 Old 10-15-2014, 06:29 PM   #1
coopsspeed's Avatar
Posts: 155   (View Stats)
coopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond repute
Default Possible bad turbo seals or no?
In need of some insight!
So i had my shortblock rebuilt and i dropped the motor in the car, just cranked it a couple of times and then noticed an oil leak from where the turbo and the dp flange join. Now there is not suppose to be oil on the hot side of the turbo obviously. The oil is dark so im not sure what to think except for my seals being blown.
This is a new turbo with only 10k miles on it so its hard to believe the seals are gone already. A diagnosis idea i have is to crank the motor again but without the dp connected to see if oil collects in the turbo as i crank. Question is, is this a smart way to go about diagnosing it? I dont see the issue cranking without a dp connected.
Please help!
2007 Black Mica Speed3
speedperf6rmanc3 built short block >> Manley H-beam rods >> Wiseco pistons >> BNR stage 1 >> Cobb sf intake >> Corksport TIP >> ISC coilovers >> Autotech hpfp >> Forge V1 BPV >> jbr stage 2 occ >> jbr 88d RMM >> UR tp >> CNT cat back exhaust >> Cobb AP >> Richtuned by Anthony
coopsspeed is offline   Reply With Quote
 Old 11-12-2014, 08:11 AM   #2
eks666's Avatar
Posts: 15   (View Stats)
eks666 is a glorious beacon of lighteks666 is a glorious beacon of lighteks666 is a glorious beacon of lighteks666 is a glorious beacon of lighteks666 is a glorious beacon of light
did you just crank it or it run for a while? strange you could see it after few cranks. specially in a turbo to DP connection - this is after exhaust mani so there is a lot possible reasons...
2006 Mazdaspeed6 - Cobb Accessport v3; CS SRI+TIH; CX-Racing Fmic; Catted M2 DP; Magnaflow CBE; Turbosmart BPV; Cp-e RMM, JBR egr delete; JBR SSP; H&R Coilovers; NGK One step colder;
eks666 is offline   Reply With Quote
 Old 11-12-2014, 09:26 AM   #3
coopsspeed's Avatar
I had gotten it figured out. Thanks
 Old 11-13-2014, 12:52 AM   #4
eks666's Avatar
so? what was it?
 Old 11-13-2014, 04:15 AM   #5
coopsspeed's Avatar
My seals were shot
 Old 11-25-2014, 02:43 PM   #6
HaXiR's Avatar
Posts: 315   (View Stats)
HaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud of
WHy did mazda have to use such a shit turbo... Literally for a few bucks more in their bulk buying they could have avoided all the issues. I would have gladly paid another hundred or 2 or whatever upon purchase at the dealer for a turbo that wasn't going to smoke or leak oil.
HaXiR is offline   Reply With Quote
Bad turbo seals kyle53 MazdaSpeed 6 - Engine, Transmission & Driveline 10 11-05-2013 10:24 AM
Turbo seals went joey MazdaSpeed 3/6 - Turbo Induction 6 08-31-2012 01:52 AM
Turbo seals done? titusdrake MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 09-23-2011 03:48 PM
i knew the turbo seals were gone but this much? k0m MazdaSpeed 3/6 - Turbo Induction 19 01-06-2009 04:04 PM
Bye Bye Turbo Seals Laloosh MazdaSpeed 3/6 - Turbo Induction 50 04-27-2008 08:55 PM
Page generated in 0.26301 seconds with 22 queries
