  • 1 Post By Mattyhawk1
 Old 05-01-2014, 10:09 AM   #1
typeshluder's Avatar
Posts: 127   (View Stats)
typeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the world
Default Preventing Smoking Turbo
I got my car back on Monday after having the turbo replaced under the 7 year extended warranty. Is the new turbo updated to not smoke? If not, is there anything to do to prevent it from happening again? I searched and only found how to get your already smoking turbo to stop smoking.
typeshluder is offline   Reply With Quote
 Old 05-01-2014, 10:11 AM   #2
dan7225's Avatar
Posts: 511   (View Stats)
what was your mileage?
restrictor bolt.
5w-40.
 Old 05-01-2014, 10:42 AM   #3
restrictor bolt.
5w-40.
56,000. I've been using 5w40 Rotella, but Mazda made me pay for an oil change of 5w30 to make sure it still smoked after the oil change. Made no sense, but I think my total bill was close to $2400 and I only paid $38.
I've read all those, but they are generally for if you are already smoking. I have a new turbo so am not currently smoking. Maybe the concept is the same though, that's what I'm asking.
Originally Posted by Mattyhawk1 View Post
I an't help but love how your CWP Gen1 looks. Wish they were available when I bought mine in 07. Those are TRM C3's, right?
Evo X
Last edited by typeshluder; 05-01-2014 at 10:42 AM. Reason: MSF Database - Automerged Doublepost
 Old 05-01-2014, 10:53 AM   #4
Mattyhawk1's Avatar
Posts: 739   (View Stats)
The bolt is the best from what I have read. I have one sitting to be installed, but I am still not smoking with 68,000. I have been using 5W40 synthetic since 20K and at about 45K got a Hypertech and raised idle to 850RPM. Now I have AP and still have it at 850rpm.
Consider all those things Bnoon wrote about in the thread of his notes as ways to fix and prevent. The way I see it, for those who could not get their turbos from smoking after doing all these things needed a new turbo, the seals were done. By doing the fixes now on a new turbo, you are preventing seal damage or at least extending the life of the seals.
kvg823 likes this.
The Following 3 Users Say Thank You to Mattyhawk1 For This Useful Post:
ItsNox (05-25-2014), kvg823 (05-21-2014), typeshluder (05-01-2014)
 Old 05-01-2014, 10:37 AM   #5
Mattyhawk1's Avatar
Smoke at idle fixes, my thoughts and notes
Bnoon restrictor bolts
Oil restrictor bolt install
 Old 05-01-2014, 12:14 PM   #6
Posts: 2,826   (View Stats)
For cars that have not had the valve cover upgrade and PVC relocate (the real fix), the simplest fix and the one that works well for me, even with a catless exhaust and almost 99,000 smoke free miles is to run Rotella 5-40s full synthetic oil and to raise idle rpm by +200.
dan7225 (05-01-2014)
 Old 05-01-2014, 04:28 PM   #7
ihasmazda's Avatar
Posts: 1,011   (View Stats)
it's really weird how some people's turbos smoke at 15k miles and some never do at 150k miles. i think there's some mystery factor at work that no one has identified
2007 Mazdaspeed 6 GT
2003 Ford Ranger XLT
 Old 05-21-2014, 07:54 AM   #8
rudydecc's Avatar
Posts: 113   (View Stats)
rudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud of
I will tell you this much, when I took my car in even with a dp, and full exhaust and intake set up, Mazda still replaced my turbo.
The service manager sent my vin to Mazda and they called Him back within three hours to tell him that they had sent a new turbo to the dealership.
Apparently Mazda was able to figure out exactly when they started putting in bad turbos, and mine was definitely one of them. All the other fixes, new turbo inlet, valve cover, oil type and weight and no bearing on my car smoking.
2008 Mazdaspeed3 GT ::COBB STS/Turbo Inlet/AP/SW/BPV, Fujita F5 CAI, CP-E RMM/DP/CBE/FMIC, TWM Shifter Bushings/JBR Side Mounts::
2019 Audi Q7
rudydecc is offline   Reply With Quote
 Old 08-13-2014, 08:36 PM   #9
diepanthony's Avatar
Posts: 63   (View Stats)
diepanthony is a jewel in the roughdiepanthony is a jewel in the roughdiepanthony is a jewel in the roughdiepanthony is a jewel in the rough
Mine dont smoke but sure burns oil cuz inseem to be missing oil everytime I check.. And I think its bs that they only extended the warranty and not just replace all bad turbos. My car was out of warranty when I got the letter..
diepanthony is offline   Reply With Quote
 Old 10-14-2014, 04:16 AM   #10
rudydecc's Avatar
Mine was out of the extended warranty by three months, and they still replaced it.
2019 Audi Q7
 Old 10-14-2014, 06:19 PM   #11
Poohster's Avatar
Posts: 353   (View Stats)
Poohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the world
Check out some pics of improved turbo.. That is the revised K04. I have the an upgraded K04 with new seals and it still smokes. Heavier weight oil 5W40, bnoon or MD restrictor oil bolt would help.
06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP
RPM: Sport Springs, Shark Fin, LED side markers
CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount
Poohster is offline   Reply With Quote
GB smoking turbo fix!!! ptperformance Mazdaspeed3/6 General Discussion 654 11-26-2013 08:31 AM
smoking turbo fc3schick87 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 04-14-2010 01:25 PM
Page generated in 0.32379 seconds with 27 queries
