Groans: 239
(Thread Starter) | Not Ranked : 0 score any of you guys running precision's? what did you use for oil feed/coolant feed? wont have a problem with oil drain. i would want to preserve the use of the stock oil feed banjo, and replace with a different thread banjo bolt if applicable will be goin on a t3 60-1 journal bearing
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
Groans: 793
| Not Ranked : 0 score @kmac, help this chigga out. I'll make it worth your while.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
| The Following User Says Thank You to Tokay444 For This Useful Post: | rfinkle2 (02-02-2012) |
Groans: 433
| Not Ranked : 0 score Precision should be able to give you the thread specs on the CHRA, or it may be on their website, then you can get banjos accordingly holmes
![]() Join Date: Jan 2010 Location: Ladera Ranch, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 91
| Not Ranked : 0 score Orrrrr you could buy my 5557 so I can get a gtx3071 Lol jk but precisions are good turbos for the money. Plus its cheap to rebuild if it takes a shit. Sent from my BlackBerry 9300 using Tapatalk
__________________ 2008 MAZDASPEED 3 GT | Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP | | Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 | | Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip | |
Groans: 239
(Thread Starter) | Not Ranked : 0 score Kevin has been eluding me
| Not Ranked : 0 score Erich is running a Precision as well. EDIT: Erich is running a Bullseye. Edit: I think Speed6 killah and Doubleflusher are other guys running Precision. Last edited by rfinkle2; 02-02-2012 at 01:47 PM. |
| Brian's ballin' azz Precision turbo build | bmylez | MazdaSpeed 3/6 - Big Turbo Builds | 167 | 11-27-2018 09:51 PM |
| Anyone running a precision turbo on MS3 | origjdm3 | MazdaSpeed 3/6 - Big Turbo Builds | 37 | 07-08-2010 04:04 PM |
| K04 oil feed line & oil drain line | NJSPEED3 | MazdaSpeed 3/6 - Turbo Induction | 12 | 09-14-2009 10:46 AM |
