspeed 3 Port In 2 Port Mode on IWG? | bewsted | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 12-21-2011 08:59 AM |
| GS EBCS 3-port - tuning compensation? | xcoldricex | MazdaSpeed 3/6 - ECU Computer Tuning | 3 | 02-13-2011 12:00 AM |
